Results 1 to 18 of 18
Thread: mobile 2500 72/45W
    Xtreme Mentor
    Feb 2004
    The Netherlands
    mobile 2500 72/45W
    whats the diff between a 45 or a 72W xp-m 2500+ ? is the W for watts and is it just the amount of power it needs? the 45W costs a bit more. And whats better?
    Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
    32 GB Patriot Viper Steel 3733 CL14 (1.51v)
    RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
    Tons of NVMe & SATA SSDs
    LG 27GL850 + Asus MG279Q
    Meshify C white
    IT Engineer in the making
    Jun 2003
    Former Kingdom of Bavaria
    The mobile barton with 45W consumes only these 45W in comparison to the normal one that consumes 72W, because the Vcore on that chip is at only 1,45V.
    That's why the 45W chip cost more and is indeed better!
    Xtreme Mentor
    Feb 2004
    The Netherlands
    ok thnx... and another thing: I heard the 2500 is a bit different from the 2400/2600? is that true or is the 2600 the best out of those 3?
    Meshify C white
    Dec 2003
    Tennessee
    good question
    **bump**
    Athlon Barton Mobile 2600+
    IQYHA0401UPMW
    236x11..1.8 VCore @ 2602mhz
    LanParty Ultra 400 rev.B
    Mushkin PC3200 Black Level II 2X256MB BH-5
    2-2-2-2-11 (3.1v)
    ATI Radeon 9700 Pro
    2 X Western Digital WD800JB (Raid 0)
    Thermalright SLK-900U
    Antec TrueControl 550W PSU
    WinXP
    Xtreme Mentor
    Feb 2004
    The Netherlands
    Meshify C white
    Xtreme Mentor
    Feb 2004
    The Netherlands
    sry I refreshed the page and then he posted the same.. lol
    Meshify C white
    Jan 2003
    Holland
    Biohead the 2600 is an athlon xp and the 2400 and 2500 are bartons, so the best chance on a nice score is with the 2500 but as we all see there is non or a verry little differends between the 2400 and 2500 when the got OCed to the max.
    Sep 2003
    i've been hearing the 2600+ mobiles are the best. If you think about it, they're also rated for the highest clock speed at 1.45v, so it makes sense. They are barton's too, just check out newegg.
    Q6700 | P5W DH | 2GB Corsair XMS DDR2-800 4-4-4-12 | 512 MB X1900XT | WinXP Home
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    yah the 2600s are bartons too
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Jan 2003
    Holland
    I think the 2400, 2500 and 2600 barton mobiles having the same chips only the 2600 is tested on 2600+ speeds and the 2400 on 2400 speeds, look to the overklocked results, there is just no differents.
    Aug 2003
    Somewhere, beyond the sea
    Dumb question on my first foray into AMD land after years of building Intel:
    I just put a mobile Barton 2500+ into a DFI NF2 Ultra Infinity. If the default Vcore on the chip is 1.45, why does the mobo pump 1.58v into the CPU as default? Is it just a consequence of having an "unrecognized" CPU in the board?
    (FYI, the default multi is 6 and FSB is 100...)
    EDIT: Never mind. I figured it out.
    Jul 2003
    all the desktop boards seem to do it.
    Xtreme Mentor
    Feb 2004
    The Netherlands
    the mobiles I've seen all have 1,55v except for the 2500 which can be bought in 45W/1,45v too... But maybe its just a sucky store... But for now its the only store I found that have them (except for NewEgg but they are sold out )
    cya
    Meshify C white
    Jan 2003
    Holland
    cya
    Your from holland right!
    http://www.ritrade.de and go to CPU >>> CPU Mobile Sockel A
    and than you will find the mobiles in all kind I orded this one yesterday
    AMD Athlon XP-M 2400+ 1800 MHz (OPGA, Mainstream, ``Barton``) CPU Mobile Sockel A
    Preis: 101,44
    good luck my dutch friend
    Aug 2003
    And, of course, newegg raised the price $7 since last week.
    Xtreme Mentor
    Feb 2004
    The Netherlands
    Preis: 101,44
    hallo hollandse vriend (hey dutch friend)
    I found another german website www.go2shop.at
    I'll check out ur website lol :P
    mzzls
    Meshify C white
    Xtreme Mentor
    Feb 2004
    The Netherlands
    lol whats the differents between Desktop replacement (?), Mainstream and LowPower? You ordered the mainstream version does that mean higher voltage or something?
    And im getting a bit confused by all those different 2600's... higher/lower clocks, mainstream/desktop, barton/tbred etc etc... cant they just put a "very good overclockable AMD mobile 2600" these instead? btw what ur msn addres I'd like to talk to u goedemorgen
    Meshify C white
  18. #18
    Jan 2003
    Holland
    The Desktop replacement is almost the same as the mainstream but the biggest differends between it is that the mainstream only 45W heat produced and the Dektop... 72W. So the mainstream is less hot than the desktop... and will OC harder because he has better temperatures. The LopPower version is a version with the smallest amount of heat producment (good English?) but it is not able to work in a standard Socket A motherboard. If you order a mobile cpu just order the mainstreams.
    EDIT:
    on your site (go2shop) this is the right cpu to order:
    CPU AMD Mobile Athlon XP 2400+ 45W (again the 45W are mainstreams and able to work in any Socket A motherboard)
