Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: fortron psu mod
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Thumbs up fortron psu mod
    opened my fsp fortron group 350W psu (fsp350-60BTP)
    it has two pots, one on the side of all the cables leaving the psu. its really small and very sensetive, only turn it a ittle!
    it raises all voltages at the same time!
    the second pot is hidden under the cables leaving the psu and controls the shuttdown voltages. the fortron psus shut down atomatically if you raise the voltages too much. the fdefault setting is around 18-20%.
    so if you turn the first pot too far it will shut down, in this case turn the pot back, cut the power to the psu and wait a few seconds before you start it again.
    if your still not happy with the voltages you get when playing with the first pot, you can change the shutdown values by turning the second pot a little.
    i didnt use the second pot because im happy with the voltages i got from plaqying with the first pot.
    12v@14v 5v@5.6v 3.3v@3.7v
    those where the voltages i got with the psu not connected to the pc. when i started my pc with the psu again i noticed that the 3.3v had dropped to 3.1v! so i soldered a 50Kohm vr (10Kohm should be fine as well) to the brown sense wire close to the orange 5v wires.
    cut the brown wire and then solder each end to one of the pins of the vr. i dont know what resistance you should set it to to begin with, but since the psu shuts itself down automatically if the 3.3v rail should go too high theres no prob.
    i just turned the vr a little more and tried to power the psu on again and start my system. if it doesnt start just cut the power wait a few sec and turn the vr a little further. i did this for 3 min until i found the right resistance and then raised the 3.3v rail while watching the voltages in the bios until i reached 3.7v again.
    14v 5.6v 3.7v
    Xtreme X.I.P.
    Nov 2002
    Shipai
    only turn the pots by 30° , this should raise your rails to 13.6 5.4 and 3.5 already
    Dec 2002
    Tempe, AZ
    i dont know how safe that is for your psu??
    after a while, i think it would fry it dont you think?
    NF7 | Mobile 2400+ | 256MB Twinmos PC3200 BH5 | 9800 PRO | 23384 6989
    MY HEATWARE
    Xtreme X.I.P.
    Nov 2002
    Shipai
    yepp running my 12v rail@14v
    stang, there are people running their rails a lot higher then me. stevils little brother runs his 5vl rail@7v iirc and ive heard from quite a lot of people who run their 12v rails@14v adn theres even one japaneese guy (lol its always the japaneese ) who replaced the 3.3v cables with 5v cables, so hes running his 3.3@5v
    ill let you know if the my mainboard dies the psu wont die, it has an overvolt and overheat protection, if the voltages rise or drop too much or too fast or become too unstable it shuts down the system... great psu!
    Dec 2002
    Tempe, AZ
    well, i was thinking motherboard too..
    how would you replace your 3.3v lines with 5v ones??
    which ones are the 3.3v ones? the yellow is 12v, the red is 5v and the black's are groundd.. 3.3 is orange??
    MY HEATWARE
    c[_]
    Nov 2002
    Alberta, Canada
    My brother's 3.3v is 3.7v because it is a 230 watt PSU thats half shot or something... 8-)
    I wouldn't worry about the PSU. I would worry about what is connected to it..
    EDIT
    My Enermax 430 is screaming for the r82 mod... :smileysex
    All along the watchtower the watchmen watch the eternal return.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    im just overvolting 17% on the 12v line, and 11% on the 5v and 9% on the 3.3v line. i really dont think itll kill anything.
    thats like jumping from 1.6vcore to 1.8vcore with a cpu....
    Jan 2003
    Belgium\Ieper
    if I were you, connect your HDD to a seperate PSU. they really don't like that much voltage
    Xtreme X.I.P.
    Nov 2002
    Shipai
    nah i still have this brand new 20gb ibm here in case my old one dies...
    i really dont care if this 40gb ibm crapstar dies...
    go go die on me you %"§)/& %$&§&(&&!
    son of a %&$/(&))($(§&& $/%%§%& you (&%§)$&""§/_§
    Jun 2003
    Japan
    i have one of these i think.. that "overvolt" pot is 3.3v though and the other one is 5/12.. btw it handles a hell of a lot more than 350w and while maintaing completely stable rails that are alot higher than spec
    I cannot control my vocabulary
    Xtreme X.I.P.
    Nov 2002
    Shipai
    yeah fortron psus ROCK!
    Feb 2003
    Italy/Slovenia
    I have an aOpen 300w with the same type of trimmers. On nf7-s 2.0 if 3.3 is too high (3.6v) mb doesn't work.
    Bye!
    Dane - OC-ENTHUSIAST TEAM
    barton 2500+@2834 // abit nf7-s rev2.0 modded // 2x256 adata with bh5 // sapphire 9500np 128Mb pcb rev.3 modded // aOpen 300W
    3Dmark2k1 21773 in AMD32/9500np class
    Xtreme X.I.P.
