Results 1 to 9 of 9
Thread: AN7 bios
    Dec 2003
    State Of Snow
    AN7 bios
    anyone think they can make a bios for the AN7 that would help out all the crapass problems it seems to be havin??
    Fused
    Dec 2003
    Malaysia
    well i dono if it help.... but i hav AN7 modded bios with better sata function
    grab it here: AN7 + SATA 4227
    Oct 2003
    Sweden up north!
    tictac: Do you know if anyone has tested your modded AN7 turbo BIOS? I were just wondering if the extra vdd options worked. 2.1v vdd! That is some xtreme ยงยงยงยง by just modding the bios!
    | AN7 | Barton 2500+ @ 212x13 AQXEA 0330UMPW "Z" | R9600Pro FireBlade 400/300 @ 560/413 NO vmods! | Tyan G9800Pro 492+/390++ Still testing |
    | 24/7 | 230x10.5@1.82v and 1.75vdd | G9800Pro Tyan 470/380 For day to day use |
    Mar 2004
    Hello.....
    hope u can help me........
    i tried to download the bios from the link above...... but the link does not work.....
    is there any new modded bios for the abit AN7??
    please help!!
    Mar 2004
    tictac please answer this questions -> I'm also interested in this turbo bios. want to increase the VDD voltage without soldering.
    Fused
    Dec 2003
    Malaysia
    u got PM
    Apr 2004
    Indonesia
    Is extra vdd options worked ? is it nice FSB more than 220 ?
    Jun 2002
    Belgium
    tictac : can u get me the turbo bios for AN7 too, please?
    thnx!
    Abit AN7 - XP2500+ @ XP3200+ (oc'ing still has to begin hehe) - 2x512MB OCZ PC3200EL Platinum Edition - Sapphire Atlantis 9800Pro @ XT @ default speeds - NEC ND2510A DVD/RW - LG 16x/40x DVD/CD - 2x Hitachi 400GB SATA - 2x Maxtor 200GB SATA - 1x Maxtor 120GB SATA - 1x Maxtor 40GB PATA - 2x WD Raptor 74GB (raidO) SATA - 2x Promise SATA150 TX2 - 1x Promise Fasttrack SATA150 TX4
    What's your storage?
    Fused
    Dec 2003
    Malaysia
    ops sorry.. it is limited editon
    use this 1:
    Code:
    MODDED BIOS: N24AAC18.bin
    Explanation for the file name of the BIOS:
    "N"Force "2" Ultra "4"00 "A"N7 "A"BIT
    "C" (C in hex, which means the 12 month of the year) "18" (Date 18) ROMSIP date
    Important Notice : After you update the BIOS , be sure to load optimized default first ,
    save and exit to see if everything is working fine , after this
    procedure you can set other BIOS setting to the best configuration for
    your own system setup ...
    Disclaimer :
    This is a MODDED BIOS for the AN7 motherboard.
    Please use it at your own risk. ABIT is not responsible for any damage
    as a result of using this modded BIOS.
    12/18 BIOS update as follows :
    Change Log:
    1 . Changed the Optimal and Aggressive CPU Interface Table above 200 MHz FSB:
    - DISABLE CPU Interface has been modified to be more user-friendly
    for high FSB overclocking
    - ENABLE CPU Interface now recalls the lost bandwidth when FSB
    is above 200 MHz and at a multiplier that is under 10
    2 . No L12 Mod needed for 133MHz & 166MHz. All CPU will be running on 200MHz CPU Profile
    3. BPL Version:
    - Command Per Clock Enable : BPL version 3.02 (ABIT PCR)
    - Command Per Clock Disable: BPL Version 3.19 (DFI PCR)
    Download Link : N24AAC18-R2
    http://downloads.modlabs.net/bios/beta/N24AAC18-R2.zip
    http://downloads.modlabs.net/bios/be...C18-R2-CPC.zip
    or latest version
    Code:
    Disclaimer :
    Change Log:
    - Improve Stability and Overclocking
    1) AN7DE8 (Command Per Clock Enable)
    http://forum.abit-usa.com/attachment...&postid=365426
    2) DE8CPC2T (Command Per Clock Disable Bios)
    http://forum.abit-usa.com/attachment...&postid=371760
