Page 1 of 11 1234 ... LastLast
Results 1 to 25 of 252
Thread: So many A64 deaths
    Jan 2003
    So. Cal.
    So many A64 deaths
    Has anyone figured out what is killing all these A64's? Seems like I hear alot of people getting inexplicable failures on them - running them a day or two then losing them. Has anyone isolated some areas that seem suspicious.
    Thought I'd get a little feeback here before I put one together this week.
    Jan 2003
    Great and I just ordered mine yesterday
    - i7 5820K | Asus X99 Deluxe | 16GB Corsair Vengeance LPX | eVGA GTX 970 SC SLI | Asus PB278Q | 250GB Samsung 840 | 11TB HDD Storage | Steel Series Rival & QcK+ | Razer Orbweaver & Black Widow Ultimate '14 | Corsair RM1000W | Win 8.1 -
    - Ek Supremacy Nickel | Alphacool NexXxos UT60 360MM | Coolgate UHE 360MM | Bitspower Water Tank Z-Multi 150 | EK D5 CSQ Top | Alphacool VPP D5 | Corsair SP120 HP's | Corsair 900D | Xbox One & PS4 | Sharp Aquos Q 60" | Astro A50 -
    ~ Gone but never forgotten: Xtreme Legend - Hallowed Point - Enthusiast - Bencher - Friend ~
    Jun 2003
    The World
    Re: So many A64 deaths
    have you noticed most of these deaths are at extreme temps and high voltages?
    A64 3200+ Newcastle 2.2ghz
    Asus K8V SE Deluxe
    2x512 Mushkin BH5
    Tyan Tachyon G9800pro
    NEC 8x DVDRW
    Liteon 52x CDRW
    2x160gb Maxtor 7200
    Chaintech AV710
    Lian Li v1000
    Dec 2002
    Quite possibly to do with high RAM voltages as well as it kills the MMU on the A64...
    - LL V1000 - GA965P-DS3 - Intel C2D e6420 3.22GHz - 2GB OCZ 6400 Plat Rev 2 - GeForce 8800GT KO AC S1 - 500w Enermax Liberty -
    Oct 2002
    Talk to bowman about this - he's had some die at stock voltages too and fast. A weird phenomena for sure...and one that gets expensive.
    Xtreme Christmas Lighter
    Jun 2002
    Upstate NY, USA
    Jun 2002
    usa,va.
    I have lost 6 as of right now....some were high voltage,some stock,some extreeme cold,some not....but all were on my chaintech motherboard(except one that died from a known problem..power suppy blowing up)...and all die from the onchip mem controller dieing...
    the chaintech i was trying to figure out why it is killing them.the cpu and mem mod was off and stock voltage the last 2 that died.
    powersuppy on the last couple was running 3.33v 5.25v 12.24v so i know it wasnt that.and if the chips are going out because of a high 3.3 line then someone needs to fix something..because if i am not wrong...the spec motherboard and powersupply makers go by is 3.3v 5.0v 12.0v and thay all are allowed a 10% margin of differance...and that would =3.63v on the high side.
    then i relized the chaintech ..i had modded the chipset...the nf3 chipset was modded and set to 2.2v...this has to have a direct relation to the chips dieing...
    but i am not going to try my idea and remove the mod and then try another chip...not right now at least.
    i am whating on another 3400 to play on and thats it for a while...
    Xtreme Mentor
    Jun 2002
    6 = gotta be that board or more likely the chipset mod.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
    Dec 2003
    Louisiana
    Must be the board. That's just too many chips for them all to be defective.
    Bedroom: D201GLY2, Celeron 220 (1.2ghz/512k cache); 1gb DDR2 PC-5300; Geforce 6200 PCI
    Gaming: Core 2 Duo E4500@2.93ghz (266x11); Abit IP35-E; 3gb Crucial Ballistix PC5300@400mhz (4-4-4-15); XFX Geforce 8800GS@680/800 10123 3dmark06
    HTPC: Athlon 64 X2 BE-2300 (1.9ghz); ECS mATX mb; 2gb Crucial PC5300; Radeon HD2600 Pro 256mb (DXVA HA in BD and HD-DVD)
    Originally posted by Thunderbird1Ghz(Geforce4Ti4200) at Sharky Forums
    And you arent gonna believe this, but that DVD rom will even read regular CD roms!!!!!!!
    Dec 2003
    Cambridge, England
    so am i right to assume that it is the vDimm that is killing the A64s as a result of the onboard mem controler?
    thanks.
    - In Shadows Growing Wings -
    Mar 2003
    Columbus, Ohio
    Thats expensive man, like 6 X $400 at least $1200-$2400
    "...If you are not part of the solution, you are part of the precipitate..." Stephen Wright
    MSI-Neo2, Athlon64 3200+, 0447-SPAW2750mhz (10X275)@1.55V 38 degrees idle, 42degrees load
    LR Cascade, Mag 5, OCZ Powerstream 520W, BFG GeForce 6800GT OC, OCZ PC3200 Platinum Rev II 2X512mb 2.5,4,4, 6
    Setup
    Heatware
    Jun 2002
    Upstate NY, USA
    Xtreme Mentor
    Jun 2002
    thanks.
    I think Bowman was saying it may have been the "Chipset Mod" that was to blame. Not a vdim mod.
