I figured I'd pass on a little info on the 9800XT Vdd mod. The 9800XT uses the same ISL6522 controller as the 9800pro. Resistor values have changed however. The FB input is pin 5 and ground is pin 7. If the resistance from pin 5 to ground is R2 and the resistance from the Vdd output to pin 5 is R3, we get Vdd=.8x(1+R3/R2). R3 has a code of 13B, which is 1330 ohms. R2 has a code of 73A, which is 562 ohms. This gives a default Vdd of 2.69V. I measured 2.68V. The ram is spec'd at 2.80V+/-.15. Notice that the default voltage is actually below the 2.80V nominal voltage spec for the ram. Connecting a 10k pot from pin 5 to ground gives us:
Rpot/Vdd
9.8k/2.80V
5.0K/2.90V
4.0k/2.96V
3.5k/3.00V
3.0k/3.05V
2.5k/3.12V
Vdd is generated from the standard motherboard 3.3V supply, so I suspect it would be difficult to fry the ram (Vdd max should be less than the 3.3V supply), but I'd still be careful.
In the picture the yellow/black pair is for Vdd monitoring and the red/black pair is where I attach the pot. I've got enough air moving in my case that the backside plate does an adequate job of cooling the ram, but I'll probably eventually switch to regular heatsinks. BTW, the 3 pin connector actually fits though the hole in the plate, so the soldering was done and then the plate reattached. I'll most likely just replace the 562 ohm resistor on the board with a 487 ohm (for 2.98V) and then remove the wires.
