It came back from Aces so i could enjoy it for a few hours
goddamnit i simply couldnt get it into Windows at 3G![]()
I have 1.775V in the BIOS... which is more like 1.74V real... if i had 1.850 I swear to you i could bench it at 3 GHz... bloody ASUS.
I ran the memory almost as high as it would go, 224-226 MHz 1:1 2-5-3-2 at 2.70 volts. This is the corsair 400 registered and i can tell you its pretty damn good. The Kingston 400 registered is absolute crap stay away from that POS.
mem bench
some rather useless sandra shots
pifastgetting closer macci
I have an utterly useless 9800pro here that i can only get up to 438/357 stock. nonetheless im a hair from 24K with a car high of 140 FPS and lobby high 165.2 FPS. If I had some good radeon clocks I think i could get 27K because this graphics card just bottlenecks everything,,, although lobby low did start off at 602 FPS even with a low card
I ran some PCmark just to forget about the possibe 3D scores I could make http://service.futuremark.com/compare?pcm=1529525
What I need - but cant do sadly - is a Vmem mod and a tad more Vcore voltage. Then I can see a 41.5-42s pifast and 28-29s super pi time. memory speed is the key really... i could bench everything pretty much stable at 2.91 GHz, the memory and FSB were a pain in the ass though and soft reboots just dont work. The BIOS is one big bug as well.
hope to see 3dmark with a good 9800pro
This is not a Lime tree
