Page 1 of 3 123 LastLast
Results 1 to 25 of 55
Thread: Wow, 290FSB 1:1 on Albatron KT800 fastest timings
    Moderator
    Jun 2002
    Looks like high FSB, lower multiplier 1:1 is the way to go with the Albatron, if my Radeon can take the bus. On the S3 virge, 290FSB 1:1 at tightest timings
    The sisoft's ran on a corrupt OS so dunno how the scores get affected, but 3000+ looks good for a 1Ghz CPU.
    Still on good old HyperX 3500 but on 3.54 Vdimm. Gonna try using higher Vdimm in a bit
    Jun 2002
    Belgium
    nice ram :thumbsup:
    24 core Xeon:
    2x Intel Xeon Q3QS 'ES' @ 4.1GHz (folding@3.8GHz) - (flakey) EVGA SR-2 - 2x Antec Kühler 620 - 6x 4GB Corsair Vengeance 1600MHz CL8 - MSI GTX580 Twin Frozr II/OC - Thermalright Shaman - 2x Intel X25-M 80GB RAID0 - Silverstone Strider 1200W Gold - Lian Li PC-P80
    Dec 2002
    Rome - Italy
    290fsb 1:1 cas2 522???
    awful!
    your memories're extraterrestrial....
    great result
    Moderator
    Jun 2002
    10 X 280 FSB is very possible if I have a Prometeia to use on the CPU! God, dry ice is tempting me again!!!
    Aug 2002
    London,Uk
    is that kingston hyperx cas 2,2,2 rated stuff, i assume it is. But you mighta got lucky with a diff rated stick. I'm thinking bout buying a gig of it, jsut not sure if its teh best way to go for ath 64 or not, looks like it might be
    You know what chips are underneath the spreaders, a p4 mobo listed kingston hyper x pc3500 in the compatibility list, and seemed to show it having bh-5 chips on. If thats likely, i'll deffo buy it. Though i've seen some kingmax pc3500 that states cas 2/2.5, much cheaper than most i've seen. the red pcb stuff, ever heard, seen it, i can't find a review.
    Does that alby have a 1/8 divider at all, not sure? lets hope so anyway. 1:1 at 280 would be completely sweet.
    Mail Me | 3500+ , dfi sli-dr, g-skill la, 2x6800gt, 600w pcz, stacker case, air cooled
    Xtreme Legend MrIcee's Avatar
    Jun 2002
    Cambridge, NY
    This is great news, and also a great job my friend
    I've got 2 sticks of HyperX PC3500 BH5 that love high voltage and high FSB......can't wait to play with A64
    Randi
    Jun 2002
    That's radical man... I wonder what higher cpu speeds would do.
    Holy Sheet 3.54v on the ram!
    They will fall at his feet....... But eBay @ZZHOLE still ripped me off!
    Aug 2002
    London,Uk
    sweet, ,methinks i'll defo order some nice pc3500 then.
    Mr ice, how high will yours go, fsb/timings/voltage wise, what kinda stick, 512/256.
    lardarse, what kinda speeds will that ram do at 3-3.2v?
    Xtreme Legend
    Jun 2002
    Belgium / Denmark / Russia
    something isnt quite right there... first off 290 2-2-2-5... sorry but i really dont think thats possible not with any existing chips... and secondly I know the CPU speed is only 1,1 GHz but 3,2 GB/s in sandra?? That seems really low to me... i think Albatron is using slow ass settings like they did on the springdale...even 360 FSB was slow as hell lol
    Why the 4x multi? run it a bit higher so you are around 2 GHz at least and then show us some performance at 280
    Sep 2002
    Nova Scotia, Canada
    ^^^ agreed kinda get the cpu speed up some then give us some more benchies.... the speed should increase as the cpu catches up ... i think ...
    AMD Athlon XP 1700+ JIUHB 0302
    512mb DDR PC3200
    Abit KX7-333 Fully Vmodded
    ATI Radeon 9500np Softmodded -> 9700
    3dMark 2k3
    3dMark 2k1
    Xtreme Recruit
    Jul 2002
    Stockholm, Sweden
    Have to agree with JC, 3269/3233MB/s is awefully low for 290MHz with Cas2.
    Just as a compare MJ is getting 3500/3490 with memory at 227MHz with Cas2.
    CPU: AMD Athlon XP 2500+ @ 2850MHz
    Motherboard: ABIT NF7-S v2 nForce 2 Ultra 400 @ 228MHz FSB
    Video Card: ATi Radeon 9700 PRO @ 400Mhz core / 710MHz Memory
    RAM: Corsair 2x256MB TwinX 3200 LL @ 228MHz CAS 2-2-2-11
    Media: 120GB Matrox DiamondMax 8MB cache, Seagate Barracuda IV 80GB & 40GB
    Cooling: nVENTIV Mach I ( CPU ), Watercooling ( GPU & NB )
    Mouse and KB: Logitech MX700 & Logitech Cordless Keyboard
    Case: Coolermaster ATC-220C, Enhance 460WPSU
    Moderator
    Jun 2002
    ok, i'll do a 280 with a higher multi in a bit. It could also be due to a corrupt OS, but a reformat would take quite some time. Anyhows, I'll be back with some results.
