Well, the new domain name is up and the site has been moved to a new host at www.8rdafaq.com But I really need to take the site to the next level content-wise. I've got the basics down, but now I need to get into the less common problems, and for that I turn to the forums. I've been going through hundreds of post on multiple forums and I'm going crazy at this point. I figured that I could post a request like this and maybe by the time i'm doing going through old info I might have some great responsesI'm searching for the following:
1. Post codes/errors that people are encountering, and a possible cause/solution if known (other then C1/FF). The manual is absolutely useless for this.
2. More info on the vdimm mod (yeah I know there is a lot going around now, but i'm still a touch short on what resistors to use and what resistances to start with) and if possible a high res image of the area that the mod is done in to use as a template for a diagram. I haven't done the mod myself so its rather difficult to explain to others.
3. More about adding caps to the back of the board. I'm no electrical engineer but I understand the value of this, and it would be a really easy mod, even for those with only basic soldering skills.
4. INPUT! I get tons of emails asking how do I fix this or that (always common problems) or general thanks for making the site comments, but no real input on how to make it better! Also I want to know about any problems you had along the way with your board.
Anwyays, thanks to all those who have been supportiveand I appreciate any help that can be offered.
I wish would only have taken "hints" from me, although it appears that most of the stolen content is gone. (not trying to sound like a :banana::banana::banana::banana:, I just have a subitle hatred for that site after what we've been through)
its an unfortunate thing though.
