Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: IS7 Vmem mod?
    Oct 2002
    London
    IS7 Vmem mod?
    I know the mod. is the same as the IC7, but instead of R50, is it R567 i need to remove ??
    May 2003
    U of K
    Re: IS7 Vmem mod?
    I did the mod for a friend a few days ago....cant exactly remember the name of the resistor, but its in the same location as the r50; the top resistor to the right of the winbond chip.
    HTH.
    He who asks is a fool for 15 minutes, he who does'nt remains a fool forever.
    Oct 2002
    London
    yes pls...post here or mail it to me.
    Apr 2003
    Sweden(sthlm/Märsta)
    Well Pc ice ive done exaktly what u done,and i dont get it....I only get aprox 1.44v on this legs u showing...
    President Techsweden.org 3DMark Team
    First EVER to pass 20k/Ti4200 Series-20086
    First EVER to pass 20k/9600-series-20101
    My screens/records-gabbax-projects.com
    Apr 2003
    ok
    Apr 2003
    PC ice
    hmm,when u atached the vire to the "thing on the board,did u ONLY atached ONE vir? "vire on the "THING" and then to ground? il atached on the other side too....schould i atached that one directly to ground? insted...
    Apr 2003
    Hmmm, now il get it u simply removed the Exicting diod and replaced with wire to the 350Ohms VR am i right...
    Apr 2003
    pc ice
    Man do i feel like looser or what is it hard to remove it? just atached the "hot.pen" and grab it witha pincett? den put the cables on it
    Apr 2003
    Ahhh,thx man just remove it totaly...(Boring,iv just put my things together now) .Il do this after lunch il put my 2kOhm VR to 350 and then
    Apr 2003
    Hmm well it didnt change annything for me It is my processor who stops me to get anny further .Well i hav a verry good Modd thx to PC ICE man il sit down later and do some testings
    Apr 2003
    HEhe,well i can now run 285x12 Ratio:5:4 timings 2.5-7-3-3
    Aug 2002
    Melbourne Aus
    cheers, did the mod and it worked
    though it was bit scary to remove the lil surface mount component (it's so damn small)
    Jun 2002
    Melbourne, Australia
    Yep the mod was done 100% successfull and im currently getting 2.78vdimm when set to 2.5 in bios and 3.15vdimm when set to 2.8 in bios.
    We started at 300 ohms and then worked up and i think it was ~450 ohms when we settled for the above settings
    VTT has dropped to 1.24 volts when vdimm is set to 2.90 (real) or below....but when it gets up to ~3.10vdimm (real) it rises to ~1.36 So it looks like the are related somehow.....
    Kudos and many thanks to Ragnorok and his cousin for doing the mod for me while I looked on
    Intel P4 3.2 EE || Asus P4C800-E || Prometia Mach II || 2 x 256Meg HyperX 3500 || Antec TrueControl|| Sapphire Radeon 9800XT || 2x Raptors || Samsung 172T
    OCAU 3DMark Team || 3DMark Compare: 26847 || World of Britney|| PCDB Entry
    "Sundance is weird. The movies are weird. You actually have to think about them when you watch them. " -Britney Spears
    Feb 2003
    Brazil
    Hi guys, where can i find the IC7 mod so I can do it on My IS7, I´m dont know xxxitz abou soldering, so I need an good guide that I can show it to a friend of mine, who by the way nowz xitzzz about computers
    Feb 2003
    Brazil
    Huuu sorry heheh read it wrong,
    What I need to buy:
    Feb 2003
    Brazil
    Is it possible for you to take a Pic, of the entire mod, With the 1K VR, because I need to go buy one, and I don´t know the translation in portugue for a 1K VR, I need to see the little sucker
    Aug 2002
    Melbourne Aus
    1K ohm variável resistor (at least according to babelfish)
    http://members.iinet.net.au/~zzhang/nf7smod.jpg
    different board, but u can see a variable resistor next to the AGP slot
  18. #18
    Feb 2003
    Brazil
    I would like to use a resistor like this pic, 330Ohms, can give me 3.1v? Or I need a Higher rated resistor?:
    if I use de 1K OHM Variable Resistor Do i need to ground it?: Because I saw it has 3 legs, so I´m not quite sure where do solder de cables
    I really preffer the resistor mod over the VR,
  19. #19
    Aug 2002
    Melbourne Aus
    u can use a fixed value resistor, prob need a 400 ohm to give u 3.1V
    btw, one of the 2 soldering point is a ground...
  20. #20
    Feb 2003
    Brazil
    Tks man, gonna look for some 400ohm resistors to do the mod, since I´ll be taking the mobo of the case, Ill put some cooling in the mosfets and put a zalman heatsink on NB
    Thanks for the input, really helpfull
  21. #21
    Feb 2003
    Brazil
    One last dought, if I use a resistor, do I have to ground it?: The Vr needs it?
  22. #22
    Aug 2002
    Melbourne Aus
    1 of the 2 soldering pads is a ground.....
  23. #23
    Jul 2003
    let us know how u get on and post what is your max voltage when using the 400ohm resistor.
  24. #24
    Feb 2003
    Brazil
    Ive used a Trimpot, Can go all tha way uo to 3.2Vdimm, heres a pic
  25. #25
    Feb 2003
    Brazil
    Opppsss