    Moderator
    Jun 2002
    Well this is just posting so you guys don't think I've gone off proposing to my GF or something
    The board, went tits up on me.... I originally wanted to go straight to insulating the board then putting it on the chiller but you guys wanted some higher multi bench so I put it back on the default aircooling put voltage to 1.9v and started to find the CPU speed limit on aircool first. After just a short while, it turned off by itself and I felt the HS, was really really hot. NVM I thought, the over temperature protection should have handled it.
    Turned the PC back on and the fans spin for 1/4 of a second then stopped. Now thats all it does, with the CPU on it it will just turn on for less than a second then stop. If I remove the CPU it will run fine. If I put in the CPU and unplug the 12v line it will run fine. I'm starting to think my power supply is doing things. The MSI board "died" with this same syndrome. Now I'm waiting for a replacement, but I'm thinking of quickly ordering one online from the nearest retailer if possible. This board shows great promise thus far though I've not really tested the performance yet.
    I believe that even if the board is a little bit slower compared to competition, I don't think it will be greater than a 5Mhz FSB speed difference. And put it into equation, thats still 270+ 1:1. The greatest draw for me about this board is the ability to go real high on Vdimm as its derived from 5V.
    I wish I could rush out to buy another Albatron right now, the high 1:1 achievable from partly the good ram and high Vdimm allowed.got me hooked!
    The CPU is still alive though.
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    LardArse sorry to hear that about your board.
    I take it you liked the Albatron ?? I havn't tried lowering my multi and playing with the memory cause I aint go no memory that will run 1:1 ! hehe
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Xtreme X.I.P.
    Nov 2002
    Shipai
    290 2-2-2
    Moderator
    Jun 2002
    Ok, I've not received the replacement yet, but with a new bios to set to 280 FSB, I'm testing out the Shuttle NF3 right now. Here's 280 1:1 fastest timings available with just 2380Mhz CPU, 3.6 Vdimm.
    I think I can do some more FSB as 4v vdimm seems to run well, but I'm getting too chicken §§§§ to run it that high without need to. Too bad the Clock gen doesnt work with this.
    /dev/zero
    Nov 2002
    Germany, Berlin
    Too bad the nf2 does not handle such high voltage/fsb at all... My twinmos are pretty good as well
    Good luck on 3d
    @MickeyMouse
    I think he's running an s3 virge slowmo vidcard
    Xtremesystems.org
    i7-4820K * ryba 2-stager + 1-stager * EVGA X79 Dark * 32G Team Xtreem 2666C11 * EVGA GTX 680 SC Sig. * Intel G2 80G * Corsair HX1000 * Lian Li PC-70B * Watercool Heatkiller, EK Fullcover/Backplate for GTX, MCP355 Dual Setup@Koolance RP-402X2, PA120.3+Alphacool 360, Tubing 16/10.
  18. #18
    Banned
    Oct 2003
    Im having a slight bit of trouble believing him as well...
  19. #19
    Dec 2002
    Jersey City, NJ USA
    holy crap! This is definately good news!
    Do you have a good VC that will post some good 3DM scores? Sure hope so.
    I also cannot believe those hyperx's.
    WTG!
    | MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
    HeatWare
  20. #20
    I am Xtreme
    Aug 2003
    Best ram I've ever seen. But isint almost 3.6V killing it?
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
  21. #21
    XS - Extra Strong
    Aug 2003
    Toronto, Canada
    Son of a ..man. Thats just insane....
    That mem score is quite low though.... also, hate to rain on your parade, but will it pass memtest86 with those settings? :P
    -Phenom2 x6 1055 @stock
    -8gb ddr3
    -Gigabyte UD3
    -Geforce 7900Gt 755/1863 1.562v vgpu
    -OCZ Powersupply 600w
  22. #22
    c[_]
    Nov 2002
    Alberta, Canada
    4.1v took out ram on a 9800 in 24 hours (who was that? I forget..), so I would expect 3.5v ish to be runable 24/7....? 8-)
    EDIT
    Dont forget macci ran 3.6v into his ram for 270 2-2-2.
    All along the watchtower the watchmen watch the eternal return.
  23. #23
    Champion
    Jun 2003
    cape town
    LardArse - please tell me how you get those lower multipliers. does it happen in the bios or are you using clockgen?
  24. #24
    Aug 2002
    Melbourne Aus
    lol good word lardarse, hipro would be proud of ur vdimm!..
  25. #25
    Moderator
    Jun 2002
    Ok, just fixed up the Radeon 9800 P onto it, benched this on an untweaked OS, default Video speed first. This is at 280 x 8.5, 1:1 cas 2.0, 2, 2, 13. 3.64Vdimm <-- best spot yet, 3.7+v works good for a while only, 3.8v is worse. Only 1 stick of 256Mb ram now. LDT at 2X.
    http://service.futuremark.com/compare?2k1=7163022
    It seems though that I might have to lower my 1:1 FSB under high vcore/speed, still testing and waiting for the chiller to go down.
    flytek, I used clockgen, works great, just that my FSB can't use it as my clockgen is different on the Shuttle.
    Tell me guys, cats 3.6 and DX9.0b, good combi for 2001 bench? I don't have Win 2k here.
