Results 1 to 13 of 13
Thread: nforce 2 board and 3 DIMMs
    Jun 2002
    Saskatoon, Saskatchewan
    Is it still possible to get dual channel with three sticks of memory? I just ordered an NF7-S, and I am planning on getting more RAM as well. I want a GB or more, and was wondering if I get an extra GB of RAM, if I can use all three slots and still get dual channel with 1GB on one channel, and 512MB on the other.
    AXP1700+ JIUHB 0302 @ 2400MHz - TEC-Watercooled in The Skyscraper
    ABIT NF7-S , Sapphire Radeon 9500 Pro, 1.5GB XMS3200C2
    XS IRC channel: irc.quakenet.net #xtremesystems
    www.ocfaq.com
    Jun 2002
    This technical document seems to say it does, can anyone confirm that?
    originally found at: http://www.nvidia.com/page/nf2_tech.html
    DualDDR combines the power of DDR333/DDR400 with two independent
    intelligent memory controllers. As stated previously, higher memory bandwidth yields
    higher system and graphics performance, resulting in more overall productivity, while
    intelligent arbitration and ordering logic ensures that data integrity is maintained.
    Both of the memory controllers on DualDDR are functionally identical with all
    control and timing parameters independently programmable. This flexibility allows
    the users to populate up to three asymmetric DIMMs in any organization, size and
    speed. DualDDR simply adjust to the lowest common density that will facilitate 128-
    bit bandwidth, allowing a wide variety of different DIMM combinations to operate
    reliably regardless of the individual density and latency characteristics. DualDDR also
    doubles the addressable memory space to 3GB. End-users now can populate higher
    density DIMMs, up to 1GB each, to utilize the entire 3GB memory address map.
    This large memory map allows more application and audio, video streams to coexist
    without conflicts. DualDDR also incorporates three memory address buses to reduce
    loading and to ensure all three DIMMs operate stably at very high data rates.
    www.ocfaq.com
    Chuck Norris Worshipper
    Dec 2002
    Stevens Point, Wisconsin
    wow, if that's true, thats really awesome. i always thought dual channel was just 2 or 4 dimms, not 3
    if dc works w/ all 3 dimms filled on the nf7, then im buying another stick or mushkin
    Jun 2002
    Tampa Fl
    I have 2x256 in the slots closest to the the cpu,
    and 1x512 in the other for 1 gig dual channel that works fine.
    But I think u must have equal amounts on each channel for it to work correctly.
    *edit* but after reading that it would seem to say differently*
    Also it has been suggested that using the same type ram is best.
    peace
    WannaGoafast
    P5K Deluxe - Bios 0404 - C2D Q6600G0 L723A930 SLACR - 3600MHz 400x9 1.45v - D-TEK FuZion CPU Waterblock
    2GB Team Group Xtreem DDR2 800 - 500MHz 5-5-5-15 2t 2.2v - EVGA 8800GTS - Swiftech MCW60 GPU Waterblock
    Laing DDC-2 w/Petra'sTech DDCT-01s Delrin Top - Swiftech MCR320-QP - Yate Loon D12SH-12 - Swiftech Res
    PC P&C Silencer 750 - 2XWD Raptor 36.7GB (RAID0) - 36.7 GB Raptor(SATA) - LiteOn LH-20A1H-186 DVDRW
    LIAN LI PC-G70B Black Aluminum Full Tower - 22" Samsung Syncmaster 226BW LCD - APC Back-UPS XS 1200
    Dec 2002
    hahaha...i just ordered a 3rd stick of 256mb mushkin black level 2 pc3500...768mb dual channel
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    I use to run 3 sticks of kingston 3500 in my 8RDA's for games, and it was still dual channel
    Jun 2002
    Thanks. I will soon have 1.5GB of RAM then .
    www.ocfaq.com
    Nov 2002
    Juneau Alaska
    wow, why so much ram?
    Xtremely Large Member
    Jul 2003
    Britland
    If the new HyperX I ordered plays fair with my OCZ, it's 2Gb for me soon.
    I've heard it all, I've seen it all, I've done it all. I just don't remember any of it.
    DFI LanParty UT NF3 | A-64 3200+ | 1Gb OCZ EL DDR PC-3500 Limited Edition
    Radeon X800XT | Audigy 2 | 2x WD 74Gb Raptors | 60Gb IBM | 20Gb Maxtor
    OCZ PowerStream 520w | Mach II GT Cooled
    Aug 2003
    Somewhere I Belong
    With three sticks of the same size (eg. 3x 256 ) ...only the first two sticks are in Dual channel....one remains in single channel.
    If you have 2x 256 & 1x 512, then everything will be in 128bit Dual channel mode.
    Jun 2002
    Yeah, I realize that.... but you still get a 128 bit wide interface to the RAM regardless, which is what I was told would not happen.
    As to why I need so much RAM... I see no point in having less than 1GB (and Desert Combat seems to load maps faster the more you have), and since I have another 512MB if I buy that, then I will have a total of 1.5GB.
    www.ocfaq.com
    Xtreme X.I.P.
    Nov 2002
    Shipai
    it works, but its harder to oc the more memory you have...
    got 1.25gb running in dual channel atm
    the max fsb with all this ram is around 10mhz lower than the max fsb with 256mb...
    c[_]
    Nov 2002
    Alberta, Canada
    I'd be running 1.25/1.5gb right now if I had another BH-5/6 stick...
    Just have a pair of BH-6's and a pair of Samsung TCC4's, though.
    All along the watchtower the watchmen watch the eternal return.