    Jun 2002
    usa,va.
    well i have posted in a few threads about mine....
    but i dont have time alot to check the threads at work.....i do have to work...not play all day...so i hope that wasnt directed to me...
    i ran accoss this one by accident....and i am still not sure on the death issue.....i have 3 boards so i am not going back to the chaintech until i get chaintech to take a look at it...i have emailed the company direct.
    all i know for sure it is the mem control going out..not the basic cpu.
    it starts with lots of windows errors and then it wont reload a fresh copy of windows.i pulled 2 chips from the chaintech after the first errors accured.and one just contunied to reboot....all the time..one the gigabyte it would almost make it to the desktop and then it rebooted...in the shuttle it just rebooted constantly...
    the other chip started just getting errors in my wndows until i rebooted it one more time..and then i got the black screen of a64death...
    so they are fun to play with...and yep i have depleted my funds...i got caught up in getting one to bench with,,and the mader i got the more determaned i got to get one going...and the more i purchaced....
    after my chips come in next week i want to weed out the weeker ones and keep one setup...sell off the rest at reduced price to get something back..
    and yes...the chipset voltage is the only thing the chaintech has that the shuttle and gigabyte dont/
    so i am leaning towards high chipset voltage doing it...since that is directly connected to the hypertransport..
    Xtreme Legend MrIcee's Avatar
    Jun 2002
    Cambridge, NY
    I'm on A64 # 5.
    As Bowman, mine have all died on an Nforce3 board, The Shuttle AN50R.
    I did run crazy high voltages to the memory on mine, for obvious reasons. I also run a high 3.3v line, many times in the 3.5v range.
    My assumption is I took out the memory controller. 1 of the 4 dead CPU's stopped my debug card at "detecting the memory". The last one lasted a day....not even pushed except with 3.5v+ to the memory, low multi high FSB under 2.2ghz. It ran fine that night, shut it off, next day no post. FF on the debug card...swapped the chip to an Abit KV8-Max 3...same thing...FF.
    I haven't pushed high Vcore thru mine..1.79v max at 2400Mhz.
    I have my latest residing on the KV8-Max3 for now, as I'm trying to see what kind of performance I can wring out of it, not many have messed with this board, and I've had it for months now. The Shuttle was too easy to push the FSB and fun...but at the expense of me killing CPU's. No doubt I'll prolly be working with that board soon again but with a little less volts
    Randi
    Member
    Dec 2002
    Leics UK
    Certainly a cause of some concern..
    Anybody else willing to admit to joining the 1337 band who have killed an A64?
    Jan 2003
    So. Cal.
    I was thinking that it might have something to do with the psu rails or chipset voltage. But obviously Mr. Icee hasn't done anything with the chipset.
    I've noticed that CCC is going strong with his 3400+ running 3.6vdimm and high FSB on An50r, but I think he's keeping his rails conservative. No need for increased 3.3v on that board. Maybe the 3400+ is just a little better chip, I don't know.
    One thing I haven't heard anyone talk about is the possibility of extreme cold killing these things. Don't know if that could have anything to do with it since most people on the forum are using phase change, period.
    How many people have lost this chip on stock cooling? And yes I'm surprised this issue hasn't surfaced as a thread already.
    3700+ San Diego @ 1.7v
    2x512 pc4000 Mushkin Redline @ 3.6v
    MSI k8n neo2
    x800xtpe
    Mach 2 cooled
    Superpi (1.4mod) --> 24.7 sec
    3DMark '01 ---> 37.8k on stock x800xt (526/573)
  18. #18
    Jun 2002
    Cambridge, NY
    Here's an addendum: the 1 A64 that I had great luck with and lasted the longest(1 month+) was an older CAAKC. The others died much faster and endured only a few hours of playtime before they would not post, those 3 were CAAMC, same as the one I recieved yesterday.
    Randi
  19. #19
    Member
    Dec 2002
    Leics UK
    Try and keep it till the weekend at least m8 :P
  20. #20
    Jun 2002
    usa,va.
    i have a running list of all my chips that i own and which ones died so far..i can post tonight if anyone wants to see...
  21. #21
    Xtreme Mentor
    Jun 2002
    Has anyone had this happen on a Via board?
  22. #22
    Xtreme Legend
    Jun 2003
    Portugal
    Originally posted by bowman1964
    it starts with lots of windows errors and then it wont reload a fresh copy of windows. one the gigabyte it would almost make it to the desktop and then it rebooted...
    I´m starting to have exactly the same problem. Have vcore and vdim mods done.
    Problem started when I tried to increase vdim from 3V up
    MOBO: K8N Pro
    CPU: A64 3000+
    I can only confirm tomorrow night if CPU is KO or not
  23. #23
    Jun 2002
    Ontario, Canada
    I hate to say it, but it's pretty obvious that these chips don't like high voltage like the Athlon XP did. So if you want to keep your chip and not hose your system, keep the voltages down.
    As quoted by LowRun......"So, we are one week past AMD's worst case scenario for BD's availability but they don't feel like communicating about the delay, I suppose AMD must be removed from the reliable sources list for AMD's products launch dates"
  24. #24
    Xtreme Legend
    May 2003
    Portugal
    i'v benched with mine 3200+ with +3.3v @ 3.8v and with v-dimm @ 3.5+- several times and it's all ok
    i'v tested with asus k8v and gigabyte k8n np
    i'm waiting for a 3.4+ let's see if it lives :S
    regards
    3dmark addict
    phase-change addict
    dirty benching addict
    tits lover
  25. #25
    Jan 2004
    Winnipeg, Canada
    Well, when I get my K8N Pro or AN50R I'm not going to volt mod it because I can't afford to buy even one extra cpu.
    Will the maximum voltages that are allowed in the K8N/AN50R bios not kill the cpu?
