Results 1 to 13 of 13
Thread: U guys have this Mach 2 USB problem?
    Oct 2002
    NYC
    OK i was able to install all the usb drivers and the Prometeia Software, but when i start the program i get the error in the lower left hand corner of the program. And ideas on how to fix this?
    E6600 SL9S8 Malay
    ASUS P5W64( no mods )
    Mushkin (2 x 1GB) XP2-6400
    ATI x850xt
    2 x 150GB WD Raptor RAID
    Thermalright Ultra-120
    SilverStone ST56ZF 560W
    Oct 2002
    NyC - did you find a work around for this problem yet? Do you have USB enabled ok in the bios? Let me know thanks.
    Banned
    Jul 2003
    West Virginia
    Look here for the chip controler download http://www.xtremesystems.org/forums/...ighlight=mach.
    I had that problem after installing front display and this solved it. Instructions for firmware are in the back of the manual.
    Banned
    Jul 2003
    West Virginia
    Make sure to look at the usb pin out for the mobo. I think if you have the usb connector reversed it will cause this also.
    Oct 2002
    NYC
    Thank you 2Fast4u and WxChaser. i updated the firmware and now the usb connection is alright now. Once again thank you guys for the help.
    E6600 SL9S8 Malay
    ATI x850xt
    Banned
    Jul 2003
    West Virginia
    Good to see it is working now. BTW what do you use to get your screen shots?
    Oct 2002
    NYC
    i use print and turn it into jpg. looka bit fuzzy though.
    E6600 SL9S8 Malay
    ATI x850xt
    Nov 2002
    Sierra Nevada Mountains (not my Beer)
    2fast4u.....try irfanview it's free ware, very powerful...I like it alot!
    Oct 2002
    Great NyC - glad to hear it, will be doing some configuration on my rig very soon hopefully (bowman is making good progress!).
    Oct 2002
    Once you've extracted the .ste file, how do you upgrade the firmware once everything is ready to go? Figure it's an easy process (bowman has the service manual with my rig so just wondered in advance, thanks!).
    Oct 2002
    NYC
    being as dumb as myself, i thought all files were one-click installers. but i tried out bootloader.exe in the Prometeia Folder and pressed Bootload and opened up the .ste file into it, nad it started to upgrade it. Veyr easy!
    E6600 SL9S8 Malay
    ATI x850xt
    Oct 2002
    Cool - thanks man. I figured it had to be pretty simple...and glad it worked out. I'll need the USB headers to work, since no serial or parallel ports (now I have to buy another frikkin UPS that works via USB instead of serial port connection). I have an APC BackUPS 650 now & will need to upgrade to an APC Backup Pro unit of some kind, once I scrape up more cashola.
    May 2003
    Tax-country
    prob solved
