Hi,
New to watercooling have read through the sticky threads.
I am being offered a few items that are used/nearly new.
The components will be used for cooling my AMD 64X2 4800 cpu.
I have a choice of
Dangerden D5 12vpump (only 2 months old)
Aquaextreme 50Z-DC12 Inline Pump (not sure of the age)
Storm CPU block
I will go for 1/2" fiitings, with either of the above pumps, I am planning on using a PA120.3 rad with these. Are mounting kits available for mounting the rad on the outside rear of my case (Silverstone TJ-05), The case is pretty full with my 1900'x in Crossfire, 2 hd's in raid, floppy, dvd drive, Tagan 900w psu with a lot of surplas sata cable connectors in a bunch at the top of the case. I have room for everything else but mounting the rad would be tricky, requiring a lot of work.
I have room for a bay res, or even dual bay res, I assume there will be no advantage going for the dual res, are the standard cylindar types easier to bleed due to easier access (depending on mounting of course)?
Tubing wise how many feet are a safe length to but for a new build (was thinking of around 12ft)?
How many hose clips should I order minimum, reading the sticky's it appears that the classic steel screw types are safest?
Is there anything else I would need to have?
One more question which perhaps deserves a thread of it's own elsewhere, I will probably upgrade to Conroe at some point (perhaps early next year), given that the temps are lower as they are less power hungry cpu's, will water cooling still provide the benefits in terms of overclocks and stability? Initial tests show that the gap has closed somewhat between air and water cooling on these newer cpu's (noise performance aside).
Sorry for the noob simplicity/questions!
Regards
Raja
