Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: XP2000@2920mhz prime stable
    Jan 2003
    Germany
    Cool T-Bred 1666mhz@2920mhz prime stable
    Hi,
    this is my new project. I reach 2920mhz with a T-Bred 1666mhz AIUHB 0316 MPMW. It maxes out @3045mhz. There I can make a Sandra bench. Further I don't testet it because the interesting thing is the stability.
    The cooling is a selfmade compressor system with R404a and a Danfoss SC15D compressor which has 300W@ -40°C. I used a TEV for this thing. On 2920mhz @ 2,175V I have idle -15°C and load -8°C with CPU Disconnect function is off. With CPU Disconnect it is -23°Cin idle. The measuring is the CPU internal Diode! The Board is a old Abit KD7a. Yes I have also a NF7 but with this Board I reach only 2600mhz so this board suxx. I ordered now a MSI KT6-delta. Next week I try more.
    All benches are on the KD7. The photos are on the NF7. More pics later.
    Oct 2003
    Sweden up north!
    §§§§! Thats some xtream clock dude! Over 3ghz with an 2000+! con gratz man, burn it in a bit and get it primestable over 3g now
    | AN7 | Barton 2500+ @ 212x13 AQXEA 0330UMPW "Z" | R9600Pro FireBlade 400/300 @ 560/413 NO vmods! | Tyan G9800Pro 492+/390++ Still testing |
    | 24/7 | 230x10.5@1.82v and 1.75vdd | G9800Pro Tyan 470/380 For day to day use |
    Jan 2003
    Germany
    believe me I try my best. Maybe with the new Mainboard!
    0445 SPAW Winchester@ 3311mhz@ R404a self made on die cooling / OCZ 600W
    Apr 2003
    Belgium/ Malaysia
    nice score
    what's the fsb?
    that's alot of beer over there
    Jun 2003
    The Netherlands
    Nice overclock.. Where did you overclock that processor , there seems to be a few people
    AMD Athlon 64 3000+ @ 10 x 250 HTT | MSI K8N Neo Platinum | Mushkin 512 mb DDR BH5 @ 2-2-2-5 | Club3d ATI Radeon 9700 @ default speeds | 2 x Maxtor 160 GB SATA | 80 GB Western Digital
    Feb 2003
    Miles from Civilization...
    Nice work.
    .... how was the NF7 holding you back?
    Thx.
    Pops.
    .... I spent a Fortune on Booze and Women.... the rest I just wasted.
    My Heatware
    Xtreme X.I.P.
    Nov 2002
    Shipai
    jau! noch n hamburger!
    becks gold? hatten sie kein normales becks mehr? naja die richtige marke ists schonmal!
    sehr fettes setup! wo hast du den radi her? ich hab vor auch n kompressor system zu bauen, kannst du mir eventuell helfen? wie hast du zb die blöcke gelötet? wenn du willst kann ich dir mein a7n8x ausleihen, kann bis 250fbs+ benchen und die caps und mosfets sind vom feinsten, werden kaum warm!
    sorry, just excited to finally meet somebody from hh in this forum
    Nov 2003
    Germany Berlin
    nice score
    achja duw würdest dich wundern wieviel deutsche hier sind
    2,8€ @4130mhz
    radeon 98 pro440/380
    ic-7max3 full modded
    Chuck Norris Worshipper
    Dec 2002
    Stevens Point, Wisconsin
    now that's Xtreme!!
    Oct 2002
    FL
    wonderful clocks
    Nov 2003
    Denmark
    Yeah! amd power! - could you pleas run superpi, and uploade the result?
    |-|DFI LP nF4 Ultra-D passively cooled chipset|-|
    |-|Winchester 3500+ cooled DD TDX A64 and passive car radiator|-|
    |-|2*512 Corsair PC3500 (BH-5)|-|
    |-|HIS X800XL cooled by zalman VF700-cu @ 5v|-|
    |-|Powered by Tagan 480w PSU|-|
    If you are a Dane --> tjek min hp for flere billeder (http://www.try-this.dk)
    Oct 2002
    The Netherlands
    The good stuff Very, very Xtreme..
    Oct 2002
    Germany
    hmm da mus sich mich auch mal wieder einloggn...auch wenn ich nicht mehr im "oc-genre" bin
    endlich mal wieder jemand der dt. land würdig vertritt hrhr ;D go on !...
    Jan 2004
    bavaria, germany
    Deutsche?? Wo??
    Tja Diamond, ich kenn dein Sys ja schon von KM. trotzdem immer wieder beeindruckend!
