Results 1 to 12 of 12
Thread: Kingston HyperX no good ??
    Feb 2003
    I have 2 x 256 sticks of Kingston HyperX PC3500, part no, KHX3500K2/512.
    I can get them to run 1:1 at 232 mhz which is fine, however I can't get them to run asynch at 5:4 or 3:2, the most I can get is 208 Mhz which is bad.
    I have some cr&ppy el-cheapo no-name pc3200 that will run asynch 220 Mhz no problem.
    The question is, why will the Kingston run high fsb 1:1 but not asynch.
    BTW it will run 1:1 232Mhz at 2-7-3-3.
    Any ideas ??
    MoBo is IC-7 with vdd mod, voltage makes no difference, I have tried up to 2.9 with no luck.
    Dec 2002
    Jersey City, NJ USA
    not sure there. Mine run 290 5:4 no problems. Maybe your hyperx has the ch-5 chips on it, which I hear has problems async in the IC7 and some other boards.
    | MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
    HeatWare
    Xtreme X.I.P.
    Jun 2002
    Belgium
    Same problem for me.
    Bought me 2*512MB HyperX PC3500 sticks and I can't run at +250Mhz, with either 3:2 or 5:4 settings on my IC7-G.
    Plain CH5 crap chips on them, just like Twinmos is using these now.
    And way overprized.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    guess i was lucky to get some khx with bh5 then...
    Xtreme X.I.P.
    Jun 2002
    Belgium
    Guess you are.
    I bought 4 512MB sticks in total, from 2 different persons over at a German forum.
    2 sticks seem to have the BH5 chips, because the guy who has them now, can run at 275FSb, 5:4 and fastest settings.
    Looks like I got the bad ones.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    theres a guy on ebay.de selling a 512mb bh5 stick for 66€
    Feb 2003
    Thanks guys
    It looks like these 2 sticks are going back then.
    I looked at the el-cheapo ram that I have and it's A-data PC 3200, cost was £120 for a gig, I guess I'll use them
    Aug 2003
    Netherlands
    Hm, me and a friend of mine have exactly the same problem. Kingston HyperX PC3500 but with the ASUS P4P800. FSB won't go farther than 255MHz (stable) with the divider on 5:4.
    He also tried Corsair PC3700, but still has the same problem.
    Do you think this issue will / can be resolved by a BIOS patch?
    Or which PC3500 / PC3700 memory sticks does not use those chips (without getting as expensive as OCZ)?
    Dec 2002
    Jersey City, NJ USA
    supposedly abit says it is working on a fix for it's bios' so I am sure Asus is also. I would imagine since these CH-5 chips are ebing so widely used, they will have to find a fix for it.
    HeatWare
    Aug 2003
    Netherlands
    Uhm, supposedly? I'm on the verge of ordering some new GeiL sticks. I tried the 1010 BETA 6 BIOS today and it still won't work.
    Of course, if they come up with a fix then that's perfect!
    Do you have any source or any idea when to expect the fix? And whether it's really true? Sounds great!
    Jul 2003
    Chaos Sanctuary
    Are Kingston HyperX PC3200 BH-5 chips?
    1700+ DLT3C @ 2.4 Ghz (220 x 11)
    Abit NF7-S rev.2.0 with modded NB cooling
    Sapphire ATI Radeon 9800XT 256MB
    PC-3200 2 x 512 Corsair XMS
    Western Digital 120GB 8MB HDD
    "Framerate is Life!"
    Jul 2002
    Norway
    Im kinda wondering of that too, because if they are, im ordering 2x256 tomorrow
    Intel i7 3930K C2 @ 4700 mhz (100 x 47) 1.4v
    EK Supremacy/EK XTC 420+280/EK DCP4.0/PrimoChill 1/2 ID 3/4 OD
    Asus Rampage IV EXTREME
    16 GB G.Skill RipjawsZ @ 2400 CL10-12-11-1T
    Zotac GTX670
    Antec Quattro 850W
    Intel 330 180 GB + Micron C400 128 GB
    LD Cooling PC-V7 B/R
