Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: MachII & Prescott advice
    Dec 2003
    I have a Mach II on the way this week and with Prescott around the corner I'm looking for some advice on the best Prescott chip to run with my current system.
    P4C800E-dlx (am going to do the Vdimm mod on it)
    OCZ Gold 4000 (cpu limits me to 260 1:1 so far)
    I reckon with more volts I could get the ram to 270 1:1, maybe.
    Assuming I can get a Prescott chip that flies (luck required as always) would I be better getting the 3.2 so I can run the mem 1:1 ie 265x16 would be nice or would the 2.8 with a higher fsb be better and run the mem at 5:4. Maybe even the 3.0 would be possible for 1:1 with 270! I really can't decide which would be better.
    Any suggestions anyone ? No cash left for anything else after Prescott & Prommy so what I have will have to do
    Gigabyte P55 UD5 | i5 750 @ 4.00GHZ | HD5850 | Corsair 650w
    Banned
    Nov 2003
    Ipswich, England
    you'll probably want to run a divider since you should do 5GHz easy by my reckoning. (32 stage pipe / 90nm)
    I say, go for the 3.2
    Xtreme Mentor
    Nov 2003
    New-Brunswick, Canada
    yup, im going for the 3.2P coze if it dont OC like they saying i steal have a good clock. but from what ive heard they should do very easy 280X15. But please dont cote me on this coze thats what ive heard, and it still make sens coze of 32 pipe stage and 90Nm
    Nov 2003
    Western Pa
    5000 Mhz easy?
    Has anybody overclocked a Prescott yet?
    Abit NF7-S V 2.0
    AMD XP 2500+ @ 2300+Mhz
    2x256 Twinmos (DC) BH-5
    WD 80 GB w/8MB Cache
    XFX Ti 4200-- 128MB
    Windows 2k Pro
    CPU watercooled by Flowmaster
    Dec 2003
    skate,
    I'm sure you meant 280x16 ?
    Dec 2003
    OC, California
    I thought there was a 3.4 Prescott coming as well. I know the 3.4P EE is delayed, but I haven't heard of the 3.4P being delayed.
    Custom Baker18 R22 cpu/gpu cooling
    3D01 41889 3D03 18256 3D05 8011
    Nov 2003
    Norway
    I've heard something about that the first prescott CPU's that come out, will not be good overclockers, and later they will be...is this true?
    Abit IC7-MAX3 Vdimm mod
    P4 3.0E
    OCZ 2X512MB PC4000 EL DDR Dual Channel Gold VX
    ASUS 9600XT 128MB
    All with stock cooling
    3DMark03: 4609p 3DMark2001: 15087p Super Pi: 35s
    Nov 2003
    its just assumption based on the northwoods.... (first ones were bollocks for overclocking and the later ones are sweet)
    Nov 2003
    Norway
    oh ok. I guess we whont know before the prescotts have been out for a while
    Im thinking of buying a Prescott myself, but not if they suck in overclocking. Overclocking is over half the fun!
    P4 3.0E
    ASUS 9600XT 128MB
    Dec 2003
    OC, California
    It's also strange for the EU to get them first. Maybe the first shipments went there..... and they are the bad ones.... no offense to the EU.. we'll all see...
    Nov 2003
    Norway
    Why is it so strange that we get them first? I feel that it's our turn now to get something before you guys
    P4 3.0E
    ASUS 9600XT 128MB
    Xtreme Mentor
    Nov 2003
    some are saying they will be some OC beast and other are saying they will S*CK for OC. Personally i think the Prescott will OC like beast, 90Nm and 32 stage pipes cant give poorer OC
    Xtreme X.I.P. Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    That is how it works with all hardware.
    As the process is refined they start pumping out higher quality silicon. Think of the first AXP processors, compared with the latest steppings. Or, the early 9800 Pros compared with the newer ones...not even close.
    System
    ASUS Z170-Pro
    Skylake i7-6700K @ 4600 Mhz
    MSI GTX 1070 Armor OC
    32 GB G.Skill Ripjaws V
    Samsung 850 EVO (2)
    EVGA SuperNOVA 650 G2
    Corsair Hydro H90
    NZXT S340
    Xtreme Legend
    Nov 2002
    Sweden
    There's also larger cache, which can make things worse...
    And if performance isn't at least on pair with Northwood, 5GHz is needed for sure...
    "In mild doses, ethylene produces states of euphoria, associated with stimulus
    to the pleasure centres of the human brain."
