Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: Abit It 7 max vcore and vio mod!
    Jun 2002
    Munich-Germany
    Post Abit It 7 max vcore and vio mod!
    I'm searching for these mods! Does anyone knows how to mod?
    Epox 8KDA3+ full modified
    Kingston PC3500 HyperX ( Winbond BH-5) running 270Mhz 2-2-2-5@3.7V
    AMD Athlon 64 3200+@2430Mhz 9x270
    Club3D Geforce 6800 Ultra (on it's way)
    Overclocking Guru
    May 2002
    SoCal, USA
    Use this one for the V-core.
    Just pin 7.
    The 6301 is up top left next to the socket.
    http://www.xtremesystems.org/forums/...&threadid=1432
    OPP
    Overclocking Guru
    May 2002
    SoCal, USA
    Location of the 6301 chip
    Here is where the chip is located.
    Jun 2002
    Munich-Germany
    Ok thx opp!
    Jun 2002
    Belgium
    Just pin 7.
    OPP
    is the pin10 obsolete?
    Im going for veeeery high volts
    24 core Xeon:
    2x Intel Xeon Q3QS 'ES' @ 4.1GHz (folding@3.8GHz) - (flakey) EVGA SR-2 - 2x Antec Kühler 620 - 6x 4GB Corsair Vengeance 1600MHz CL8 - MSI GTX580 Twin Frozr II/OC - Thermalright Shaman - 2x Intel X25-M 80GB RAID0 - Silverstone Strider 1200W Gold - Lian Li PC-P80
    Jun 2002
    Belgium
    btw, is the VMEM possible on me IT7 (as it controls AGP too, handy for OC'ing me GF )
    24 core Xeon:
    Overclocking Guru
    May 2002
    SoCal, USA
    ctgilles,
    The memory voltage goes to 3.2 on this mobo allready.
    OPP
    Jun 2002
    Belgium
    nope, i have the 8y bios (max 2.8)
    anyone has the original one (/me is looking @ opp )
    cuz, it's handy to get the agp up and oc some more
    24 core Xeon:
    Jun 2002
    Minnesota
    Is this the one you are looking for?
    ftp://202.168.194.114/pub/download/fae/IT78H.EXE
    Jun 2002
    Belgium
    gonna try it
    24 core Xeon:
    Xtreme X.I.P.
    Jun 2002
    Denmark
    Hi ctgilles
    also some bios here:
    http://www.n3dt.com/bios/main.html
    OPP:
    my IT7 only shows 2.99-3.02 when the volt in bios is set to 3.2 V
    I agree with you this board need som good ram.
    I can go to 225 Mhz 3431/3442 stabil with corsair 400 DDR v 1.1
    a little more volt will help I think.
    CO Regards
    Tom Holck
    Denmark
    Best OC Regards
    Tom Holck
    Denmark
    The Homeland of nVentiv and Asetek
    Xtreme X.I.P.
    Jun 2002
    Denmark
    Funny,
    Just got the corsair 400c2 v 2.1
    They kan go 232 Mhz but the volt need to bee 2.9 ?
    at 3.0 its only 228, same at 2.8 V
    I thange the alu-headspreder to cupper it gave 234 unstable.
    The Mem are still the problem, going at 181 mhz (P4 2.533) 3/4 the ram have to do 242.
    Best OC regards
    Tom Holck
    Denmark
    Best OC Regards
    Tom Holck
    Denmark
    Xtreme Legend
    Jun 2002
    Arlington, TX
    Any clues on how to get the 3.2V from this board? After 2.9 mine only shows 2.96-2.94 no matter what I set it too.
    Jun 2002
    Melbourne, Australia
    Same chong, mine only goes to 2.9 even when on 3.2 I think OP mentioned he couldnt find any vdimm mods for this board?
    Im prob going to do the vcore cos my board undervolts to about 1.77 on load when at 1.85 in bios
    Intel P4 3.2 EE || Asus P4C800-E || Prometia Mach II || 2 x 256Meg HyperX 3500 || Antec TrueControl|| Sapphire Radeon 9800XT || 2x Raptors || Samsung 172T
    OCAU 3DMark Team || 3DMark Compare: 26847 || World of Britney|| PCDB Entry
    "Sundance is weird. The movies are weird. You actually have to think about them when you watch them. " -Britney Spears
    Xtreme Legend
    Jun 2002
    Arlington, TX
    Well, I tweaked my PSU a little bit and I get a little higher voltage on the vdimm. I dunno though. Its now at 3V and won't go any higher no matter what.
    Jun 2002
    What do you mean tweak bud?
    I have a 430watt Antec TruPower here and dont know anything bout tweaking PSUs
    hehehe
    Xtreme Legend
    Jun 2002
    Arlington, TX
    I just upped my 5 and 12 and then the vdimm got better.
  18. #18
    Jul 2002
    Does anyone know if the BIOS will work for the IT7 MAXII?
    Currently the IT7 II only allows for 2.8v, thought about vMod but if the BIOS works I might try that first.
  19. #19
    Xtreme Legend
    Jun 2002
    London England
    Does the NW pin mod work ok for the IT7 Max2, I'm assuming it will?
  20. #20
    Sep 2002
    Edmonton, Ab, Canada
    The original 8H bios provides a 3.2 Vmem. It's available at Abit.
    New rig:
    939 neo 2 platinum
    FX-55@ 271 x12... 24/7
    Prom 1
    Gskill 2x512...
    1 gb 3700EB for sale....any reasonable offer
    OCZ ram booster....for sale as well
    Sapphire X800XT VIVO
    Twin Raptors
    PCI raid card
    OCZ 520 PSU
  21. #21
    Xtreme Legend
    Jun 2002
    Hong Kong
    Smile
    Hardware limitations on the Vmem. JC and I worked on a Vmem mod, it works, but max Vmem is 3.04V. The controller IC is speced
    up to 3.5V, so something else is limiting it. The MOSFET that drives Vmem feeds off of the 5V line, that's why Chong managed to squeeze out a little more.
    DDTUNG
  22. #22
    Xtreme Legend
    Jun 2002
    Arlington, TX
    Thats right. I max out right at 3.07-3.04. Oh well. thats still not bad.
    Chong
  23. #23
    Xtreme X.I.P.
    Jun 2002
    Denmark
    Unhappy Is it the same Vmem regulator as the KX7/AT7/KG7 ?
    DDTUNG
    Hi Ddtung,
    Is the MemVoltmod on IT7Max the pin3 on one of the 2 chip with 16 pins? in the corner...
    Best OC regards
    Tom Holck
    Denmark
  24. #24
    Xtreme X.I.P.
    Jun 2002
    Denmark
    Talking Where are you Ddtung??
    We need your expertise, to get more mem-volt out of the Abit IT7Max.
    The mem speed at low (3.04volt) is the limit
    238 is limiting my FSB at 178. The P4 3Ghz come this month, and we are puching 4Ghz.
    My Winbond 4.5 can go close to 250 at 3.3 volt
    Best OC regards
    Tom Holck
    Denmark
    The Homeland of Prometeia and Vapochill
  25. #25
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    Look at my Vmem......with the ABIT IT7-Max2 Mobo I'm working now(for the time been).....
    INTEL PWA FOR EVER
    Dr. Who my arss...
