Well this is all I can squeeze out of this combination...
vcore=1.95, vdimm=3.3, vdd=1.9, agp=1.7
timings= 11-2-2-2-2-9-12, enabled, enabled, fast
cpu interface=aggressive
Sorry for the large images....
I am very happy with this set up!!!
[+] Abit AN8 Fatal1ty [+] A64 3500+ NC [+] XP120 [+] 2x256 G.Skill DDR600 "LA" [+] MSI 6600GT [+] OCZ 420w Powerstream [+]
really a good achievement m8! Just a couple of questions:
1) Is vdd 1.9v stable? I noticed on my board that going over 1.7v makes things act worse.
2) Is your ram single or double sided?
3) Does ddr slot3 (the one on the right side of the mobo) overclock less than slot 1&2?
Thanx....Originally posted by Iolao
1) It seems to need all the vdd
2) Double sided (I think) it is OCZ PC3200 rev2, bought Jan03
3) Not sure... I did all this dual channel slots 2 & 3
Have you some sort of cooling on the mosfets? If you have spare time can you test a single stick in all three slots?Originally posted by clockedOut
Thanx....
Stock cooling on the mobo.
I did try single stick with my locked Barton... but it didnt make any difference... I was maxed out on the CPU at 225x11.
I will try moving single sticks around later.
Very nice, and certainly very intriguing as we've seen such mixed results from this board and the LPB.
Was 250fsb prime stable ? Where did you get the board as Im looking for a replacement for my 8rda+ and the abit boards dont seem to be doing so well right now.
Wow not too bad!
CPU - Intel i7 2700K @ 5.2Ghz (1.38v)
Cooling - Corsair H100i With 4 X 120MM OEM Corsair Fans
System Board - Asus P8Z68-V Pro
Memory - G.Skill RipJaws-Z 2X8GB DDR3 2133Mhz @ 9-10-10-28 1T
SSD1 - 240Gb Samsung 840 Pro
SSD2 - 128GB OCZ Vertex 3
HDD1 - 1TB WD Black
HDD2 - 2TB WD Green
DVD - Liteon 22X DVD R/RW
GPU1 - EVGA 670 GTX FTW 2GB
PSU - 750W XFX XXX Edition
Case - Silverstone Raven-02 Case
Monitors - 3X Asus VX238H's and HANNS-G 28"
GRRRRR hurry up excaliber!! I WANT MY INFINITY!!
Dell Studio XPS16... no desktop![]()
yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
No, 250x10 is NOT Prime stable.... I have to back off to 245x10 to get Prime stable at same volts.
I bought it from NewEgg 2 weeks ago.
very nice clockedout excellent job Im gonna be ordering one of these board sometime this week for me and a friend.
Coming Soon!!!!
Very nice
This will be my next mobo for sure
Updating...
I like this mobo!!!
I still think it has voltage regulation issues.
And I wish it would let me use vcore past 1.95 or didnt undervolt.
If I could combine the stability of my Soltek 75FRN2-L with the votage options of this Infinity... it would be the perfect clocker for me.![]()
It sounds like anice board but no way no how can I live with 1.95 Vcore. I just couldn't do it. Even 2v even is no good for me. I want and need at least 2.1 v
No one has tried a vcore mod for this board?
Does it use the HIP6301 or what?
I am able to bench with 255x10. But I wish I could use these setting 24/7
IMO I need more vdimm... mod anywhere?
Then I am gonna cool my tinies (mosfets) down so that I am able to use more than 1,85VCore w/out reboots...
My cpu could do 242x11,5 stably and I am convinced it still can do it with enough voltage...![]()
I put a New UN-locked 2500+ in the Infinity last night and put active cooling on the NB & SB.
Its at home Priming at 245x9.5 to get it warmed up for some testing tonight.
HI
HOw about the 10 - 10.5 multipliers ?
They are functional, right ?
E8200@3.4ghz
8x427
MSI 7345
OCZ Plat DDR2 800
8800 GT
Vista Home Premium 64
Sure... why wouldnt they be??
Hi
Because they arent for those of us with NF7-S's.
I may order one.
Would a Northpole or Swiftech cooler be advisiable for the nb ?
I have Buffalo pc3700 BH5's...and want to really push the fsb.
E8200@3.4ghz
8x427
MSI 7345
OCZ Plat DDR2 800
8800 GT
I put a Vantec Iceburg on the NB & the SB.
Hi
Thats what I have on this Abit. I can just move it over.
The Infinity should be here on Tuesday
E8200@3.4ghz
8x427
MSI 7345
OCZ Plat DDR2 800
8800 GT
So far it feels alittle more stable... but I have not really tested all the new changes yet.
why is it limited to 1.95v
is it a bios issue or vcore regulation/overvolt protection?
it's never fast enough!
