Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 116
Thread: 250 FSB DC SYNCH and ABIT NF7-S
    X.I.P.
    Jun 2003
    Patras - HELLAS
    Thumbs up 250 FSB DC SYNCH and ABIT NF7-S
    Last night i moved back to d10 BIOS and droped down VDD to 1.75 Volt....
    Now? 250 FSB 100% STable and still dont believe it.......
    I want more but 1.0 has 250 as top limit FSB.....
    Just Take a look.....
    E8400 4400(Q814A015 Wafer **91)@1.296 Vcore
    Q6600 (L733B458)@4054 1.5 Vcore
    ASUS P5Q Unmoded - 2X2 GB Corsair Dominator 8500
    Blaster AUDIGY 2
    Sound Blaster Megaworks Speakers 2.1 250D THX / 300 WRMS
    ATI 4850 512MB @750/1150 Stock cooling
    LG W2600HP-BF 26" Wide TFT Monitor (S-IPS)
    System Cooled by ThermalRight Ultra 120 Extreme
    System Powered By OCZ 600W
    Limits do NOT exist
    X.I.P.
    Jun 2003
    Patras - HELLAS
    But i like for 24/7 246 FSB whish give me MOOORRREEEE Performance.....
    Blaster AUDIGY 2
    Limits do NOT exist
    AMD Fanboy
    Jan 2003
    San Luis Obispo, California
    nice! i wish my mobo would do over 182fsb LOL.. thats why its getting RMA'd tomorow!
    Dell Studio XPS16... no desktop
    yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
    X.I.P.
    Jun 2003
    Patras - HELLAS
    Good luck.......
    And just remember to try BIOS d10 (for Ver. 2 NF7) and see whow it goes......
    You will find alot of Performance hidden right there.......
    Blaster AUDIGY 2
    Limits do NOT exist
    X.I.P.
    Jun 2003
    Patras - HELLAS
    Now my main target is to have 250 X 10 = 2500 MHZ stable 24/7....
    Since now all are ok but 3D is not working well...
    Probably need a litle more VDD juice like 1.80 to 1.85 to have 3D World back to action........
    We will see...........
    Blaster AUDIGY 2
    Limits do NOT exist
    Jan 2003
    Sweden
    Thats verry nice. What timings are that in and are all things stable(like memtest86 and prime) at 250 except for 3dmark?
    Abit NF7-S v2.0 vdd vdimm | 2400+ XP-M @ 10x230.5 1.83v | 2x TwinMOS / Winbond BH-5 256MB
    Feb 2003
    get a chip that can do more than 2.5Ghz , then you will have the 250*10
    btw nice NF7-S, can you tell us what mods you did ? I mean Vdd mod, Vdimm mod, rads on mosfets, zalman32NB on southbridge , special cooling on northbridge ?
    X.I.P.
    Jun 2003
    Patras - HELLAS
    For 250 FSB i set timmings at 11-3-2-2.5
    For 246 FSB i set timmings at 11-3-2-2 and was stable.....
    I also tested 11-3-3-2.5 to have stable 3D at 250 FSB but no luck until now....
    I will raise VDD up to 1.8-1.85 and redo all Becnhes from begining...
    The BIOS 1.0 goes from 245 FSB (246 measured with CPUID) directly to 250 without midle steps like 246 - 247- 248 - 249 and this was another problem.....
    But since now all are running very stable and FFFFFAAAAAAST.......
    Blaster AUDIGY 2
    Limits do NOT exist
    Aug 2002
    so you aren't at 250 100% stable.. if you aren't 3d stable you aren't stable at all
    try 7-3-2-2.5 settigns, all the memory i have tested lower the max clock if i set 11
    Xtreme X.I.P.
    Nov 2002
    Shipai
    your using the 1.0 bios on the rev2.0 board???
    X.I.P.
    Jun 2003
    Patras - HELLAS
    Before the downgrade from d18 to d10(for Ver. 2 NF7) BIOS i had VDD up to 1.95 for a stable 242 FSB...
    Now with 1.0 BIOS i have VDD mode back to default voltge (1.75 Volt) measured with my digital multimeter.....
    I dont use any other MODS (VDDR - VCORE e.tc.)
    I have stock cooling on it but AS3 under Heatslink and Passive Cooling with a Simple heatsink on the other Bridge.....
    Mosfets are not using extra Heatsinks.....
    I guess i am VERY VERY LUCKY
    Blaster AUDIGY 2
    Limits do NOT exist
    Xtremely Large Member
    Jul 2003
    Britland
    Holy poop!
    Mine doesn't even like anything over 210Mhz, good going man!
    I've heard it all, I've seen it all, I've done it all. I just don't remember any of it.
    DFI LanParty UT NF3 | A-64 3200+ | 1Gb OCZ EL DDR PC-3500 Limited Edition
    Radeon X800XT | Audigy 2 | 2x WD 74Gb Raptors | 60Gb IBM | 20Gb Maxtor
    OCZ PowerStream 520w | Mach II GT Cooled
    X.I.P.
    Jun 2003
    Patras - HELLAS
    Lets clear this .....
    I am 100% stable at 250 FSB but with a multi set to 9.5 which give me 2375 MHZ which is not what i want........
    When i set 250 FSB X 10 = 2500 MHZ then all running fine even Prime 95 - CPU TOAST - Fast PI - SUPER PI but 3D applications after a few minutes just closing .....
    And seems to me needed a litle more VDD or a much effective cooling to the Chipset........
