Page 1 of 3 123 LastLast
Results 1 to 25 of 63
Thread: Next-Gen AMD Motherboard Intro- MSI K9N SLI Platinum First Sight
    Nov 2004
    the AMD K8 infrastructure leads the performance of CPU about 2 years, and we used to define Single/ Dual Channel memory by Socket 939/754.
    In the 2nd half of year 2006, AMD introduces the new pin definition, which is called Socket AM2, has the 2 major differences;
    The Socket AM2 will all support Dual Channel DDR2; and from the low-end Sempron to high-end FX. In this time, AMD achieve a united goal in infrastructure.
    Let’s take a look of the leading role this time- the MSI K9N SLI Platinum, it’s somewhat different from the engineer sample released on internet before.
    the left-lower part of board.
    The space between 2 PCI Express slots is very sufficient.
    With 3 PCI v2.3 slots
    Dual Gb LAN, 7.1 ch. HD Audio, and IEEE 1394 chip.
    the right-lower part of board.
    6 SATA2 ports, support RAID 0, 1, 0+1
    6 USB 2.0 ports
    and Clear CMOS button
    the right-upper part of board.
    4 DDR2 slots
    IDE port and 24-pin power socket
    the part around CPU
    there is heat sink on the MOSFET
    the fastener base is different, but still can use 939/754 coolers, have to test to know the real usage situation.
    the back I/O
    it has 4 USB 2.0 ports, dual LAN ports and 7.1ch. audio jack.
    it’s nForce 570 SLI chipset base, still the single chip
    the thermal solution of system chip
    it use the copper bottom and wide range heat sink to reach the quiet requirement.
    Testing platform
    CPU:AMD AM2 Althon64 X2 4800+
    MB: MSI K9N SLI Platinum
    DRAM: Wind DDRII 667 512MBX2
    VGA: ELSA 6600GT
    HD: Seagate 7200.7 80GB
    POWER: ONYX 520W
    CPU-Z at default 200MHz system bus and DDR2-800
    the BIOS introduction of MSI K9N SLI Platinum is coming soon.
    The performance benchmark is under testing for its limit, and cannot release the result right now.
    The detail of performance test will come after.
    Whatever, AM2 stands for the forward step of AMD, and we’ll look forward it available to the market.
    Mar 2006
    York, England
    sweet! cant wait
    Nov 2003
    Munich, Germany
    Quote Originally Posted by windwithme
    Just give us a hint pls:
    or ?
    "Physics is like sex: sure, it may give some practical results, but that's
    not why we do it." -- Richard Feynman.
    "A Celeron is not so much a processor, it is more a collection of shorting links to allow the motherboard to work." - read on xtremesystems.org
    Xtreme Cruncher
    Apr 2006
    Slovenia
    Isn't am2 supposed to have pinless cpus? Why the holes in the socket then? Or am i the noob?
    Thermaltake Xaser 3 V2000a ALU
    Phenom x4 905e
    4G ddr3
    Ati radeon HD 4850 sapphire
    OCZ Vertex turbo 30G
    Xtreme Cruncher
    Nov 2005
    Netherlands
    I'm guessing the performance wont be all that with DDRII-667 @ 400Mhz 5-5-5-15. You need good DDRII-800 to beat S939 with an AM2.
    Nice to see some stuff working though!
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    why does it only have a 4pin cpu power connector?
    and why does it say socket A? =\
    STARSCREAM
    3570k @ 4.6 GHz | Asus P8Z77-V LK | G.Skill F3-12800CL8D-8GBXM | ASUS GeForce GTX550 Ti
    Corsair Neutron GTX 240GB | Corsair Force GT 120GB | SK hynix 128GB | Samsung 830 64GB
    WD Black 640GB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i
    Corsair AX750 | CoolerMaster Hyper 212 | Antec P280 | Dell Ultrasharp U2410 | BenQ XL2420T
    ROCCAT Savu | Filco Majestouch-2 TKL w/Cherry MX Reds
    MEGATRON
    3770k @ 4.5GHz | Asus Sabertooth Z77 | G.Skill F3-12800CL8D-8GBXM
    SK hynix 128GB | Mushkin Enhanced Chronos 60GB | WD Red 3TB (4) | Seagate 7200rpm 3TB (2)
    WD Green 2TB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i (2)
    Corsair AX650 | Corsair H80i
    Xtreme Recruit
    Nov 2004
    Toronto, Ont
    I bet it says "AM2" once you lift the IO plate
    L90D+
    ocz520powerstream
    Nf4 Ultra d Venice3200+ 10x277 1.54volts TT Bt
    Redline 2x512, 251 2.2.2.5
    radeon7000 166.166
    Mar 2006
    Hungary
    Overclock it and have fun! Can you set better RAM timings?
