I was looking at prices and noticed that opteron 140s are only $175. Im wondering if they are any good at gaming since they are architecturally the same as the athlon 64 fx i thought that maybe they would be decent at gaming.
wow... might have got really affordable for 20k+![]()
All along the watchtower the watchmen watch the eternal return.
As is see it the opteron 140 is just a 1.4ghz athlon fx. It could probably even be overclocked to around the speed of the fx 51.
If im wrong someone please say so.
well theres the chance you get an old stepping opteron that wont oc aboth 1.8ghz... and you would need a huge fsb to get to fx-51 speeds wich would mean a 66mhz pci ide card with a damn good nf3 board, IF the cpu ocs that high...
I know a guy thats sellling Opteron 140 systems overclocked to 1900Mhz+... heres a Link
Thats the highest he says it can run..
Running now, http://www.evga.com/forums/tm.aspx?m=693435
Intel 3960 @ 5Ghz
Asus Rampage IV Extreme
QuadFire 7970
X-Fi Sound Card
16GB G.Skill 2133Mhz DDR3 Quad Channel Ram 9,11,10 @ 1.65v.
3 Acer 23" 3D Ready LCDs
2x Ultra X4 1600 WATT P/S 's
MM Extension Ascention UFO Case W/ Top of the line Water cooling. Dream build!
So are opterons faster than athlon 64s clock for clock?
is the multi unlocked also on these?
I believe that multi's are locked on the Opteron's.... it's only the FX's that are unlocked..
That's y MM is using a 146 Opteron as it has the multi of 10....
'Turilli':
XP2500+ Barton AQXEA @ 2502MHz (227x11)
ABIT NF7-S Rev 2.0 Ultra 400
512MB CORSAIR XMS3500
Hercules Radeon 9800 Pro (Pelted )
200GB Hard Disc Space
Full Tower Chieftec 'Black Dragon'
Watercooled with DangerDen (At Last!)
it seems.... the guy thats selling the 140s oced to 1.9ghz says the fsb is running at ~220 fsb iirc , that would mean a multi of 8.5 or 9 and not the default 7x multi.
why not go with with the cheap A64 3000+
GF4 MX440 - <8,629> 3Dmark01
Radeon9500Pro -<16,871> 3Dmark01 | <39,167> AquaMark3
5900Ultra - <21,127> 3DMark01 | <57,320> AquaMark3 | <7,444> 3DMark03
Radeon9800Pro - <23,791> 3DMark01
P4 3C @ 3.9Ghz | 256MB XMS3200 x2 | P4C800-Deluxe |
2100+ @ 2.35Ghz | 512MB PC3200 | A7N8X-Deluxe |
www.Badasscomputer.com Folding since 7/20/03 (Not Folding = User Error)
512kb L2 cache :/ ~1500 less in 2k1!
A test over at AMDZone only showed a difference of 200 points in 3DMark2001SE when comparing the A64 3200+ and the A64 3000+ 512kb version
'Turilli':
AMDZone isnt on top of the orb, is it?
8-)
