Page 1 of 2 12 LastLast
Results 1 to 25 of 44
Thread: 250FSB all air!!
    Jan 2003
    Tallinn, Estonia
    Talking 250FSB all air!!
    So here is the deal. I got myself an Abit NF7-S rev 1.2 about 3 weeks ago and have been playing around since then. I have done vdd, vdimm and mosfet cooling mods as well as puting on a new NB cooler.
    I had a 256MB stick of OCZ pc3500EL that was about 3 months old that would do 240Mhz stable on this board with 3.25V but anything above that wasn't stable.
    Here is my new NB cooler. Its a thermaltake SK-6 with a 60mm fan.
    Mosfet cooling (has a 60mm fan over it)
    So after that I am now running at 250FSB
    vdd@2.1V
    vdimm@3.15V
    vcore@1.87V
    CPU is an XP 1700+ 0308XPMW DLTC3 cooled with alpha pal 8045
    Some benchmark action
    Gaming is a go but my usb, nic and sound all end up dying after a few mins. So I think I will need to throw the old NB cooled onto the SB because my current mod isn't cutting it
    Steve
    Jun 2002
    LAS VEGAS
    That's in single channel not dual isn't it?
    Nov 2002
    Los Angeles
    well Spec, that is Mighty Nice
    2400+ @ 2100Mhz
    210x10 1.65v Everyday use.
    Watercooled.
    256MB Corsair XMS3500C2 2-2-2-11
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    Kick ass dude! Very nice oc'in!
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
    Xtreme Legend MrIcee's Avatar
    Jun 2002
    Cambridge, NY
    Great job Spec:thumbsup:
    Nice northbridge cooling you got going on there!!
    Randi
    Feb 2003
    Maryland
    Keep it up br0!.
    AMD Barton 2500+ @ 3200+ (2.2ghz)
    Abit NF7-s v2.0
    1gb // OCZ PC-3500 El DDr
    Sapphire ATi Radeon 9800Pro (4.7s) @ 407/720
    WD800JB x2
    Audigy-2
    Antec Truepower 550w
    Dec 2002
    great job
    btw, is that a plastic zip tie holding on ur NB heatsink? thats a pretty good idea. how secure is the heatsink?
    Intel E8500 @ 3.8ghz
    Corsair H50
    ASUS P5N-D
    Mushkin 2x2gig DDR2
    Galaxy 560 Ti 1024
    Nov 2002
    Orlando/Tallahassee
    Originally posted by Mister420
    great job
    I'd like to know this as well. I am thinking of strapping a spare heatsink on a NB soon, and I was gonna try shoe string but the Zip Tie thing might be a little better idea I was going to reinforce it with Glue as well to be safe, but I thought it would be pretty secure.
    Originally posted by JohnnyKnoxville
    Cool, a spam thread
    Originally posted by antipop
    Is that the kinda thread where you can do whatever you want??
    Oct 2002
    Toronto, ON
    Spec3 awesome job again man.
    Somone buy this man some better cooling!
    My online trading evals, 100% positive!!!
    Heatware 82-0-0
    , eBay 76-0-0
    DFI BIOS Settings: 11 x 293 MHz, 510 XCEL2-LL 180-E-1.5-2-5-2-7-13-0-2-1-1-1552-E-A-0-A-A-7-F-A-16-E-16-7-E
    New Project A Solar Powered PC Completed!
    Nov 2002
    University of Pennsylvania
    looks pretty good
    what timings are you using? and what are the temps?
    how about the CPU, whats that running at?
    Nov 2002
    Canby, OR
    thats pretty sweet!
    Spec3, did you have to mod the standoffs on the 8045 to get it to fit?
    Nov 2002
    When modding a p4 cooler to the nf7 nb i found screws to be a lot better. Zip tie would slide down when upright. All u have to do is the old coolere as a templet and drill holes in ur heatsink. U can then get a LOT of pressure on the nb. The only thing that sux is that resistor next to the nb that gets in the way... how did the sk-6 clear the resistor? did u mod the heatsink? i cut a notch in mine.
    xp2100+@2550mhz 2.03v 210fsb
    Abit nf7-s v1.2
    ATI R9700
    2x512mb Cprsair pc3500 c2
    Dual Channel!!!!!WOOT
    SATA raid on 80gig maxtors
    highest 3dmark 19300
    3dmark2k1
    Jul 2002
    Nice OC...and nice cooling...just becareful or you will do what I did on my first 8RDA+...you will see the capacitor I circled next to your HS you have on the NB...my first HS was like that and the HS melted the capacitor...just make sure there is plenty of room between the two...and no my HS was not touching the capacitor either...