    Xtreme X.I.P.
    Nov 2002
    Shipai
    sieh an sieh an da kommen sie auf einmal aus allen löchern gekrochen ^^
    Xtreme Legend
    Jun 2002
    Belgium / Denmark / Russia
    damn nice chip, almost as good as my ex-1700+
    Feb 2003
    San Diego
    You did that on a KT400a? I knew I shouldn't have jumped off of the Via ship... Oh well, I'll go back to Via as soon as I get my new IDE card. I always seemed to have much better luck on Via chipsets than any other too. That's some xtreme clockin there...
    Take out your ex tonight... one bullet should do it.
    I've effectively killed my sig because it is no longer accurate. Oh well!
    A64 3200+ Newcie
    2x512 OCz PC3500 GX
    DFI NF3 250gb LPUT
    No Name 9700 that refuses to die!
  18. #18
    Aug 2003
    Chicago InsaneTek.com
    EDIT
    Nvm, reread the first post.
  19. #19
    Jan 2003
    Germany
    ok I upload some more pics today afternoon Superpi 1M or?
    I know the fsb suxx because the don't do much more. The NF7 holding me back in the Vcore. 2500@1,85 stable, same frequency@2,00 Volt not stable, 2,1V bluescreen. And the higher the Vcore, the lower the fsb i have to set. So this Board really suxx. I tried the KD7 only because I wanted to see the real Temperature. I believed on the NF7 that my project suxx until I tried the other Board. That was luck I think.I had also the same chip as the JCviggen 0308 XPMW but that was not so good. Max.Vcore on this chip 2,06 V and with this I reached 2860Mhz. Not more. I think generally that the AIUHB chip's can go higher with the Vcore.
    So nun für die Deutschen:
    Nene ich komm net aus Hamburg, sondern aus der nähe von Nürnberg. Ich und mein Kumpel saufen das Zeuch ohne Ende. Geh mal auf www.dichtistpflicht.com da siehst es. Habt ihr vielleicht nocheinpaar Becksdosen bei euch??? Das wär echt korrekt
  20. #20
    c[_]
    Nov 2002
    Alberta, Canada
    What month/week/stepping on the 2000+ ?
    Mines 0318 SPDW DUT3C Y... Can pull 2600mhz on air with the right setup.
    All along the watchtower the watchmen watch the eternal return.
  21. #21
    Jan 2003
    Germany
    0316 MPMW DUT3C
  22. #22
    Dec 2003
    @sayaa
    Bist nicht der einzige hamburger.....
    @Diamonddog
    Wow, great oc!!! But: you really went to a lan with that setup?
    DD
  23. #23
    Jan 2003
    Germany
    i don't go to lan's because the where I am is computer club and there is a lan 24/7/365
  24. #24
    Jan 2003
    Germany
    SuperPI is only 43s. I think that is the low fsb.
  25. #25
    Dec 2003
    At work
    Nice OC...lots of volts though.
    Server: HP Proliant ML370 G6, 2x Xeon X5690, 144GB ECC Registered, 8x OCZ Vertex 3 MAX IOPS 240GB on LSi 9265-8i (RAID 0), 12x Seagate Constellation ES.2 3TB SAS on LSi 9280-24i4e (RAID 6) and dual 1200W redundant power supplies.
    Gamer: Intel Core i7 6950X@4.2GHz, Rampage Edition 10, 128GB (8x16GB) Corsair Dominator Platinum 2800MHz, 2x NVidia Titan X (Pascal), Corsair H110i, Vengeance C70 w/Corsair AX1500i, Intel P3700 2TB (boot), Samsung SM961 1TB (Games), 2x Samsung PM1725 6.4TB (11.64TB usable) Windows Software RAID 0 (local storage).
    Beater: Xeon E5-1680 V3, NCase M1, ASRock X99-iTX/ac, 2x32GB Crucial 2400MHz RDIMMs, eVGA Titan X (Maxwell), Samsung 950 Pro 512GB, Corsair SF600, Asetek 92mm AIO water cooler.
    Server/workstation: 2x Xeon E5-2687W V2, Asus Z9PE-D8, 256GB 1866MHz Samsung LRDIMMs (8x32GB), eVGA Titan X (Maxwell), 2x Intel S3610 1.6TB SSD, Corsair AX1500i, Chenbro SR10769, Intel P3700 2TB.
    Thanks for the help (or lack thereof) in resolving my P3700 issue, FUGGER...
