This is really starting to push the envelope.
Ok, my goal has always been to double the FSB of a tbred. And I have done it.266FSB, CPU Interface Enabled, memory running in sync at 2-2-2-11. Just thought I'd share.
The screenshot (linking instead of embedding, because of some low-resolution whiners last time; be warned, it's 2048x1536)
As you can see in the top right corner, my voltages are ROCK SOLID (the ones pictures are Vdimm, at 3.55v, and 3.3v, at 3.7v). I think this is very important to overclocking success - think of it as the gas you put in your car. You wouldn't go into a race with sub-par gas!
My VDD is at 2.15v here, although I don't think it did much. The strangest thing about this motherboard is that it doesn't seem to max out. I can keep adding vdimm and she will keep giving more headroom. I don't know if I got a magic NB or what, but once I get my hands on some cheaper/throwaway BH-5, I will be pumping some serious volts through it (I'm thinking, around 4v) and I will find the limit of this board.
Interesting stuff. And I do believe this puts me as #1 AMD FSB in the world (except for the A64's).
Not done yet,
Mike
NF7-S rev 2.
Abit/nVidia should get their act in gear.
