Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Vapochill and promie mounts templates for A64, also vapochill moount for R9800pro
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Here are some mounting plates I've laid out for the promie and vapochill for the A64/FX51. The pics are not drawn to scale but measurements are correct and atleast might help someone with a starting point to make there own.
    I'm using 1/4" plexiglass.
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    This is pic I borrowed (sorry don't know who posted it) showing a simular mount for Vapochill on P4.
    Aug 2002
    .CA
    Nice post Major!! Thanks I'll be needing this info very soon.
    If my answers frighten you, stop asking such scary questions...
    • Hush V2
    • Intel i7 4770K - XSPC Raystorm - Gigabyte G1.Sniper Z87 - Crucial Ballistix DDR3-1866 - 9-9-9-24
    • Zoltac Geforce GTX 780Ti - EK-FC780GTX Ti
    • SanDisk Ultra 480GB SSD - WD Black 1TB 64MB Cache
    • Custom Water Cooled Fractal Designs Define R4 - Antec HCP-1000 Platinum
    • EK Coolstream XTC 280 - Cougar CF-V14HB Vortex HDB - XSPC EX240 - Scythe GT AP-15
    • Dazmode Storm DDC 3.25 - AquaComputer Aqualis DDC 150 Reservoir
    Xtreme Gamer
    Jun 2002
    Boise, Idaho USA
    That was the one I did. It was made from 3/8" plastic and it bends a bit more than I like when I tighten it down, but does the job ok.
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    BMG thanks for the pic then !
    Here is the radeon mount I made.
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    And here are some pics of the promie mount in use on the A64
    Jun 2002
    Nice post Major.......
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Hey Jason I did a How-To guide for Madshrimps, I wish you had posted that Friday !
    Sep 2003
    NY
    Great job guys. Would you be intrested in selling one?
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    Jason,
    Nice...what anti-condensation measures do you take with the vapo-9800? And obviously your shim sits lower than your core right? On mine when I had dry ice on it, the DI container contacted the core AND the shim, transferring so much cold to the shim that half the card froze up...lol
    C
    Jun 2002
    Belgium
    Make and ship me one, I'll pay (pm me if you are taking this for serious )
    24 core Xeon:
    2x Intel Xeon Q3QS 'ES' @ 4.1GHz (folding@3.8GHz) - (flakey) EVGA SR-2 - 2x Antec Kühler 620 - 6x 4GB Corsair Vengeance 1600MHz CL8 - MSI GTX580 Twin Frozr II/OC - Thermalright Shaman - 2x Intel X25-M 80GB RAID0 - Silverstone Strider 1200W Gold - Lian Li PC-P80
    Moderator
    Jun 2002
    Here is my Prommie on the Raddy method
    Moderator
    Jun 2002
    The mobo just died
    I was hoping for a humble 280 x 9/ 5:4 bench......
    But I'm now eyeing the Abit KV8, really really tempted right now.
    The good news is the Prommie works significantly better than a 172w pelt at 18.8v with -30C liquid. Max was 551/427 on Car Low before, now testing it on a KT600 board without AGP voltage adjustments 564/432 on Car low, with some tearing of course
    Moderator
    Jun 2002
    Thats just the wax paper on the Seal tape same stuff like that Seal string. I leave it there if not my fingers get the sticky stuff all over when I hold the card heh.
    I have VGPU at 1.94v, VDDQ at 2.73v which was up from 2.68v or somewhere there, Vref at default of 1.41v, and VDD at 3.63v. I tried 1.5v Vref last time whjen on pelt, didn't help, but I might try it again with this improved cooling. Have good fannage over the heatsink cooling VDDQ regulator or some chip like that, and it still gets quite hot. Ramsinks came with the card so that's handled.
    I think the combi/ratio between VDDQ/VDD/Vref is very important for overclock as well as for survival of the card. I think high VDD with low VDDQ/Vref can kill the card easier than say high VDD and high VDDQ. I also tried pulling the VDDQ and Vref further apart and artifacts soon started to appear, so I stick with VDDQ a little below 2X of Vref, that works good for me.
    Moderator
    Jun 2002
    Heh, I doubt that I would be removing any of the mods, but if I do I'll let you know. Though its much easier for you to just buy some bigger VRs
    Aug 2003
    My Prometeia is mounted on my 9800 Pro by putting seal string on the edge, pressing hard, and putting an elastic band over one side of the cooling head. Really bulletproof setup .
    But it works! No leaks.
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    bump
  18. #18
    Nov 2002
    Inside out
    Thanks for the bump, this thread is really useful.
    I'm gonna try making a mounting kit for my socket-a vapo on my hercules 9800p tonight (just got one back from rma, doing 500/400 on water now).
