Results 1 to 11 of 11
Thread: Mach 1 Prommie & R507?!?
    Oct 2002
    Scottsdale, AZ
    Question Mach 1 Prommie & R507?!?
    I just got a Mach1 Prommie and I called my local refridgerator repair man, he said he'll come by and empty/recharge the compressor with my choice of R404 or R507, are there any extra modifications that I would have to perform with either of these recharges and what would it entail... ive heard people had great success with R507 so I was going to do that, just wanted to ask first...
    i3-540 @ 4.2ghz
    Asrock P55 Extreme4
    8gb DDR3 @ 1760mhz
    2 x 6850's in Crossfire
    Admin
    Mar 2003
    North Texas
    Is this watersnoodge?
    I have 404a in my prommie with no modifications what-so-ever.
    JVLK has 507 in his with no mods.
    You can increase performance by changing the length of the captube and adding a larger drier. These are a couple of the things I've seen done by bowman. Search some of his mods for more info on this.
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    I have had good luck with the 507 mod without cap tube and this may be easiest to do.
    have the ac guys send in the charge slowly and fire up the system. you should set the system to operate at appoximatly 6 inches of vacuum for best results. Dont forget when you take the hoses off you will loose a little bit of charge, iirc this will pull you deeper into a vacuum. so you 6 inches becomes 8 inches of vaccum. Your compressor will run warm and not ice up on the side at idle based upon the units I have worked on.
    Make sure you put the sides on when in operation to maintain best air flow across the compressors.
    The AC guy will need to install a schrader valve, he may also vampire tap the sealed system to recover the gas.
    Look on the back of the unit for the original charge amount.
    So he should be able to work with "pull it to 250 microns and set it for 6 inches of vacuum"
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Jul 2002
    Springfield,IL
    Excelent post Fugger :thumbsup: i am about to have this done to my Mach I
    how much of a temp drop unloaded and loaded did you see ?
    Jun 2002
    Las Vegas
    most of the time I am looking at error mode on the display, playing games(CS, generaly, delta force, ...) it will drop to 48c on the display @ 4Ghz on a 3.2EE.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Oct 2003
    About how much will this mod cost??
    Jun 2002
    Las Vegas
    time + gas, about $200
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    HVAC/R Engineer
    Nov 2003
    Make sure that the machine is off and with pressure in the suction lines when you disconect the hoses.
    Oct 2002
    Scottsdale, AZ
    Re: Mach 1 Prommie & R507?!?
    Yep, its me MC, i know youd be excited that I got into phase change, but I was actually asking "as my friend", who actually posts on this board as "Semper FI", he just didnt know exactly how to ask the question so I asked it for him...
    im still chuggin away for team puss though, trying to break 22k with my 9800np and barton 2500... its not easy
    i3-540 @ 4.2ghz
    Asrock P55 Extreme4
    8gb DDR3 @ 1760mhz
    Feb 2004
    nice post. Seems like an easy upgrade.
    Xtreme Mentor
    Nov 2003
    Snoodge, how did the mod go? have you had it done yet?