    PS...... If any of you have same mobo Ver. 2.0 just try to Flash d10 (for Ver. 2 NF7) BIOS and findout what will happend.....
    If this confirm my success then we must ask from ABIT to give us a new copy of this BIOS with SATA correction on it and leave all the other code back to original d10 (for Ver. 2 NF7) BIOS.......
    Is a good IDEA.....
    Blaster AUDIGY 2
    Limits do NOT exist
    Xtreme X.I.P.
    Nov 2002
    Shipai
    If any of you have same mobo Ver. 2.0 just try to Flash 1.0 BIOS and findout what will happend.....
    it killed the board of a friend
    well he needed a new bios chip that was all... i really wonder why your board is still working... are you sure its the 1.0 bios? where did you get it? i heard of 2 other people already who tried to flash their 2.0 boards to 1.0 and they board wouldnt post after that...
    please post a link, i wanna try that bios when i get my nf7-s 2.0 back.
    X.I.P.
    Jun 2003
    Patras - HELLAS
    I always doing flashes with ABITs Flashmenu utility and is working perfectly.....
    There is a note on ABIT homepage that is not able to reverse to any BIOS prior to d14 if i remember well but this is not true when you are using flashmenu utility.....
    The most importand of all if before you make a flash ALWAYS you must be sure you are with 100 FSB and remove from memorie any aplication is running......
    Since now i've made up to 20 - 25 FLASHES with this board and many many more times BIOS reconfiguration and until now thanks GOD all running well........
    Blaster AUDIGY 2
    Limits do NOT exist
    Aug 2002
    some people use bios 10 with rev 2.0, because bios 10 give much more overclock VS bios 14-16-17-18, more bus & more performance, and there is no problem to go back to bios 10, use winflash
    Xtreme X.I.P.
    Nov 2002
    Shipai
    he did use winflash, he was on tha 16 bios before because i told him it works best for me. he used winflash to get the 10 bios flashed, all went fine, need reboot window popped up , but it never booted again.
    i heard of some special commands to get back to 10. do you mean that? or did you just use a floppy with the 10 bios to boot and hit alt-F2?
  18. #18
    Feb 2003
    Originally posted by st0nedpenguin
    Holy poop!
    try the L12 mod + bios 1.0 => nice combo for 230-240Mhz
  19. #19
    Jul 2003
    Britland
    I have my 1800+ all ready to go, just waiting till I have the time to pop it in, prolly on saturday, unless I snap and stick it in tonight.
    Here's hoping I have enough AS3 left!
  20. #20
    X.I.P.
    Jun 2003
    Patras - HELLAS
    Please dont make me think i have the GOLDEN SAMPLE on my hands because i dont believe it.....
    Abits flashmenu have all the options you need for a safe FLASH.....
    I remember a day which flashing procedure just freeze in the middle of flashing and after a Ctrl - Alt - Delete combination i end task the flashmenu and restart again flashing.....
    Even with this bad situation still working JUST FINE..... But NEVER i mean NEVER forgot to make boot at 100 FSB before do a FLASH Procedure....
    So i think if you want to try you MUST be FLASH back to d10 (for Ver. 2 NF7) BIOS....
    The risk of a Bad Flash always will be like ghost around us.......
    Blaster AUDIGY 2
    Limits do NOT exist
  21. #21
    X.I.P.
    Jun 2003
    Patras - HELLAS
    With 246 FSB and 10 multi all 3dMark 2001 & 2003 passed at default card speed...... 400/850 GPU MEM for my fx5900 by Leadtek..... But is not the higest scores i got because i dint try yet to push more....
    I have a lot of tests to do before find the best FSB/MHZ combination for a 24/7 use.......
    Here i post just the begining of a happy story and just wait to see the happy ending of it.....
    Blaster AUDIGY 2
    Limits do NOT exist
  22. #22
    /dev/zero
    Nov 2002
    Germany, Berlin
    Originally posted by MickeyMouse
    lets see 3dmark 2k1 above 241mhz dc at max timings tho M8?? with a very oc'd VC and a multi over 10x???? if not its a joke but very nice oc there anyways
    Yes. Wanna see. My ram single sticks can easily do 243 2,0-11-2-2 at 3,17V but in dual channel... that's another story
    At least with multi above 9,5...
    Xtremesystems.org
    i7-4820K * ryba 2-stager + 1-stager * EVGA X79 Dark * 32G Team Xtreem 2666C11 * EVGA GTX 680 SC Sig. * Intel G2 80G * Corsair HX1000 * Lian Li PC-70B * Watercool Heatkiller, EK Fullcover/Backplate for GTX, MCP355 Dual Setup@Koolance RP-402X2, PA120.3+Alphacool 360, Tubing 16/10.
  23. #23
    Xtreme Mentor
    Jun 2002
    Interesting thread. I never did inderstand why we had to sacrifice this performance when they updated the bios from 1.0. Please send this thread to Abit.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
  24. #24
    Xtreme Mentor
    Oct 2002
    boston,ma
    That is very good. Get some good memory and you will ok to go.
    Abit KN9-SLI
    X2 3800+
    1gb corsair pc5400
    2 evga 7900gt
    200gb maxtor sata
    ocz 520w
    heatware:althes
    ebay althes
  25. #25
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    how about some benchmarks finally
    Super PI, Hexus Pifast, Sisoft sandra mem test, PCmark.
    those I'd be interested in seeing
