Results 1 to 19 of 19
Thread: New IC7 MAX3 beta bios 14b4
    Dec 2002
    Netherlands
    I'm downloading it now. There aren't any release notes so I don't know what the difference will be but probably Prescott support?
    over here
    ZX12 Kawa power
    DFI nf4, AMD 64 X2 4400+ prometeia cooled, 2 x 512mb Twinmos SP 2.2.2.0, Antec 550w, 7800GTX Zalman VF700cu cooled
    Life is like a box of cpu's, you never know what you're gonna get.
    Mar 2003
    Netherlands
    I flashed it already, don't see any new things, still stable
    Intel Pentium D 920 - Asus P5WD2 Premium - 2x2GB OCZ PC2 5400 - XFX GeForce 7600GT - 2x Seagate 250GB
    Dec 2002
    Netherlands
    It doesn't alow me as high GAT settings as before with the 1.3 bios. But perhaps that is because the memory is tighter allready with this bios. Don't know.
    ZX12 Kawa power
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Yes, thanks Abit!
    And like mkleingeld said, put some release notes with it.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Dec 2003
    At work
    Upgraded the BIOS...no idea what's new or fixed.
    Server: HP Proliant ML370 G6, 2x Xeon X5690, 144GB ECC Registered, 8x OCZ Vertex 3 MAX IOPS 240GB on LSi 9265-8i (RAID 0), 12x Seagate Constellation ES.2 3TB SAS on LSi 9280-24i4e (RAID 6) and dual 1200W redundant power supplies.
    Gamer: Intel Core i7 6950X@4.2GHz, Rampage Edition 10, 128GB (8x16GB) Corsair Dominator Platinum 2800MHz, 2x NVidia Titan X (Pascal), Corsair H110i, Vengeance C70 w/Corsair AX1500i, Intel P3700 2TB (boot), Samsung SM961 1TB (Games), 2x Samsung PM1725 6.4TB (11.64TB usable) Windows Software RAID 0 (local storage).
    Beater: Xeon E5-1680 V3, NCase M1, ASRock X99-iTX/ac, 2x32GB Crucial 2400MHz RDIMMs, eVGA Titan X (Maxwell), Samsung 950 Pro 512GB, Corsair SF600, Asetek 92mm AIO water cooler.
    Server/workstation: 2x Xeon E5-2687W V2, Asus Z9PE-D8, 256GB 1866MHz Samsung LRDIMMs (8x32GB), eVGA Titan X (Maxwell), 2x Intel S3610 1.6TB SSD, Corsair AX1500i, Chenbro SR10769, Intel P3700 2TB.
    Thanks for the help (or lack thereof) in resolving my P3700 issue, FUGGER...
    Jan 2004
    Australia, Sydney
    i was wondering does this bios allow you to set vdim above 2.8+ cause i cant go above 2.8+ with the 1.3 bios, i can do 2.9 but the problem is its not stable i loose something like 20 mhz of my ram oc
    Maximus Gene-z crazy little board.
    Xtreme X.I.P. Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    No that is a physical problem with the hardware.
    System
    ASUS Z170-Pro
    Skylake i7-6700K @ 4600 Mhz
    MSI GTX 1070 Armor OC
    32 GB G.Skill Ripjaws V
    Samsung 850 EVO (2)
    EVGA SuperNOVA 650 G2
    Corsair Hydro H90
    NZXT S340
    XS Intel News & DČOL enhanced
    Nov 2003
    Netherlands
    when you set to 3.2 it should be fine/ atleast better.
    Nov 2003
    CT
    Hey Fugger its 12:00 est. time... wheres ur review ?
    |-| 2.8C @ 3.5GHZ - 250FSB|-| 1GB Corsair XMS PC3500 @ 2-5-2-2 |-| IC7-Max3 |-| MCX478-V |-|
    |-| PNY 6800 GT @ 427/1160 |-| AudiGy 2 Sound Card |-| Logitech's Z560's |-| 19" NEC FP912SB |-|
    |-| 3DMark01: 23125|-|
    Dec 2003
    The land of sexy
    12 on feb 1st. The nda expires the 2nd. so 12AM sunday night mon morning. Not 12am sat night sun morning.
    Nov 2003
    CT
    Damet!
    Jun 2002
    Las Vegas
    NDA lifted noon sunday PST
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Nov 2003
    CT
    So fugger you will have results in 1 hour from now?
    Dec 2003
    The land of sexy
    noon!!!! w00t. I kept hearing the 2nd. Hell yeah i get back from work and BOOM there will be precott!
    Nov 2003
    CT
    3rd-Dimension I new I wasn't haulucinating when i saw Fugger say by 12:00 sunday afternoon!
    Jan 2004
    Australia, Sydney
    So ur telling me at 3.2 it wont decrease stability of my ram like the other setting do?
    Edit: Flashed bios and still cant run ram at 3.2 or anything above 2.8, With my P4C800-D i could run the ram at 3.1 no problem at 2.5 4 4 7 at 272fsb prime stable, So it aint the ram. stupid bloody :smileysex
    XS - Extra Strong
    Aug 2003
    Toronto, Canada
    Maybe its something to do with the release of prescott?
    Just a guess..
    -Phenom2 x6 1055 @stock
    -8gb ddr3
    -Gigabyte UD3
    -Geforce 7900Gt 755/1863 1.562v vgpu
    -OCZ Powersupply 600w
  18. #18
    Oct 2003
    Lincoln, NE
    Bingo....
    System
    ASUS Z170-Pro
    Samsung 850 EVO (2)
    Corsair Hydro H90
    NZXT S340
  19. #19
    Jul 2003
    Rio de Janeiro - Brazil
    i have tested with no difference between beta and 1.3
    Q9550 EO @ 4.1
    Asus P5Q Deluxe
    4 Gb DDR2 Gskill
    2xVelociraptors 300 gb Raid 0
    Sapphire Vapor 4870 1Gb
    PCP&C 750w silencer psu
