Results 1 to 8 of 8
Thread: Help with a new PSU
    Feb 2003
    Belgrade, Serbia
    Help with a new PSU
    I got to change my enermax since i started having problems with half the molex connectors on it. I would like to know what do you guys think about this Aopen PSU, and is it as i think it is a Forton PSU.
    http://usa.aopen.com/products/power/FSP530-60GN.htm
    also is PFC a big deal and should i look into a PSU with it or not
    thanks
    ps: opinions on their 400w PSUs would be welcome also
    Jun 2003
    Ohio
    That PSU is great. PFC is nice to keep your rails exactly where you want, and the fortronn 530 has tons of room to adjust.
    It's probably the second or third best psu out, and definatly the best bang/buck.
    I have a 350watt sparkle that is a rebadged fortron, and it runs whatever I throw at it.
    Dud3!
    Guest
    Don'y buy anything from Aopen! Especially not a PSU.
    PSUs from best to not as good:
    PC Power & Cooling
    Zalman and Antec
    Sparkle
    Feb 2003
    Sweden
    You say that out of experience?
    Or because you want it to be that way?
    I have read some about FSP psu tonight and most ppl seem to like them.
    X3520
    R2E
    Corsair DDR3 1600mhz
    X25-e
    2xCorsair S128
    GTX 295
    Nov 2002
    Canby, OR
    the Aopen PSU looks like a rebadged Fortron/Sparkle. it is surely using a Fortron/Sparkle part number.
    PC Power & Cooling
    Sparkle
    Fortron/Sparkle used to make the lower wattage PSUs for PCP&C, and they may still. i haven't really been keeping up on those things.
    Sep 2003
    Great Britain
    I own Zalman and Antec PSU's, you can't go wrong with them.
    Never owned an Aopen - so can't say.
    #1 - AMD XP3000 333mhz 12 x 200mhz / Abit NF7 v2.0 / Corsair 512Mb PC3200 Pro / XFX 6800 Ultra
    #2 - A64 3000 / MSI K8T Neo / Corsair 3200LL / MSI FX5200 with TV / WinXP 64-bit (beta)
    Nov 2003
    I'm sure Dud3 means well, but his reasoning is suspect.
    After all, Fortron makes Sparkle and AOpen PSUs (and some PC Power & Cooling ones).
    I haven had problem with Fortron PSUs for years. Very high quality, always above their rated specs in output power and relatively good efficiency. Only Seasonic makes more efficient PSUs, afaik.
    However, it's most likely true that PC Power & Cooling high end PSUs are hard to beat. People who use them swear by them.
    I just personally tried a 480W Tagan and it failed to produce even specified output power. This PSU and all Be Quiet (both blackline and colorline) PSUs are made by Topower. I wouldn't recommend them for HC overclocking as they seem to have some quality control issues, like my unit (and several others at spcr forums) did.
    regards,
    Halcyon
    Twisted
    Guest
    i have had GREAT luck with sparkles and TTGi psus