    BTW - The 8RDA+ lasted about 2 weeks then fired...And also...nice Iwill fan ...
    Nov 2002
    Los Angeles
    You mean Capacitors
    2400+ @ 2100Mhz
    Watercooled.
    Jul 2002
    lol...yes...I caught that after I posted it and you posted...fixed now...
    Asus (Native) ROG Rampage Formula
    E6400 ()
    TRU 120 Extreme w/Scythe 120mm 110CFM
    2x1G Ballistix DD2 (D9GMH)
    Sapphire Toxic HD 3870
    Diamomd Viper HD 3850
    600w OCZ GameXstream
    Jan 2003
    Canterbury, UK
    Holy :banana::banana::banana::banana::banana:! Well done there!
    Given me a whole new boost of confidence when my replacement 1.2 gets here, a pelt'd n/b should do that shouldn't ? With 2v+?
    | Asus nVidia 580 GTX @ 850MHz |
    | Windows 7 x64 Ultimate | Mac OS X 10.6.8 | Mac OS X 10.7.2 |
    | Intel Core i7 970 @ 4.2GHz | Gigabyte X58A-UD9 | 12GB Corsair 2000MHz 8-8-8-24 |
    | HTC HD2 | MIUI 1.10.21 | Android 2.3.7 | TyTung 12.4 Kernel |
    New Builds Coming Soon..
    Xtreme Relic
    Jun 2002
    Hilton Head, S.C.
    I have a cheap aluminum HS/F on my NB and an SK6 lying around....probably should have used the copper. I attached with t-grease in center and 1 dot of super glue on each corner. Seems to be doing the job...was a tight fit on NF-S
    I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me.
    Hunter S. Thompson (1939 - 2005)
  18. #18
    Nov 2002
    Ohio
    I think your Northbridge cooling idea is about to be used on my setup....great work there!
    Do what you love, Love what you do.
  19. #19
    Nov 2002
    Plano, TX
    Yeah, I would at least try getting a better fan on that SB, if not a better HS. That should help some with your sound and UBS issues, but at 250, I'm not sure anything will cure them all other than getting separate cards and not using the onboard stuff..
    Epox 8RDA v1.1 | Athlon XP 2100+ AIUHB 0301 @ 2205 mhz (200x11) @ 1.8v | Radeon 9800 NP @ 378/324 | 2x256 MB of Corsair XMS PC3200 CAS2 | Maxtor 80gig 5400 HD | Linksys LNE100TX | SLK-800 w/42.5 cfm Sunon 80mm fan | Antec SX830 w/Antec SL400 PSU
  20. #20
    Nov 2002
    Earth: The Insane Asylum of the Universe
    Very nice! (I'm jealous. :p )
  21. #21
    Jan 2003
    Tallinn, Estonia
    Ram timings were 3-2-2 cl2.5
    The SK-6 os held on with a zip tie that I had to cut down a little to get it through the holes.
    Steve
  22. #22
    Moderator
    Jun 2002
    Nice. Makes me jealous. Did you tear off the green "NF7S" sticker on the "south-south-bridge" or did it come like that? I wonder what week NBs you aircooled 250 FSB guys have, that probably played a part as well.
  23. #23
    Jan 2003
    Tallinn, Estonia
    Think mine is the same week as my cpu
    0308
    Steve
  24. #24
    CCW
    Guest
    Wow! Nice mods The things a guy like you could do with TECs and water
  25. #25
    Jan 2003
    UT
    Very impressive. I wish my 8rda could do things like that. It has issues at 200 fsb, even with the vdd mod.
    Intel Core I7 3930K 4.4Ghz | Asus Radeon HD7870 | 8 GB Ram | Win 7 Ultimate x64 | Lenovo L220x Monitor | Logitech Z-5500 5.1 Speakers
