You can read it here fella'sVolt Mod Guide
Randi![]()
Randi![]()
deserves sticky..
Here there is a chipset mod for KR7/KX7, the pins is n°5:
so for the VCORE mod all i need to do il solder a lets say 22k resistor to pin7 and then to ground (my case or something like that??)
am i right?
[Team Green, Abit All The Way
AMD AthlonXP AIUGA 0241 Tbred 1700+ @ 175 x 11, Abit KX7-333, 256Mb PC2700 Samsung @ 175MHz 2-5-3,1T,4Bank, Triplex Ti4200 @ 320/650, D-Link DFE530TX+ 10/100 NIC, Lite-On 16x DVD, Sony 8x4x32 CDRW, Enermax Full Tower w/window,Rounded IDE/FDD Cables, Eagle 350w PSU, Hercules Game Theatre XP, VideoLogic DigiTheatre LC 5.1
3D Mark Score : 13529#5 AMD/Ti4200 Under 1850Mhz
Visit InfinityComputer.com! <-------------
Ive got the required stuff from my volt mod Lee and you just need to solder it onto the pin or use an IC clip or something.
Ive killed 2 mobos now, both Abit, KR7A and an IT7 now from volt mods....you can have my wires....ive given up on vcore mods....![]()
Intel P4 3.2 EE || Asus P4C800-E || Prometia Mach II || 2 x 256Meg HyperX 3500 || Antec TrueControl|| Sapphire Radeon 9800XT || 2x Raptors || Samsung 172T
OCAU 3DMark Team || 3DMark Compare: 26847 || World of Britney|| PCDB Entry
"Sundance is weird. The movies are weird. You actually have to think about them when you watch them. " -Britney Spears
andrew! u are making me not want to do it! ahahaha...
This maybe old, but whats that mod for? do you mean vmem mod maybe?Originally posted by Ciesko
I know.. but it's efficently. This is my mod on my KX7
Vcore and OVP, the chip is HIP6301CB pins 7 and 10
Another image of Vcore and OVP mod.
Vram mod, the chip is HIP6521CB the pin is number 3.
I've used a 50Kohm trimmers.
Good luck![]()
Ciesko
ah i need 3 pots?
i only have 2..
there 47ohm pots..
http://dissolved.netfirms.com/Picture%20015.jpg
^what they look like.
Do i need 3?
i havent heard of this OVP (over volting procection?) till now.
wheres it stop at?
i have the at7 (trying to sell), and gonna get the kx7-333 and vmod it.
gonna be water cooled.
If you don't use a OVP you need 2 pots, but you can have more of about 2,16V Vcore. 47Kohm is ok![]()
you lost me? can u explain?Originally posted by Ciesko
What if I just sodder the a 18kohm resistor to the pin 7 and then to pin 9 for ground what kind of adjustments should I get? Also could I do similar with a 4k for vdimm?
mmmm..~~ 18k ohm might be toughyyy....
22k ohm resistence, direct connection will give you upto 2.05v Vcore.
4.7k ohm for the Vmem will give you 3.25~ 3.28v.
My KX7 is rock n roll @ 3.45v mem with a 3k ohm resis.... LOL! really gave some sqeeze on my Sammy pc2700ctl@ 208mhz FSB@ cas2.0-2-5-2 on da KX7 blk caps.
What about the chipset(VDD?) mod?, what ohm resistor for that?...
i test chipset vmod,but no stability increase.
nobody talks about that:
and a agp voltage mod to im improve stability at higher fsbs,to kx7 333r,whem i try fsb higher than 215mhz,i have corruption on image.it is possible to change?
dfi lanparty nforce 4 ultra d
2x512mb twinmos speed premium bh5@2-2-2-5-1t 250mhz
gecube x800 128mb gddr3 256bits
Opteron 146 301x10 1.475v Water
