Results 1 to 20 of 20
Thread: Mushkin PC3500 Level II BH-5 performance...?
    Oct 2003
    Scotland
    Question Mushkin PC3500 Level II BH-5 performance...?
    Hello people i'm new to the forums, having been recommended here by Drozdov over at Extreme Overclocking forums, so nice to meet you all and I look forward to picking your collective brains
    My question is, i'm getting some PC3500 Mushkin Level II w. BH-5's and I hear they are supposed to be good overclockers.
    So anyone have or used these Mushkin sticks and what can I expect out of them? What have you had ort seen out of them? They don't arrive for a few days so i'm just getting an idea of what to expect on my ABIT NF7-S v2.0.
    Cheers!
    Xtremely Large Member
    Jul 2003
    Britland
    I'm obviously running OCZ, so I can't speak from experience, but from what I have seen I reckon you could be looking at about 230MHz on an unmodded board, and with a modded board, most likely higher.
    Although it does kind of depend on your board, some will run with high FSB's, some won't, but with the Mushkin BH-5, you should be able to max out the board no problem.
    I've heard it all, I've seen it all, I've done it all. I just don't remember any of it.
    DFI LanParty UT NF3 | A-64 3200+ | 1Gb OCZ EL DDR PC-3500 Limited Edition
    Radeon X800XT | Audigy 2 | 2x WD 74Gb Raptors | 60Gb IBM | 20Gb Maxtor
    OCZ PowerStream 520w | Mach II GT Cooled
    Jul 2003
    Britland
    I thought you might make an appearance Jason.
    Oct 2003
    Scotland
    Heh, so I take it it will be very nice then.
    I've just managed to get hold of another 1800+ DLT3C too so I'll be testing that to see if it can outperform my current one which seems stuck at 11*200.
    Seems strange though, my CPU will do 11*200 @ 1.65v no problems, but when I raise the multi even a notch it randomly reboots or shuts down with a siren no matter what voltage I stick into it.
    Is that me hitting the limit of my CPU or is it the result of something else?
    My PSU is a meaty one, and I have an SK-7, although the fan on it is quite a weak 30CFM one that is due to be replaced.
    Any ideas what it could be? My mobo?
    Oct 2003
    Scotland
    Anyone?
    Member
    Dec 2002
    Leics UK
    Maybee L12 mod will help with the FSB.
    Id expect mushkin BH5 to be osme of the very best you can buy.
    Mixing memory sticks/types may be a bad idea (looking at your sig) Try the mushkin on its own.
    Banned
    Oct 2003
    is that with volt mods jason?
    Apr 2003
    Orlando, FL
    Is it just when you change the multiplier or voltage also?
    Calcu
    New PC just built, specs coming
    Xtreme Enthusiast Nebulous's Avatar
    Mar 2003
    New York State
    Dang MM, that's 1 stick? I can imagine dual channel
    <MEGA-O>
    ASRock Z97 Extreme 6 /i7 4790K De-Lid @ 4.7GHz
    GSKILL Ripjaws X F3-2400C11D-16GXM 16GB (2x8GB)
    H2O = XSPC RayStorm / Coolgate CG480 / Lowara D5 / XSPC Dual Bay Res V1
    Liteon SSD SCS-256L9S 256GB / Toshiba Red 2TB / WD VelociRaptor 300GB
    Zotac GTX 1070 AMP! Extreme @ 2100 /4500
    SilverStone Zeus SST-ZM1350 1350w
    Phanteks Enthoo Primo / Win10 Pro x64
    ** Under TITLE II, SECTION 210.340 it is legal to overclock **
    Oct 2003
    Scotland
    Calcu
    A bit of both really, but the multiplier seems to be the main culprit. Too much voltage and the siren goes off, but i'm usually OK up to 1.85v. Problem is 1.85v doesnt seem to be enough for any multiplier above 11x
    I have another 1800+ DLT3C coming soon so i'll test my current one and the new one with the Mushkin Level II i'm getting and see if it makes a difference.
    I'm using BIOS 1.8 if that makes a difference. Strange, I never imagined the NF7-S 2.0 would have quite so many glitches
    /dev/zero
    Nov 2002
    Germany, Berlin
    Originally posted by MickeyMouse
    no rams doing 260 1:1 @2-2-2-6 on an AMD mobo wihtout a voltage mod to the ram
    That's sarcastic if the anyone didn't notice
    I think he's using 3,18V or so...
    Xtremesystems.org
    i7-4820K * ryba 2-stager + 1-stager * EVGA X79 Dark * 32G Team Xtreem 2666C11 * EVGA GTX 680 SC Sig. * Intel G2 80G * Corsair HX1000 * Lian Li PC-70B * Watercool Heatkiller, EK Fullcover/Backplate for GTX, MCP355 Dual Setup@Koolance RP-402X2, PA120.3+Alphacool 360, Tubing 16/10.
    Oct 2003
    Scotland
    Just received the new CPU from the postie and the stepping is...
    AXDA1800DLT3C 9885366270121 JIUHB0321XPMW
    Interestingly, AMD CPU decoder says my new CPU is downgraded from a 2700+, whereas my old CPU was supposedly downgraded from a 2500+
    Previous CPU stepping:
    AXDA 1800DLT3C 9567346250245 JIUHB 0320UPMW
    Whether this makes a difference is yet to be seen...
    I am Xtreme
    Feb 2003
    Netherlands
    Muskin level2 PC3500 has handpicked BH-5 chips...i can only imagine what it will do with some voltage up it's ass!
    My cheapass TwinMos BH-5 is doing 242 11-2-2-2.0 with 3.2V and i think it will do even higher, the mobo just won't let me.
    BH-5 is still the best for Nforce 2 boards asking me.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Jun 2003
    Maryland
    *JAWDROPS*
    what vdimm is that at? were did you get your ram. looks like ill be getting some mushkin LII if my friend doesnt get any free ram for me
    Jun 2003
    Ohio
    MM, you're always pimping out the mushkin aren't you?
    It's alright, I would too, that is if my memory o/ced for crap.
    Jun 2003
    Maryland
    what did it do at 2.9? sry for all the q's...just im thinking about getting this. i doubt ill do a vdimm modd considering my skills and luck. i think ill settle for 240ish
    Jun 2003
    Maryland
    nother question ...
    is it worth the extra 40 or so bucks for the mushkin instead of hyper x? afaik the only difference is brand and that the chips are hand picked w/ mushkin
  18. #18
    Jun 2003
    Maryland
    k...thanks for all your help though.
  19. #19
    I am Xtreme
    Feb 2003
    Netherlands
    Originally posted by corbec
    nother question ...
    I guess these chips weren't handpicked for nothing....Mushkin took only the very best BH-5 chips, if you're planning to OC the hell out of your system it could be worth the money.
  20. #20
    Jun 2003
    Maryland
    before i do anything, im waiting till after comdex...how much longer will bh5 ram be around?
