This probably won't be a very popular board with the Nvidia 250 chipset replacing the SK8Ns 150, but it's all I have to work with for now. Figure someone might be interested.
The Memory Voltage regulator is a Richtek RT9202
Datasheet
It's located on the top right of the board above the ATX connectors.
You want Pin#6(red circle) to your VR to ground. The 'red X' is your Vdimm measurement point, on the bottom of the resistor.
Now you got some voltage to tighten up those timings on that Registered RAM![]()
