Results 1 to 3 of 3
Thread: Try this on your NF7-S 2.0
    Oct 2002
    London
    Guys....can you try this for me pls, assuming you have a capable cpu.....
    Abit NF7-S 2.0, original 1.0 bios;
    Memory timings 6-3-2 CAS2 Dual channel 2 x 256mb sticks;
    Run at 10 x 200 sync and check your Sandra bandwidth; then...
    Run at 12.5x200 sync and check bandwidth again......on mine the bandwidth is significantly higher with the lower multiplier and cpu speed!!!
    Tried on two seperate boards.
    Oct 2002
    germany
    the same thing happend also with my nf7s rev2.0.
    with multiplier 10-12 my bandwith is good, but with 12,5 it is bad
    i run 208x12 or 218x11,5 to get good bandwith combined with my max 2500mhz cpu speed.
    it is definitly the 12,5 multiplier not the high cpu speed!!!
    this is the same bug all nf2 boards also have with multiplier under 10.
    Oct 2002
    London
    Can this not be sorted out in a new bios release??