    Also I should post some pics of how I've mounted my prommy on my A64, I did it a little bit differently and re-used most of the components from the standard AMD kit.
    FOLD!!!
    Bench rig: Athlon64 3200 // Gigabyte K8NNXP with vmem/vddr voltmods // 256MB Corsair XMS3500 // Promise Fasttrak TX2000 // Maxtor 40GB 7200RPM HDD // TTGI 500W PSU voltmodded @ 3.7v/5.4v/12.6v // Prometia cooling (stock, r507 soon) // BBATI 9800XT stock no vmods YET // Speeds, voltages, and timings change daily
    25701 3DMarks
    "Everything you do will be more fun" -Microsoft, Windows 95 Installation
    I am american, PM's in english only please
  19. #19
    Banned
    Dec 2003
    NYC
    mickey your trading a r404a pe for a r9800 pro?
    beautiful pics guys. should have that in the phasechange gallery
  20. #20
    Xtreme Team DČOL
    Nov 2003
    Melbourne
    Just what I was looking for! A custom mount for a Vapo/9800pro.
    Man that looks good. I'm getting 500/770ish with WC but 550 or more would be a bonus as I have a spare Vapo Classic lying around.
    Man I'm so glad I found this forum. I've learnt so much about modding everything possible & more.
    A BIG to all XS members from an experienced OCer but a nOOb to EXTREME MODDING!!
  21. #21
    Xtreme Team DČOL
    Nov 2003
    Melbourne
    Heya EXXXtreme guys.
    I'm going to make a mount for my 9800XT but need to ask a few questions first.
    a) how thick do I need the mounting plate to be?
    b) same Q about the back plate?
    c) Where do you guys get the neoprene that is shown in those pics for the Radeon mount?
    Seems like it's sold as a hollow tube. Am I right?
    Thanks,
    Minh
    srry bout double post but this thread needs to be up the top as its very handy.
    Cheers,
    Minh
    Mine:3770k @ 4.6Ghz @1.25v, Corsair H80, Asus SabreTooth Z77, 4 x 4GB Corsair Vengeance 1600C8, XFX 7870DD, Corsair HX850w, Sandisk 240GB Extreme SSD, Corsair Graphite 600T
    Kids: 2500k @ 4.6Ghz @1.368v, TRUE120, 2 x 4Gb Corsair Vengeance 1600C9, Gigabyte Z68X-UD4-B3, Gigabyte HD6870, Sandisk 240GB Extreme SSD, 850w Thermaltake 850w PSU, Antec P182 Case
    Kids2: i3 3225, 2 x 4Gb Kingston HyperX 1600C9, ASUS P8Z68-M PRO, Sapphire HD4870 1GB, 128GB Samsung 830 SSD
    Server: Core2Quad 9450, 2 x 2Gb Kingston HyperX 1066, 2 x 2Gb Corsair XMS1066, Gigabyte EP45-DS5, Corsair HX650w, OCZ 120GB Vertex 2E SSD, WD 1TB Black, 2TB Seagate 5900rpm, 2TB Seagate 7200rpm
  22. #22
    Sep 2003
    Belgium
    Originally posted by MickeyMouse
    ALSO 4-40 rod for the hold down bolts go to "LOWES" for that HW
    I have a question then...
    When I was modding a barton boxed cooler for my R9800SE (powercolor), I could only use 3mm wide bolts...
    In the pictures, your bolts seem to be thicker than an M3 one, how is that?
    Wimpie007
  23. #23
    Xtreme Team DČOL
    Nov 2003
    Melbourne
    1/4in plexi homedepot
    1/4in same as front
    homedepot in tubes just cut it and when ya tighten the back plate it will remain flat
    Thanks a bunch Mickey. Now what do I vapo, my 502/806 9800pro or my stock no-mods 9800XT....
    Cheers,
    Minh
    Cheers,
    Minh
  24. #24
    Xtreme Team DČOL
    Nov 2003
    Melbourne
    Whoops, I forgot to mention that I'll be giving my Classic a R404 makeover.
    Would that do the trick?
    I'm running my 9800pro @ 500/806 now with just Asetek's Waterchill (GPU block only) & the temps measure on the back of the GPU are 34c-36c at full load.
    Cheers,
    Minh
  25. #25
    Xtreme Team DČOL
    Nov 2003
    Melbourne
    Thumbs up Sticky for this thread
    I hope that this thread can become a sticky so that users wanting to mount their prommie/Vapochill on AMD64/VC etc can find out "how to" easily.
    Maybe if I keep asking questions to keep this thread up the top???
    Who do we ask to make this thread a sticky for its very useful info?
    Cheers
    Minh
    Cheers,
    Minh