    Intel benching: 3DMark Vantage: E69642, P37253, H30363, X22138
    Swedish Overclocking Champion 2006 - Celeron Mobile 1400 @ 4243MHz - 203%
    Xtreme Legend
    Jun 2002
    Belgium / Denmark / Russia
    I very much doubt Prescott will OC any better than Northwood, especially at the start. There would be higher speed grades if they did OC so well. a 3.2 prescott will probably OC about the same as a 3.2 NW. We dont know how they react to more cooling and increased voltage yet of course. But for all we know, they could be worse than NW as well. 5 GHz in a Mach II isnt going to happen... Intel doesnt leave a 1 GHz aircooled OC margin on their CPUs
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    well said JC.
    Nov 2003
    happy place
    I disagree, for the reason of Prescott's redesign core which allows better clock distribution and longer pipeline. There are other improvements such as low-k silicon, and 7 layer copper interconnects. The only thing holding Prescott back is of course the world famous heat output. Something which can be corrected with proper cooling such as forementioned Mach II.
    --===== proud owner of new razor tarantula gaming keyboard =====--
  18. #18
    Xtreme Legend
    Jun 2002
    So you expect a 3.2 GHz chip to clock to 4.1 or 4.2 on aircooling then do you?
    Even with a mach II heat transfer is still a problem. More watts, smaller surface. The leak current on the 0.09 process is much higher than on .13 which will probably mean voltage increases give you mostly a heat increase rather than a good speed increase. I dont rule out that they OC a bit better than NWs but 5 GHz is plain silly. They wouldnt have had such a hard time reaching 3.2-3.4 GHz if they overclock so nicely. And they did have a hard time, tons of them went into lower speed bins already, and others got their cache disabled and waiting to be sold as celerons.
    If everything was so simple as you technically put it, AMD would be making 3 GHz chips already. Looks good on paper maybe, not so easy to make it actually work.
  19. #19
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    I think that we´ll se lots of dead Prommy cooled prescotts, in future. I lost yesterday heatspreader from my 3.2C proc. Chip looked to be just fine (even core was perfect), but it isnt working anymore
    If Intel doesnt attach those heatpreaders better in future, we´ll se some prescotts that are missing their core, because Intel is attaching heatspreader with silverepoxy directly on the core. When the "main" epoxy that is keeping heatspreaders on the place comes off ex. under prommy, all "force" (when removing evaporator or heatsink) is against that poor little core...
  20. #20
    Xtreme Mentor
    Nov 2003
    I dont think it will go over 4.5GHz but i think it will OC high.
  21. #21
    Xtreme Mentor
    Nov 2003
    In a article at VR-zone they say its way harder to remove the IHS(they have a Prescott in hand), so i think that problem is solve. And the IHS have a copper mark where the core is.
  22. #22
    Xtreme Legend
    Nov 2002
    Sweden
    Remember, all the things you list are just to be able to ramp up the speed. Increasing the lenght of the pipeline will decrease performance if the code is not optimized for it.
    The 1Mb L2 will make up for it to some extent...
  23. #23
    Xtreme Mentor
    Nov 2003
    I think we should wait to see what it gives
  24. #24
    Banned
    Jan 2004
    USA
    Only way to find out is to wait and see...
    If I were you I wouldnt consider getting a Prescott *yet*
    Keep in mind that the A64 FX-53 will be comming out as well.
    ATM AMD is the better alternative imho.
  25. #25
    Sep 2002
    will prescott chips runnable on i875/i865 socket 478 mobos?
    [size=0.5]| P4 NorthWood 3.0C @ 4350 Mhz (290 x 15) 1,872V Cooled by Ybris T-Rex @ 13,5V and Powered by TTGI 520W | Abit IC7 | 2*256 mb A-Data Winbond BH-5 Dual CH | Watercooled & Modded HIS 9700 "non Pro" @ 441/351 @ 1,95V/3,40V | Monitor 19" Tatung Vibrant | [size=0.5] | ICQ: [/size][size=0.5]174732553[/size][size=0.5] | [/size][size=0.5]**[/size][size=0.5] Diablo.II@email.it [/size][size=0.5]**[/size]
    3DMark Score:
    [/size][size=0.5]Class Ti4600 ( [/size][size=0.5]16606 pts. [/size][size=0.5])[/size][size=0.5] , [/size][size=0.5]Class Radeon 9700 ([/size][size=0.5]21505 pts. [/size][size=0.5])[/size]
