Well I got one 1.4GHz and one 1.6GHz here and was wondering if there's other people that dared to try some...
Here's the 1.4GHz part, MIXIB 0336 "Z", cooled by Tt Silent Boost:
Mollov,
Runnin' a 700MHz SlotA Thunderbird...
HardwareSight.com Owner
Have you tried the mod to enable the rest of the cache?
Nice o/c btw
This is the second thing I'll do with those two after I found out where's the MAX for each of them.... just to check if the cache is all good will there be a penalty in the MAX clock, when I'm using 256k L2.Originally posted by dojobi
Mollov,
I have a 1600 that will do 2.4GHz w/ 1.9v and crappy cooling.
Right now I have it doing a distributed computing project at 1.7v and 2250 WITH the L2 mod(for the extra 192k L2 cache).
So for $42 delivered, I basically have an XP that'll do at least 2.4GHz.
A couple of us have been playing with these over here...
http://forums.teamphoenixrising.net/...threadid=18244
yeah but the cost is so close to the 1700xp's that other than the fun of being able to mod it into the real mc coy the chips are just too close in cost for me to actually buy one.... but deff a killer deal and verry interesting indeed
later perc,
with the right cooling somebody is going to crack a 100% overclock on the 1400's some day
That may be true for USA, but here in Bulgaria the good 1800+ ( there ain't no 1700+ anymore ) are 60$+.... so one 1.4GHz for 42$ is quite a deal.... and even bigger one if the L2 cache is all goodOriginally posted by Perc
later perc,
It's really good to see that those Durons like high voltages and MHz.... It's a shame, that I can't have more than 1.75V with that A7N8X Dlx... but hell - that little puppy will go in my main system with some EPoX ( or sumthin' else ) mobo and the P4 goes to the testing system.... don't need so much of a power when watcing movies or listening to a MP3s
Mollov,
"....And then the Duron became an AthlonXP..."
Well.... now it's time to test if I can reach the same o/c speed as I was reaching before the L2 mod...
Mollov,
....... and back to 2300MHz
Mollov,
I might get one of these for a bit of cheap fun, plus I just killed my test duron in a very stupid way (dont ask, i was clumsy)
It might be fun to try and get a 100% overclock from the 1.4gig
Im also working on a Vmodd for very high (and hopefully stable) vcore, a cheap duron will make a good guineapig.
Not to mention that If you get good core with a working L2 cache up to 256k it will make a good TbredOriginally posted by Holst
Mollov,
my results:
cpu1:
1600
MIXIB 0336 TPMW ---> 2200 1.85v on air
cpu2:
1600
MIXIB 0336 TPMW ---> 2300 1.90v on air
. <---- a point.
Where is the guide for modding these?
Looks like I'll be getting one of there
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
they look like fun.. but for $5 more i think ill graba second 1700. already have this one at a 1gig OC on air.. so i think i may test my luck on a second. if its better this 1700 goes to a friend for $45
and the world goes round.
Dell Studio XPS16... no desktop
yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
I noticed the newest going better, this is an old one... Still one with a short core
24 core Xeon:
2x Intel Xeon Q3QS 'ES' @ 4.1GHz (folding@3.8GHz) - (flakey) EVGA SR-2 - 2x Antec Kühler 620 - 6x 4GB Corsair Vengeance 1600MHz CL8 - MSI GTX580 Twin Frozr II/OC - Thermalright Shaman - 2x Intel X25-M 80GB RAID0 - Silverstone Strider 1200W Gold - Lian Li PC-P80
I'll be getting me one, and will threat him with 2.3+ V and peltier cooling!
Epox 8KDA3+ full modified
Kingston PC3500 HyperX ( Winbond BH-5) running 270Mhz 2-2-2-5@3.7V
AMD Athlon 64 3200+@2430Mhz 9x270
Club3D Geforce 6800 Ultra (on it's way)
I was going to get one but changed my mind because they don't overclock any better then a Barton and even if they are cheaper then a XP2500+ they are at the same time slower because of less cache.
CPU: AMD Athlon XP 2500+ @ 2850MHz
Motherboard: ABIT NF7-S v2 nForce 2 Ultra 400 @ 228MHz FSB
Video Card: ATi Radeon 9700 PRO @ 400Mhz core / 710MHz Memory
RAM: Corsair 2x256MB TwinX 3200 LL @ 228MHz CAS 2-2-2-11
Media: 120GB Matrox DiamondMax 8MB cache, Seagate Barracuda IV 80GB & 40GB
Cooling: nVENTIV Mach I ( CPU ), Watercooling ( GPU & NB )
Mouse and KB: Logitech MX700 & Logitech Cordless Keyboard
Case: Coolermaster ATC-220C, Enhance 460WPSU
It won't even POST like thatOriginally posted by Coolzero2k1
Ever heard of the cachemod? If you're really lucky you'll be able to mod your modded xp-duron to barton, now that'd be xtremeOriginally posted by Liquide
24 core Xeon:
Why wont it post at 2.3V?
Almost none of the 1.5V chips like it, I found my chip went higher on 1.85->1.95v then on 2.3v
24 core Xeon:
I have a modded 1,4 GHz. It did run Prime95 for sevral hours at 2,05 GHz with 1,92 V and VapoChill PE cooled, but anything higher was no good. I'd like to try higher voltage, but my mobo won't.
Full info:
DHD1400DLV1C T598487272295
MIUGA 0334VPMW
Satan: Opteron 165 - TT Big Typhoon - DFI Lanparty NF4 SLI-DR - OCZ EB PC3500 2x512MB - Asus Radeon X800 XT - Raptor 74GB x2 RAID0
Slepbar (Lenovo 0761): Pentium M 735 (Celeron M 380 @ 2,13GHz) - DDR2 2x512MB - GMA 900
3DMark2001: 40392 - Super PI: 23s
It's quite simple:Originally posted by isp
Mollov,
hello their,
nice find by the way
Could I ask you for some information??
What id like to know is what is the stepping on your chips?
We could see if the part of the wafer the cores are taken off is at the edges.
What this tells me is that there maybe from the 'worse' part of the wafer but seeing the silicon process is reaching its maturity we will be getting better chips at later dates (assuming that the process is as 'pure' as previous wafers)
I c sum info has been posted the more the better.
So peeps with these durons please provide information.
Cheers
l8rz
Seasonic Prime TX-850 Platinum | MSI X570 MEG Unify | Ryzen 5 5800X 2048SUS, TechN AM4 1/2" ID
32GB Viper Steel 4400, EK Monarch @3733/1866, 1.64v - 13-14-14-14-28-42-224-16-1T-56-0-0
WD SN850 1TB | Zotac Twin Edge 3070 @2055/1905, Alphacool Eisblock
2 x Aquacomputer D5 | Eisbecher Helix 250
EK-CoolStream XE 360 | Thermochill PA120.3 | 6 x Arctic P12
So all I have to do is cut that one L2 bridge?Originally posted by TodB
It's quite simple:
