Results 1 to 8 of 8
Thread: Weird Crossfire...
    Jan 2005
    Switzerland
    Weird Crossfire...
    Just went Crossfire some days ago (Sapphire X1900XTX + X1900CF) and I'm experiencing some problems with. I get 36'000pts with 3DMark01, 12'000pts with 3DMark05... is this normal ? Cards are at stock frequencies, haven't played with ATiTool yet with this XFire setup.
    The real problem is what I'm experiencing "graphicaly". Here are some screenshots :
    I'm running this on P5WD2-E (BIOS 0501), 620W Enermax PSU and 6.4 Catalysts (same with 6.3). Any idea ?
    Comp 1 : NCASE M1, Asus Z170I PRO Gaming, Intel i7-6700K, G.Skill 2x4Gb 3466MHz, Samsung 950 Pro (512), Samsung 840 Pro (256), WD Red (5TB), Asus nVidia GTX 980 4Gb, Silverstone SX600-G, LG 34UM95
    Comp 2 : Commodore Amiga 4000D, Cyberstorm MK2 68060 50Mhz 128Mb, Cybervision 64 4Mb, FastATA MK-VI, Indivision AGA MK2cr
    Comp 3 : Commodore Amiga 600, Vampire 600 V2 128Mb, Indivision ECS, 32Gb CF
    Jul 2003
    Never seen that, it looks like composting is seriously out of snyc in that second shot. Tried a driver re-install yet?
    Jan 2005
    Switzerland
    Separatly, thoses cards work like a charm :|
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    Check if your dongle cable is attached correctly (the screws and nuts of the dongle match with the ones on the master card).
    Mar 2005
    Madison, WI
    I have the exact same cards but I don't know what to tell you. I have a huge 24" Sony CRT and when I have these cards hooked up in Crossfire, I get small wavy distortion lines that come across the screen. Luckily, it isn't that noticeable while gaming. The waves show up when the processor is being worked (above 10% usage). This issue doesn't come up when just using 1 card.
    With an FX57 at 3ghz, I get just under 15,000 in '05 - pretty good considering it's a single core.
    My first assumption when X1900 crossfire cards go weird is the power supply. It's tough to tell if yours is adequate. Maybe someone else is using it that could give some feedback.
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Well, it's time to uninstall your driver, repair-install Windows, and re-install driver.
    Check your ram out too, while you are at it. Something is getting corrupted...not sure if it's chipset related or not tho.
    Been through that many times...found out that my mobo was reseting DDS to auto when i rebooted. CFX3200. Thought was cpu at first, but now i'm 200 mhz higher than when i first had that issue.
    Scratched my head for days over it. Switched tref, DS, DSS, lowered ramclocks, and all's well, cpu 200 mhz higher.
    I think my ram might be dying, or maybe a bios issue...but i found the same behavior on RDX as CFX.
    Mushkin XP4000 Redline 2GB, Infineon CE-6-based.
    Feb 2005
    Czech Republic
    Quote Originally Posted by G H Z
    never? i seen it twice .. with HIS X1900CF and previously Asus EAX1900 CF :-)
    The Stilt : on HIS i actually broke it by screwing it a little, its pretty easy to broke it on card, doesnt affect RMA, at least not from store i bought it, so this is not really needed.
    And for all crossfire users, bookmark this
    http://forums.guru3d.com/showthread.php?t=181125
    We got some interesting finds with crossfire
    This colorful edges reminds me of enabled alternate pixel center enabled, but it was with one card.
    ASUS P8Z68-V PRO B3 + Intel i5-2500k @ 5.0 GHz + Noctua NH-D14
    8GB DDR3 Corsair Vengeance XMP (kit 2x 4GB) 1866MHz / Gainward Geforce GTX470 SLI watercooled
    120GB SSD Kingston HyperX (games) / 1x 30GB SSD OCZ Vertex Turbo (system)
    22" LG IPS226V-PN / PSU Fortron AURUM GOLD 700(W) / Cooler Master HAF Tower RC-932
    Sep 2005
    Switzerland
    X-FI IRQ problem.. the Sound card share the same IRQ of the second GPU.. try change this..
