Results 1 to 11 of 11
Thread: What "liquid! should I use?
    Feb 2003
    Santiago, Chile
    Question What "liquid! should I use?
    Hi everyone!!
    I`m new in Water Cooling, so I`ll be asking you a lot of stuff in a near future
    My first question to you Water Cooling Guru`s is:
    What liquid should I use in my system??
    XP1900 with Swiftech MCW462 w/Bronx Fittings
    GF4 Ti 4600 with MCW40 w/Bronx Fittings
    Cooper Radiator
    Sicce Idra Water Pump: http://www.sicce.com/pdf_sicce/pompe/idra.pdf
    Someones say that pure H2O is the best option, other that 75% pure H2O and 25% Antifreeze, I just don`t know...
    Best Regards
    Jun 2002
    Saskatoon, Saskatchewan
    Pure distilled water, probably, with possibly a little bit of water wetter.
    AXP1700+ JIUHB 0302 @ 2400MHz - TEC-Watercooled in The Skyscraper
    ABIT NF7-S , Sapphire Radeon 9500 Pro, 1.5GB XMS3200C2
    XS IRC channel: irc.quakenet.net #xtremesystems
    www.ocfaq.com
    Feb 2003
    ViƱa del Mar, Chile
    Yeah, I have always wanted to know what kind of "liquid" you people use in you watercooling systems... any other options apart from pure distilled water???
    thanx, bye!
    Jun 2002
    If you plan on going with chilled water, and your water will be going below freezing, you can add anti-freeze, or alcohol to the water as well. In situations above room temperature, antifreeze actually reduces performance.
    www.ocfaq.com
    Sep 2002
    Nottingham, England
    imo Water Wetter is a waste of time. I used it in my system and all it did was act like a detergent and just casue the water to foam up a bit.
    I have found that Deionised/Distilled water with Purple Ice coolant is the best option.
    "There is only one thing better than having a linebacker in your office, and thats having two linebackers in your office"
    12.7Ghz folding for XtremeSystems
    Jun 2002
    LAS VEGAS
    I've also heard that your tubing will absorb WaterWetter and purple ice. aTo prove this you just have to notice the color change in the clear tubing after prolonged usage. I know that WaterWetter does for sure, but I have never used Purple Ice.
    Jan 2003
    i've tried pure isopropyl alcohol ...... gotta have an airtight system ... i noticed it leaked easier than water would ...... seems to transfer heat really faster than water but if your radiator can't dump the heat just as fast ...... it'll heat up faster than water would as well ..... as water has a higher capacity of holding heat ...... seems to have better flow than water as well.
    Athlon Xp1700+ T-bred @ 2.376ghz JIUHB0302
    EPOX 8K3A @ 200
    512mb GEIL DDR333 ultra
    PNY Verto Geforce4 Ti4400
    Adaptec ASR2100S SCSI RAID 64mb cache
    3x18.2gb 10k_RPM Fujitsu MAN3184MP SCSI HDD
    Jan 2003
    and 1 more thing i noticed is .... when i used water ..... it hardens the plastic tubing i use .... while alcohol tends to soften the tubes instead
    EPOX 8K3A @ 200
    Feb 2003
    Hi everybody!!
    I'm a newbee to H2O cooling.
    I was thinking about getting only pure distilled water.
    Is that alright or are there any other stuff to add to distilled water in order to get max performance.
    Thanx
    Kanchana
    Jun 2002
    I use pure distilled water with no additives in mine, it seems to work fine.
    www.ocfaq.com
    Jan 2003
    UT
    Just go with distilled water. I actually have water wetter in mine, but that is because I had a gallon of water with it mixed in laying around. If you use plain silicon tubes, then additives like water wetter will get absorbed. Heh, nothing looks cooler than pink tubes in your case.
    Intel Core I7 3930K 4.4Ghz | Asus Radeon HD7870 | 8 GB Ram | Win 7 Ultimate x64 | Lenovo L220x Monitor | Logitech Z-5500 5.1 Speakers
