Results 1 to 17 of 17
Thread: GA8INXP OC problems!
    Jan 2003
    Sweden
    Hi everyone, first of all i must mention ive been a frequent reader of this forum for a year but this is my first posting so bare with me
    My problem is this!
    Im runnin a Gigabyte 8INXP mobo with a P4 2.66 CPU C1 stepping and i cant seem to get past 163 in my FSB with a stable result! Thing is that above that 3D Mark 03 crashes somewhere in the last 3 "sound" tests! It doesnt throw me back to windows, it just gives me a black screen with the sound from the crashed test looping! Ive tried increasing the corevoltage without any luck!
    My setup is this
    CPU: P4 2.66GHz C1 Stepping @3264MHz (20x163) 1.680V
    Mobo: GA8INXP F3 Modded Bios
    Mem: OCZ Dual DDR EL 2.2.2.5 2.8V
    GFx: Radeon 9700Pro 350/330 1.7V
    Vapochill PE Cooled
    Enermax 550W (12V@12.030, 5V@5,080, 3.3V@3,340)
    As u can see all seems oki regarding my settings.. wicked! Pls help me out if u have any suggestions!
    INTEL P4 3.0@4143MHz
    ABIT IC7-MAX3 1.6 BT Bios
    GeCube X800Pro 560/1120
    OCZ 1024MB DualDDR 2.7.2.2 @383MHz
    Vapochill LS Cooling CPU
    Waterchill Water Cooling NB/VGA
    Antec True Control 550W PSU
    3D Mark 03 13155
    3D Mark 01 25127
    Xtreme Recruit
    Jun 2003
    Belgium / Antwerp
    i've got the same mainboard and a P4 1.6A
    i can't get it past 162Mhz FSB
    when i boot with FSB set to 162 i get a weird error from MBM 5.3
    it says there's something wrong with my kernel.dll
    but when i lower the FSB everything works fine again ...
    Pentium 4 1.6 @ 2.5 Watercooled
    Gigabyte GA-8INXP
    2*256 Corsair PC 3200 CAS 2 Dual Channel
    Asus Geforce 4 Ti 4400
    Soundblaster Live 5.1
    Western Digital 120 GB 8mb cache / 7200 rpm
    Western Digital 60 GB 2mb cache / 7200 rpm
    Oct 2002
    NYC
    I had that motherboard back when, and Almost everybody has the same problem as you. Its hard to even get past 150 fsb. Gigabyte is all about the little goodies and features. But if your looking for ocing big time Giagbyte is not the way to go>
    E6600 SL9S8 Malay
    ASUS P5W64( no mods )
    Mushkin (2 x 1GB) XP2-6400
    ATI x850xt
    2 x 150GB WD Raptor RAID
    Thermalright Ultra-120
    SilverStone ST56ZF 560W
    Xtreme X.I.P.
    Nov 2002
    Shipai
    gigabyte...
    Nov 2002
    Plano, TX
    For oc'ing... Giga bites
    Epox 8RDA v1.1 | Athlon XP 2100+ AIUHB 0301 @ 2205 mhz (200x11) @ 1.8v | Radeon 9800 NP @ 378/324 | 2x256 MB of Corsair XMS PC3200 CAS2 | Maxtor 80gig 5400 HD | Linksys LNE100TX | SLK-800 w/42.5 cfm Sunon 80mm fan | Antec SX830 w/Antec SL400 PSU
    Apr 2003
    Italy
    I have not had problems with my Gigabite 8INXP!!
    Bios F3 mod.
    2 DDR A-Data bh-5
    P4 3.06Ghz
    Ati 9700 Pro
    SuperPI
    And max Oc (not stable)
    HT On.
    For me si one good Mainboard. Stable and fast Mb..
    Xtreme X.I.P.
    Nov 2002
    Shipai
    20K with just 178 fsb???
    Oct 2002
    NYC
    Wow that is freaking amazing. I have not seen that board even go over 3.4 ghz. Very Nice scores man, but ill be building my sisters computer with that board. Canu go any higher and what are the memory scores in sandra?
    E6600 SL9S8 Malay
    ATI x850xt
    Xtreme X.I.P.
    Nov 2002
    Shipai
    21K with 175 fsb? theres something wrong here...
    thats NEVER the system you got 21K with
    he got 21K with an fsb of 290, fsb @230 and a 9800pro@475/370
    http://www.xtremesystems.org/forums/...threadid=13781
    carnaby?
    Apr 2003
    Italy
    carnaby?
    where you see 21k with 175FSB?
    I have only one screen with 175fsb...and is max Oc not stable!!!!
    If it watches the screen well is 3900Mhz with 169FSB!!!
    Link for detail
    http://service.futuremark.com/compare?2k1=6401015
    Xtreme X.I.P.
    Nov 2002
    Shipai
    hm the first two pix look really bad, i cant recognize any numbers on it but the 21K of the 2k1 bench.
    so you got 21K with an fsb of just 169?
    how is that posible that this guy gets the same score with an fsb of almost 300!!! and the memory running @ 230 cl2?
    hows that possible?
    http://www.xtremesystems.org/forums...&threadid=13781
    Apr 2003
    Italy
    hows that possible?
    Ehm....Gigabyte 8INXP is Granite Bay!!!!
    Xtreme X.I.P.
    Nov 2002
    Shipai
    ive seen a review comparing the 875 vs the granite bay. result, they perform about the same, the 875 is a bit faster @ the same speed.
    so the 875 is as fast as the 7205, then how can you get 21K with an fsb of 170 and this guy gets 21K with an fsb of 280?
    http://service.futuremark.com/compare?2k1=6560662
    more than 100mhz faster fsb...
    Apr 2003
    Italy
    Ok saaya. My screen now is ok. Refresh...
    These is my system:
    I have others screen over 21k with Gigabyte 8inxp and 9700Pro(450/370). Screen and file save 3DMark.....
    No problem
    Xtreme X.I.P.
    Nov 2002
    Shipai
    no its ok i believe you, just how is this possible?
    Xtreme Recruit
    Jun 2003
    Belgium / Antwerp
    i'm gonna install the modded bios in a couple of days, hopefully it'll get me past 162Mhz FSB
    one other thing:
    i've got Corsair PC3200 CAS2 currently running at 312Mhz, (156MHZ FSB) so they're not at their full capacity yet
    and still, they don't like the 5-2-2 timings, the only timings i can squeeze out of them is 6-2-2 !!!
    that's like, SUCKAGE ?? :S
    and btw, my NB temp sensor is broken i think ...
    it ALWAYS displays 25° Celcius ....
    and really ALWAYS it was 37° outside for the pas week, that makes it around 42-45° inside
    and the NB was still only 25° Celcius warm ......
    Gigabyte GA-8INXP
    Xtreme Recruit
    Jun 2003
    Belgium / Antwerp
    oh and btw, is it possible to get your ram running asynch ?
    cos i'm running at 156FSB while my ram is made for 200FSB so i'd kinda like my ram to run a little faster
    Gigabyte GA-8INXP
