Results 1 to 16 of 16
Thread: compressor conversion thread
    Xtreme Cruncher
    Dec 2005
    St. Paul, MN ,USA
    Alot of people are asking for conversions so put 'em here.
    is your friend
    http://www.convert-me.com/ energy conversions
    watts x 0.00133 = HP
    1 horsepower = 745.699872 watts (power, energy/time)
    1 watt = 3.41214163 BTUs per hour (heat transfer)
    1 ton of ice = 12,000 BTUs per hour (heat transfer)
    1 ton of ice = 3517 watts (heat transfer)
    For converting BTUs to Tonns:
    (1 / 12,000) * Zbtu/h = T%
    Where Z = Your BTU rating
    T% = Tonnage in a percent
    Quote Originally Posted by epion2985
    There is a problem here, alot of people dont understand that a 1hp compressor for example, doesnt mean it is rated at 1hp (2545btu/h) with respect to heat moved.
    Watts, HP, btu/h all measure the same thing, power, which is energy over time. However there are two different systems to consider. There is the power of the compressor motor, thats one thing. Then there is power with respect to heat moved, thats another thing. The first one does not equal the second.
    So dont assume your 1/2hp compressor is rated at 1272.5Btu/h, because its not. The rating for motor power and power with respect to heat moved by the system are very different things.
    Further more yes the power with respect to heat moved by the system is a function of the compressor motor power but thats not the only variable, there are many others that impact the result.
    So be carefull what you convert.
    Quote Originally Posted by Gray Mole View Post
    Right, one question I see sometimes, and it's about the lower 'BTU' ratings, that I thought would be good to answer in here.
    For instance, you have a 850BTU low temp compressor.
    That's not much is it? Or is it?
    Generally compressors are rated to what they do. So having one that's rated to Ashrae or Cocemaf whatever will read a lot lower than one rated to higher temps.
    So, if you have 850BTU at -25 (Cecomaf) for instance as your rating, then you have around 250w of heat removal at -25.
    That would put it at the approximately 1/3HP range for a compressor.
    So it's a good idea to look at the spec sheet of the compressor you're looking at, and check what the heat removal is at the temperature that you'd actually be using it at.
    Then the HP rating and all that starts to make more sense, because the rating of a compressor and what it actually translates into for YOU can look a lot different when you look deeper into the real spec of the compressors.
    Xtreme Mentor
    Mar 2006
    Redvers, Sask, Canada.
    Bring back natural selection! No more warning lables!
    The one and Only MG Pony
    Nov 2005
    Xtreme Cruncher
    Dec 2005
    St. Paul, MN ,USA
    Wow, that post pretty much sums it up now people can do a search for conversions and not make as many posts of the same thing! Thanks!
    -130C Club Member
    May 2005
    Poland
    This thread should be sticky, I have sent pm to man, who can sticky it
    DONE
    Nov 2001
    Wichita, KS
    As per request, it is stuck.
    If I may make a suggestion? As posts get placed, the original poster edit in the info that is requested and is viable for the thread.
    I will keep an eye in this thread and if it doesnt seem to go anywhere or get updated, I will unstick it.
    This is a bit early really to stick the thread, which makes me a bit hesitant, but I am hoping it proves to be a worthwhile thread.
    So make the sticky worth it!
    Apr 2005
    Closer than you think.
    Cheers
    Gray
    [SIGPIC][/SIGPIC]
    Xtreme Cruncher
    Feb 2006
    Emmaus, PA, US
    i thought this might be appropriate
    |Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
    (12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
    (12:16:19 AM) OC3D NoL: RAWRRRR
    Xtreme Cruncher
    Dec 2005
    St. Paul, MN ,USA
    Yay! it got stickeyed, and i can't really copy the pic so it stays there till i host it
    Dothan FTW!
    Jun 2004
    London, UK
    yes you can, just copy/paste this vbcode in:
    [img]http://img415.imageshack.us/img415/4710/hp1ck.jpg[/img]
    .:MeltedDuron:.
    Aurora - i5 7600K@4.2GHz- Zotac GTX1070 Mini - 16gb Corsair Vengeance DDR3-3000 - Asus Prime Z270M - Fusion ioDrive Duo 1.2TB - 2x512GB Samsung Evo 970 Plus - Seagate FireCuda 2TB - HGST 4TB - Fractal Design Define Mini - Win7 and OSX 10.12
    Lenore - Xeon L5430 - Gigabyte G33M-DS2R - 2x2GB HyperX 6400 - Sapphire Radeon HD5450 - M-Audio Delta 1010 - Adaptec SCSI - 256GB Firestorm SSD - 1TB Samsung F1 - 2U rack mounted - WinXP and OSX 10.6
    Delilah - Pentium E5800 @ 4.2GHZ (VID mod) - Asrock Conroe865PE - Radeon 9800 Pro - 2x512MB GeiL Blue PC3200 - 30GB OCZ Vertex - 160GB Seagate - 2U rack mounted - Win98SE and Win2k
    Jezabel - Athlon XP 2800+ Barton @ 2100 (200*10.5) - ATi FireGL X1 256MB - Asus A7N8X-E Dlx - 2x512MB OCZ EL PC3200 - OG Antec Case - Win98SE and Win2k
    Mysti (WIP) - Pentium II 350MHz - Abit BX6 Rev2 - 4x256MB PC100 SDRAM - ATi Rage Fury Maxx - Diamond Monster 3D Voodoo2 8MB - 20GB IBM DeathStar - Still looking for the right case...
    Xtreme Cruncher
    Dec 2005
    St. Paul, MN ,USA
    but it's still using his[/her{you really cant tell on these forums}] account
    Xtreme Mentor
    Sep 2004
    my pants
    French Duron Poof
    Every time you lap a swiftech block a kitten dies
    "Extreme Systems, yes. But it could also mean Extremely creative, Extremely resourceful and on and on. Please don't use the name of this site as an excuse to do stupid things" -situman
    HEAT
    Xtreme Cruncher
    Dec 2005
    St. Paul, MN ,USA
    wow... i thought my thread that was stickeyed got deleted
    Xtreme Cruncher
    Oct 2005
    BFE
    I think this thread should stay stickied
    May 2005
    Houston TX USA
    FYI, I also use www.convert-me.com for power, energy, and pressure conversions.
    I am Xtreme
    Mar 2005
    Quote Originally Posted by LukeXE
    DONE
    STICKY !!!! You should have all those numbers memorized . So get too it
    The Laws of Thermodynamics say:
    Zeroth Law: "You must play the game."
    First Law: "You can't win."
    Second Law: "You can't break even."
    Third Law: "You can't quit the game."
    Do you wanna Play Thermodynamics ???????? I forgot "you must"
