After modding yesterday, the mods worked perfectly. To start I had 1.85v when set to 1.7v and 3.29v when set to 2.9v which was perfect for what I wanted. Only problem was that even with 3.2v, I still couldn't get above 230FSB stable with 1 or 2x 512MB Mushkin Lvl II PC3500 memory in any slot. I even tried my 512MB CH5 HyperX PC3500 and the samething, all this at 2x LDT. So I decided to raise the vdimm a little more to 3.5 to test, same problem, so I turned the pot back down to 3.3(2.9 in BIOS). So now I was starting to think that these A64s don't like double sided memory and I don't have any single sided memory here to test with. Anyways, I turned off the PC to insert both memory modules back and tried to power up and beep, beep. So reinstalled the memory modules and even tried the HyperX and samething. So I started to think that the problem could be and then immediately thought, DEAD CPU. Lucky I had another CPU here, popped it in and it fired right up. So from my testing, my CPU died from too much vdimm voltage and not from vdd, LDT voltage(mine were set to 1.7v vdd & 1.3v LDT) or CPU voltage(1.65v while testing) and my setup is watercooled, so temps weren't a problem. Well back to testing(below 3.5v now)
Calcu
what memory was that?
