After several BIOS modify and timing fine tuning , finally break 4100MB/sec barrier ...
Configuration :
Barton 3200+ @ 266 * 10 @ 2.0V
ChipSet Voltage @ 1.7V
Memory Voltage @ 3.3V
AGP Voltage @ 1.5V
ATI R9800 PRO @ default clock
A-DATA Winbond BH5 Single Side 256MB * 2
DRAM Timing and Driving :
11-2-2-2-2-9-12-Enable-Enable-Fast
Auto-Auto-Auto-Auto-Auto-Auto
Note : CPU is watercooled and an extra FAN for PWM airflaw is a must because there is no CPU FAN air flaw to the PWM when you using Liquid Cooling or Vapor Phase Change Cooling
Here is the picture ...
Just FYI ~~~
