Results 1 to 3 of 3
Thread: Need help with block design.
    Sep 2003
    Sweden
    Hi,
    I'm going to mill two blocks soon, one for Cpu and one for Gpu.
    Which dimensions should i go for? I'm thinking about 5x5cm for the Cpu block and 3,5x3,5cm for the Gpu block. Do you guys think its good enough?(Dumb question maybe )
    These images is from Askers evaporator design:
    Bottom:
    Middle:
    Top:
    That is the design im going to use for the evaporatorblock.
    Its going to be used o´for an AMD system and a R9800pro.[IMG]
    Jun 2002
    usa,va.
    well it is a nice design and should work well..i personally dont like twin flow paths,because i find the refrigerant will have a likely chance of going though one more than the other.path of lease resistance.thats why i always try and use a single channel path.this forces it though the way i want to to go.
    still you never know unless you build it.and i sometimes build things that shouldnt work,but they do.so go ahead and build it the way you have it,and test it and see how well it works.
    but it should do a good job
    Sep 2003
    Sweden
    Now it struck my mind, that i have to run the capillarytube inside the lowside(suctiontube or what you call it). Any ideas how to make that nicely?
