i attempted to do the vmod by soldering a wire with a TEK SMC clip to the resistor and using a wire with a spade end placed under a mounting screw to ground it, but when turn on the power supply i only get the green Power light not the amber vdimm light, so i never turn it on because i figure something is shorting out. This is the smallest SM clip i've ever used and i don't know if smaller ones even exist, so is the clip just too big or does the vdimm light never come on after the mod is done? any suggestions? i don't have a solder station, so i don't think i can do the mod without using a clip.
