Results 1 to 21 of 21
Thread: refrigerants just curious what makes one better than another
    Oct 2003
    USA /okla
    R503: blend
    CFC-503, a blend refrigerant of HFC-23 and CFC-13, used in Iow tempreture frosting unit.
    Typical Properties:
    Formula: CHF3/CCIF3
    Boiling Point (101.3KPa, ~C): -87.8
    Freezing Point (~C): --
    Critical Temperature (~C): 19.4
    Critical Pressure (KPa): 4357.5
    Liquid Density (kg/m3): 1233
    CDP Value: 0.6
    GWP Value: 13.85
    R-500: blend
    R-500 is a blend refrigerant of CFC12 and HFC 152a. It has higher pressure than CFC12, therefore under the same compressor's capacity, it's more efficient.
    Typical Properties:
    Formula: CCl2F2/CH3CHF2
    Boiling Point (101.3KPa, ~C): 99.3
    Freezing Point (~C): -159.8
    Critical Temperature (~C): 105.6
    Critical Pressure (KPa): 4426.5
    Liquid Density (kg/m3): 1138.9
    ODP: 0.7
    GWP: 2.1-2.5
    R-404A: blend
    R-404A is a blend refrigerant of HFC125, HFC-134a and HFC-143. AlliedSigal Inc.'s patent number is AZ-50. It is a long life substitute of R502, harmless to Ozone. It is mainly used in Iow and middle central commercial air re-frigeration system.
    Typical Properties:
    Formula: OH F2CF3/CF3OH2F/OH3CF3
    Boiling Point (101.3KPa, ~C): -46.1
    Critical Temperature (~C): 72.4
    Critical Pressure (KPa): 3688.7
    Liquid Density (kg/m3): 1017.2
    ODP: 0
    GWP: 0.35
    Info found at this link http://www.favorcool.com/refirgerant.htm
    What makes one better or worse than the other?? Price, avail, danger levels, usability, boiling points??
    thanks for your input
    i7 6700K @4.8 ghz
    XSPC RayStorm (very nice block)
    Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
    XFX-7970 with Swiftech Komodo nickel block
    Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
    Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
    Crossfire 30" decent monitor for IPS too bad SED tech died
    Docsis2.0 Docsis3.0
    -- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
    Oct 2003
    USA /okla
    cool deal
    thanks
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    1kg of R23 costs 30$
    Jun 2002
    Winchester, UK
    hmm freons
    Oct 2003
    USA /okla
    i thought the word Freon was a no no
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
    Jun 2002
    Winchester, UK
    yeah it is, think MM just got a little bit crazy there with his F R E O N key's
    He has seen the light now though...
    Oct 2003
    USA /okla
    BLAHHHH
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
    Oct 2003
    The Netherlands
    'freon' is a DuPont trade name (not sure if it is for the entire CFC/HFC/HCFC range or only for R12). Just like 'walkman' is Sony's. That's why one should not use the term freon, unless you mean the specific DuPont refrigerant.
    Now, what makes one better then the other? That depends entirely on the conditions. Some refrigerants work better in a high temp application, some work better in a low temp application. Some work fine with high condensing temperatures, some do not. Some are cheap, some are expensive. Some are banned, some are not. And many more factors determine the choice of the refrigerant.
    Usually one would determine the entire operating range of the device, and then select a refrigerant which provides the best fit. Refrigerators work with R134a, while an airconditioning unit works with R22, R407C or R410A for about the same evaporating temperature. Clearly those refrigerants have advantages in such a higher-capacity system over R134a (lower required compressor displacement -> cheaper compressor).
    Chip-con (oh sorry, nVENTIV) chose R134a for cheapness (of the refrigerant, the compressor and probably the testing too), I suppose. R404a and an R404a compressor would have been a better choice, but more expensive. It's a valid choice for the refrigerant to use, but not technically the best.
    Oct 2003
    USA /okla
    interesting
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
    X.I.P.
    Jul 2003
    Darby FL, USA
    Dupont called R12, R22, and R502 "Freon". They call their newer refrigerants "Suva". Other manufacturers have other brand names for these same products. The terms are sufficiently vague to be meaningless. The "R" designations are official, specific, and meaningful.
    Beyond this, it is widely understood throughout the refrigeration industry that if someone says, "It needs a little freon", that person is essentially clueless.
    Author - Refrigeration Trouble Shooting Books
    Want to learn more? Click Here
    Oct 2003
    USA /okla
    the R500 has a very low boiling point
    pros and cons ??
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
    Oct 2003
    The Netherlands
    Oh? According to my pt calculator R500 has a boiling point of -33.5C at atmospheric pressure. At 32C SCT it's saturated pressure is a moderate 9.27 bara.
    Thus, the cons: it's unavailable, it's physical properties are not that special, and neither are it's thermodynamic properties.
    The pros: if you happen to have a bottle in the garage, it's free.
    Oct 2003
    USA /okla
    why would it be listed as such ?? -33.5 seems alot higher than -99.3
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
    Oct 2003
    The Netherlands
    Sounds like an error to me. Based on the partial pressures of the R500 components I am pretty sure that -99.3C is not the correct value
    Oct 2003
    USA /okla
    so in your opinions what would be the best all around refrig to use ??? in a 1/3 hp R-12 tecumseh compressor?
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
    Sep 2003
    NY
    can a vapo pe be modded w/ r507 or would it cause too many problems?
    Xtreme Mentor
    Nov 2002
    Delaware USA
    r404 is $220 and r507 $280 "20-30lb cans
    Would r12 work in my Vapo PE, I've got 3 1 LB cans here. I've been holding onto them if my AC in my mustang ever needs a charge.
    looking at the chart, It wouldnt get much colder.
    Dont even ask where i've been!!!
  18. #18
    Dec 2002
    USA, FL
    it wouldn't be worth it since Vapo has ester oil in it so u would have to drain it then fill it w/ mineral oil to use R12 u would only get like 5C colder
  19. #19
    Oct 2003
    The Netherlands
    So far R507 performs the best. But that requires an oil change.
  20. #20
    Dec 2002
    USA, FL
    does R507 run at a higher head psi then R12
  21. #21
    Oct 2003
    The Netherlands
    Yes, it does. Head pressures are double the R12 head pressures
