Results 1 to 17 of 17
Thread: For all u fx 5800 users
Hybrid View
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    Ok, heres some of my work for you guys
    The Vcore mod is done using a 50kohm variable resistor set to 0 ohm. You increase the vcore by increasing the resistance. As you can see you connect the resistor pins to the black and white cable. There should be a 0 resistor there, you have to unsolder it
    The stock voltage is:
    1.1V in 2d
    1.35V on rev. M cards in 3d
    1.45V on rev. H cards in 3d
    The Vddr mod is something like a Vdd mod on a Radeon 8500/9xxx
    I used a 50kohm Variable resistor set to 50k, the second pin is connected to ground. You increase the voltage by decreasing resistance. The stock voltage is:
    2.5 to 2.55V on rev. H cards
    2.6 to 2.65V on rev. M cards
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    Oh i forgot. The green wire is the Vddr mod
    And now im attaching the bios file, with this bios you should do from 1100 to 1200 mem clocks
    Attached Files Attached Files
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    And heres part 2, its with the nvidia flasher already
    Jul 2003
    some idea where the points of measurement of the vcore and vmem are?
    tks
    Nº 01 ATI9700pro 2k3 (7129 marks)
    Copyman **Xtremesystems.org 3DTeam** G8NNXP watercooled a64 2524mhz 297mhz 2,5 4 4 8 11 16 \ watercooled 9700PRO 496\359mhz
    Nº 01 FX 5800\5800 ultra 2k1 (23113marks)
    Copyman **Xtremesystems.org 3DTeam** k8v dlx air cooled a64 2480mhz 248mhz 2225 11 16 \ air cooled fx5800 524\1080mhz
    Nº01 ATI9800np 2k1 (25960marks)
    Copyman **Xtremesystems.org 3DTeam** k8v dlx air cooled a64 2480mhz 248mhz 2225 11 16 \ air cooled 9800np 533\384mhz
    Nº 03 ATI9700pro 2k1 (24428marks) still Nº 01
    Copyman **Xtremesystems.org 3DTeam** G8NNXP watercooled a64 2500mhz 295mhz 2,5 4 4 8 11 16 \ watercooled 9700PRO 507\365mhz
    Nov 2003
    Sofia, Bulgaria
    The one I have here is rev. J
    ... any suggestions?
    hardwareBG Team Member
    www.hardwareBG.com - the Bulgarian Hardware Site
    Nov 2003
    Sofia, Bulgaria
    Bump
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    the rev. j looks the same as a h and m
    Nov 2003
    Sofia, Bulgaria
    And what about the stock voltages on Rev. J ?
    Can you tell me where the measure points are?
    Jan 2004
    Sweden
    Two questions:
    What voltage do I get on the core with the mod?
    I have a rev J by the way.
    Second, by changing the bios I can up my memory, but do you know if it's just worse timings or that you actually get higher voltage or something?
    Have you looked at your score at the same speeds using original bios and the ultra one?
    Jul 2003
    Denmark Frederikshavn
    Come on berkut We are wainting eagerly for this mod ! give us some reading points!
    -=Back In Business=-
    Jul 2003
    Arent there other ppl that would know how to mod this ?
    Jul 2003
    By berkut.....
    The capacitors on top right are for Vcore, on the bottom righ are for Vddr
    Im still working on the remaining Vmods
    too bad my old card is dead, it would OWN everything we've got (585/1170 clocks on a funny air cooler, no mods)
    now it is only try to reach me friends
    Jul 2003
    Damn berkut thats really bad ! how did it die ?
    Thx for your reply now Im only waiting for my mobo...then Ill mod my card!
    Nov 2003
    Denmark
    Nice
    I think i will try that mod on my TerraTec Mystify 5800 Ultra
    Now it*s go 500/1000@550/1240 and i hope maby with mod 600+/1300+
    Abit-IC7-G
    P4N-3Ghz@4.2Ghz-1.65V
    Adata-2*512@560mhz/1:1/2.5-3-3-5/2.8v
    POV.GF6800U@475/1300Mhz
    Maxtor SATA 2x80/7200/8/Raid0/Liteon DVDRW -/+
    SBLive 5.1 / Logitech z680 5.1 506W RMS
    2k5@6265 - 2k3@14696 - 2k1@28115 - Aq3@81081
    Nov 2003
    VIENNA
    holy §§§§ nice water cooling there.. selfmade? I would want some of those RAM coolers aswell
    Overclocking made in Austria
    Nov 2003
    Denmark
    Hey
    you can buy it here HERE
    there is for NV and ATI
    Abit-IC7-G
    Jul 2003
    Mine died last tuesday so Im outta the race :'(