    Nov 2002
    Shipai
    it wont work? my 3.3v is @3.69 and its running great!
    Feb 2003
    Italy/Slovenia
    mb doesn't boot if 3.3 is too high.
    I don't remember the exact limit, I'll control ;-)
    Jun 2003
    Gainesville, FL
    So whats the point in overvolting your rails by a significant amount? I also have a Fortron 350watt PSU. Think its the BN tho
    c[_]
    Nov 2002
    Alberta, Canada
    its probably the PSU giving out, Dane.. not the motherboard.
    Feb 2003
    hehe , nice mod saaya, i would try it out if I was keeping on NF7-s:
    My last NF7-s burnt because of my ANTEC 430W which died suddenly and fried the HIP6301CB (dunno why, but something to do with my "new HIP6301CB trick" )
    I think I burnt my last NF7-s yesterday (6 in two months ), and the shops where i'm currently buying my NF7-s have enough to see me week other week and i'm selling all my AMD stuff to go to P4C flavour.
    Xigfrid
  18. #18
    c[_]
    Nov 2002
    Alberta, Canada
    I have a Hi-Pro "200" watt PSU.. i'm considering trying it out on my 8RDA+ because of what i've got running on it for testing right now.. lol
    (Dual P2 266's, 86 watt pelt, GF256 DDR, bunch of fans, 15k rpm scsi disc, 2x 3.5gb 3400rpm hdd's, 2x cdroms....
    holding stable @ 5.15/12.00 with almost no tweak on the pot.. hehe.
  19. #19
    Xtreme X.I.P.
    Nov 2002
    Shipai
    yeah i have a samsung 200W psu that has an amazing good 5v and 3.3v line, the 12v line is really weak though. im using it atm to power my 30W tecs with the 5v line.
    5.6v idle (pot maxxed)
    5.4v load (1x30W tec)
    5.2v load (2x30W tec)
    5.0v load (4x30W tec)
    4.9v load (6x30W tec)
    180W on th 5v rail of a 200W psu! not bad, and it barely gets warm!!!
  20. #20
    c[_]
    Nov 2002
    Alberta, Canada
    I burned up the 200 watt HiPro.. lol 8-)
    Guess a T-Bird 1.2 @ 1.75 2.2v, an 86 watt pelt, and a 15k rpm scsi drive were just too much.. hehehe.
  21. #21
    Apr 2003
    Maryland
    Red face Re: Over volting PSU ...
    It's for bragging rights.
    Even though the components are designed to run on
    12 volts, some think it's cool to be able to say "My system is over volted to 14 volts!"
    ~ SolTek SL-75FRN2-RL (nForce2) = 10x230fsb, 2.0/2/2/11
    ~ 1800+ DLT3C/VPMW/0307 ~ Leadtek 6800nu (unlocked 16/6)
    ~ PCP&C 425deluxe ~ Gskill "LE" 1gb TCCD/437 ~ 36gb Raptor/200gb Barracuda ~ SLK-900a
    The MIND is like a parachute - works best when OPEN
  22. #22
    c[_]
    Nov 2002
    Alberta, Canada
    No, its not bragging rights.
    Higher 3.3 lines alow higher ram voltage (so can 5v lines), higher 5v lines can increase stability and bleah bleah bleah...
  23. #23
    Xtreme X.I.P.
    Nov 2002
    Shipai
    lol braggin rights? well not directly, you get a higher oc with higher rails wich then results in better braggin rights
  24. #24
    IT Engineer in the making
    Jun 2003
    Former Kingdom of Bavaria
    Re: Re: Over volting PSU ...
    Hehe, the common excuse of the ones who didn't try it themselfs yet as they are afraid of frying something.
    For example some people also consider driving a fast sportscar as "bragging", but in reality they are just jealous because they don't have the chance to experiance the POWER of such a car!
    I don't drive a sportscar either (although my dream would be a Porsche 911 Turbo), but I can imagine what it is to drive one and I wouldn't say that it's just for showing off. It's pure fun!!! And that's what our overclocking mania is like, too.
  25. #25
    Xtreme X.I.P.
    Nov 2002
    Shipai
    its for braggin as well, but so what? whats the problem with that? we all want to show off what great things we have bought/reached since it reflects ourself... i dont think its bad to brag or show off, it just depends HOW you do it...
    you can either say :
    MAN LOOK AT MY VOLTS , IM SOOOO 1337 y0's! muh44h4h4h4h i PwnZ y0
    or you can say:
    check out this fortron psu! great voltages, up to xxxx now and still 100% stable under load. great psu, i can only recommend it!
