Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Can you say Liquid Gallium cooled Xeons?
    Oct 2005
    Denton, TX
    So a friend of mine bought some server cases the other day and low and behold there was some sort of cooling included with them...
    So turns out after some reasearh the company that made these made them for special high stress situations in the military. There is liquid gallium running through the hosing and the pumps are completely magnetic and very quiet. Unfortunatly the fans are EXTREMELY loud but I think there is some way to use this card to control. Not sure if any of you know anything about them or any tricks on how to use/manipulate them for "practical" application on desktops = P
    e6600, storm g1, p5b deluxe, 2gb micron fatbody d9 667, gigabyte iram (os), 2x 320gb seagate sataII 16mb, evga 7950gx2, silverstone zeus 650w, jinu vapoli on the way = P
    naked 4800+, sycthe ninja, a8n32 sli, 2gb ocz pc4000 eb platinum, 2x 74gb raptor raid 0 (os), bfg 7950gx2, ocz powerstream 470w, lian li v1200b
    Xtreme Guru
    Jan 2006
    Milan, Italy
    Zomg liquid gallium o.o
    Quote Originally Posted by Bloody_Sorcerer
    flowrate is for losers!
    Quote Originally Posted by MaxxxRacer
    Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
    Feb 2006
    Sol -> Earth -> Europe -> Poland -> Warsaw
    well... I think it's time for upgrades...
    May 2005
    Arizona State
    temps?
    Q6700
    MSI P35
    8GB OCZ
    2xHD 2900 XT
    PCP&C 1kw
    Xtreme Cruncher
    Mar 2006
    According to wiki, liquid Gallium-tin alloy conducts heat 65 times better than water.
    Try for ambient O.O
    I am Xtreme-ly Unemployed
    Nov 2005
    Palmdale, CA USA
    Now, THAT is cool!
    I'm doing science and I'm still alive...
    Mar 2005
    Cologne, Germany
    I don't think it's pure gallium but more likely a alloy like galinstan which has an even better thermal conductivity. The thermal capacity however is a lot lower than that of water and its viscosity a lot higher.
    The main advantage of these cooling systems it's their durability and toughness in harsh environments.
    Jan 2005
    Bay Area, CA
    Don't see that too often... I wonder what kinda pump is needed, that gallium is probably pretty heavy and viscous. Is it an electromagnet type pump?
    Also, What kind of fans are those, they look sorta like a dual counter rotating Sanyo Denki or something....
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    omg is this the entire fan or is it just something behind the fan?
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
    Xtreme Guru
    Jan 2006
    Milan, Italy
    There's like 2 or 3 fans in that tube assembly.
    Well, its one fan with 2-3 rotors. Delta sells double-rotor fans as well.
    Theyre screaming loud and very high pitched, those tube fans, you can find them in a lot of 1U and 2U rackmounts.
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    jeez. must be perfekt to cover an heatercore with those!
    high static preassure!
    Xtreme Guru
    Jan 2006
    Milan, Italy
    I dunno. The dual-rotor Deltas have lower static pressure than the single-rotor 9-blade deltas.
    Ive never seen specs for those server tube thingyes. If anyone "in the know" could link me the stats, im interested.
    Feb 2006
    Impressive! please post some temps when you get them.
    Xtreme Guru
    Jan 2006
    Milan, Italy
    Ok, im confused, how exactly is the loop setup?
    Is the rad split in half with 1/2 doing one cpu and 1/2 the other?
    Dec 2005
    wonder how much that cooling setup costs?
    Opty165 CCB1E0609FPMW@2.96ghz 1.4v on UT SLI-DR
    MSI/EVGA 8800GTX / TwinX2048-4400 PRO
    1x 150gb Raptor / 2x 750GB Spinpoint F1s
    1x Maxtor 320gb / LG Blu-ray /
    Thermaltake Armor / Galaxy 850w / Creative X-Fi / MCR-220, MCP655, Apogee GT
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    is the gallium thing dangerous?
    Feb 2005
    Belgium
    I don't think u can drink it
    Well, u can, but I'm not responsible for what happens
    I think it's like Kwik (don't know the English name of it), -> dangerous gasses.
  18. #18
    Oct 2005
    Denton, TX
    At the current point in time i'm waiting on some proprietary controller card that will adjust the fan and temps accordingly. I also am missing the mounting for them but am working on some sort of alternative solution (if you guys have any ideas/suggestions)
    The gallium is infact an alloy and the pumps are electromagnetic and very quiet, have run for testing but have yet to actually mount and play with it.
    The fans are actually two fans next to each other in some sort of opposite direction can get pictures later but they are VERY loud but with the controller sound should be bareable.
    The radiator has two seperate loops going through it as each cpu has it's own, but they share the same radiator.
    Once I can figure out some mounting solution looking to get up with maybe some of the ES chips i have (woodcrest?)
    http://www.xtremesystems.org/forums/...ad.php?t=99223
  19. #19
    Nov 2005
    Los Angeles, CA
    where did he get these things? if their made for the military class stuff they should be pretty damn good.
    i want!! gallium cooled sempron!!
  20. #20
    Xtreme CCIE
    Dec 2004
    Atlanta, GA
    That's a pretty good advertisement for Tygon tubing there too.
    Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
    Xtreme Network:
    - Cisco 3560X-24P PoE Switch
    - Cisco ASA 5505 Firewall
    - Cisco 4402 Wireless LAN Controller
    - Cisco 3502i Access Point
  21. #21
    Dec 2007
    Boston
    As Los Alamos director J. Robert Oppenheimer watched the demonstration, he later said that a line from the Hindu scripture the Bhagavad Gita came to mind:
    "I am become Death, the destroyer of worlds."
    Test director Kenneth Bainbridge in turn said to Oppenheimer, "Now we are all sons of b**ches." wiki
  22. #22
    Oct 2008
    Los Angeles, California
    I've owned a few Deltas before and they are no joke.
    http://www.sidewindercomputers.com/de12gf.html
    220CFM @ 59dB
    But having four Deltas though? That's just insane.
  23. #23
    Mar 2007
    Sydney, Australia
    Quote Originally Posted by fragmasterMax View Post
    Nothing quite like the buzz of resurrecting a 2+ year old thread is there?
  24. #24
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    OMG GALLIUM!
    Okey you offically got my Envy.
    I think its paralelled at the radiator.
    Each of those units are probably something simular to the apogee direct drive, only it uses magnets to pump the gallium.
    ZOMG you resurrected a dead thread and i helped bump it.
    DIE!
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
  25. #25
    Mar 2007
    41°6′43″N 74°8′45″W
    Those are 60mm fans that move around 50cfm @8k rpm or something like that.
    Core
    Core i7 920
    eVGA X58 LE SLi
    2x3GB Mushkin DDR3-1600
    BFG 8800GT OC
    Seagate 7200.12 1TB + Maxtor 320GB
    LianLi A05B
    Cooling (all internal)
    2x BI GTS 360
    2x DDC3.2 + Ek top
    EK Supreme LT