    Nov 2003
    Munich, Germany
    Quote Originally Posted by v0dka
    I don´t think that this is an effective clock-rate, but more a physical one...someone uses very loose timings and 2T command rate for his screeny...
    Nov 2004
    Quote Originally Posted by itznfb
    socket AM2
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    socket AM2
    that would make sense wouldn't it.
    do you know why it doesn't have an 8pin connector for the cpu?
    STARSCREAM
    MEGATRON
    May 2005
    San Antonio, TX
    Yeah, I was going to point out AM2 as well. AM2 > M2. And that 400MHz speed is the actual clock, double that for the DDR rated speed of DDR2-800.
    Jun 2005
    I like the clear CMOS button idea. Very overclocker friendly feature.
    What I wanna know is why the bottom PCI slot is in different color? Also Windwithme can you tell us how many phase voltage regulations this board has?
    May 2005
    San Antonio, TX
    Quote Originally Posted by SamHughe
    The CMOS clear button has been around with MSI since 939. Also, the orange slot has something to do with a wireless PCI slot (I forget the specifics, my s754 K8N Neo Platinum had it).
    Nov 2003
    Munich, Germany
    Quote Originally Posted by tsuehpsyde
    That´s not 100% correct as well...DDR2-800 has an internal clock of 200MHz (prefetch of 4!). But the memory-bus is clocked at 400MHz.
    YouTube Addict
    Aug 2005
    Klaatu barada nikto
    What Sound chip are they using and what about Ethernet and Firewire?
    Fast computers breed slow, lazy programmers
    The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
    http://www.lighterra.com/papers/modernmicroprocessors/
    Modern Ram, makes an old overclocker miss BH-5 and the fun it was
    Apr 2005
    Calgary, AB
    I would like to see some BIOS shots esp of the RAM settings. Also please give us you impression of how the board clocks. Thanks!
    MB Reviewer for HWC
    Team OCX Bench Team
  18. #18
    "I eat motherboards"
    Dec 2004
    Topeka, KS
    Most likely one of the newer Realtek High Def audio codecs for sound.. ALC885 I believe it would be.
    杰森
    I can picture in my mind a world without hate, a world without violence.
    And I can picture us attacking that world, because they'd never expect it.
  19. #19
    Xtreme Cruncher
    Nov 2005
    Netherlands
    Quote Originally Posted by Flox
    It doesnt matter since 667 is probably too slow, that was more or less my point here. You do need DDR2-800 speeds to make a difference with 939.
    Could be me but I dont quite understand this post... It's DDR2-667 as stated by TS. But hey, I'm new to DDR2 so I guess it's true that this stuff is 4x HTT.
  20. #20
    Mar 2005
    Dallas, TX USA
    none of this makes sense, i thought the new platform would start as dd667, as in, 333x7.5
    this 200x12 makes no sense, is it unlocked????
    the fx-62 is supposed to be 400x7 is it not????
    ddr2 isn't 4x, it's still 2x
    Athlon XP-M 2500+ 0343MPMW The King is Dead!
    Phenom II X6 1090T 1025GPMW Long Live the King!
    I'm from the church of the operating room
  21. #21
    Xtreme X.I.P.
    Aug 2004
    Chile
    please run super pi so we can do a compare
  22. #22
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by VulgarHandle
    hmm, 200x12 w/ ddr @ 2-2-2-5 vs 200x12 w/ ddr2 @ 5-5-5-15, i'm guessin the ddr will win...
    edit: well, now i'm really confused, cpu-z memory tab shows cpu/6..... so, that means he's running ram 1:2, or is cpuz not showing fsb/multiplier correctly?
    the memory bus is running at cpu/6.. for 400mhz. it makes sense
    Got a fan over those memory sticks? No? Well get to it before you kill them
  23. #23
    Mar 2005
    Dallas, TX USA
    deleted last post, reposting, edited it heavily...
    Quote Originally Posted by metro.cl
    forgive me for quoting LOTR, but, 'questions, questions that need answering'
    no need to get into nda probs, but simple q's like, isn't the 4800x2 am2 processor supposed to be 333x7.5=2.5?
    are you running your ram 1:2? Is your 4800 unlocked?
    i reference... http://www.c627627.com/AMD/Athlon64/
  24. #24
    Xtreme X.I.P.
    Aug 2004
    Chile
    am2 cpus still calculate like 200xmulti
    multi is downwards unlocked on normal series, fx is completely unlocked.
  25. #25
    Mar 2005
    Dallas, TX USA
    lol, if that's true, what a waste..... although i guess that is supposed to be the point of am2, purely a switch to ddr2
    and i know only fx are supposed to be completely unlocked, was asking about HIS cpu, as it pertained to the 333vs200fsb question...
