Results 1 to 20 of 20
Thread: 7900GT Bios Mod
    Nov 2005
    Chile
    7900GT Bios Mod
    Found this on Nibitor, maybe it can work...
    Can this be made?
    L627A107
    Dec 2005
    New York
    No, because of the over-voltage protection.
    People have already tried that (i think).
    Nov 2005
    Dorset
    does that protection only kick in at 1.55v i may be wrong but it does with my hard mod on my 7900gt manli
    rig opty 146 under home built phase running 404a 2gb gskill at ddr 572 3 4 3 7 7900gt 600/1660 on dfi nf4 ultra d.
    May 2006
    I can change the voltage for 1.4 for biosmod? or so functions way mod with conductive ink?
    Dec 2005
    New York
    Quote Originally Posted by KrauseOasis
    How many times must I say this (ok, this is the first time here, but I've said it else were), the 7900GT has overvoltage protection. It's not like the X1900 were you can just raise the voltage via ATI Tool.
    You HAVE to make some sort of physical modifictaion to the card that somehow bypasses the overvoltage protection (like the Contuctive Ink mod, and the penicil vmem mod)
    May 2006
    Quote Originally Posted by wizboy11
    Oks, thank you.
    MSI K8N NEO4-F /
    A64 WIN-939 1800MHz/2400MHz /
    7900GT XFX EXTREME EDITION (540/1600)
    CORSAIR 2GB VALUE DUAL (400/440)/
    FONTE TT 360W /
    HD SEAGATE SATA 200GB
    MONITOR 19 PHILIPS 109B63
    SPEAKER LOGITECH Z-560
    Jun 2005
    But OVP acts at about 1,28v ...
    CAn be possible to raise vgpu to this limit with BIOS?? 0,05v maybe help to obtain 20-30mhz
    salu2.
    ASUS P5B dlx wifi/ap
    Core2Duo E6400 2133 @ 3200 (400x8) 1,280v
    2xOCZ platXTC PC6400, FSB400 4-4-4-15@2,1v
    2x250Gb WD CaviarSE16
    XFX 7900GT XT 600/1800 + VF700CU
    BeQuiet BlackLine450W+Antec PLusView 1000AMG
    Oct 2004
    The problem is you're just changing the label for the VID code, which will do nothing. To change voltage in NiBiTor, you need to change the VID code. I've played around with my XFX 7900GT BIOS, and there is an extra VID code programmed in (00), but selecting it does nothing, so either NiBiTor isn't reading something right or the VID code is there but no hardware is on the card to support it. When you think about it, the latter makes sense, as the 7900GT is 1.2V default 2D and 3D. It'd just be a waste of money to include hardware for it to run at higher or lower voltages.
    Feb 2006
    Hong Kong/USA
    While I know 7900GTs have OVP, but then why eVGA's beta 7900GT Bios shows a 1.35v core and some people reported that they can oc higher with the new beta bios?
    Also eVGA's 7900GT Signature Series is using reference PCB also, with a 1.35V core.
    AMD Opteron 144 w/AC Freezer 64 Pro
    MSI K8N Neo4 Platinum SLi
    PATRIOT 2x512MB Extreme+XBL
    HIS IceQ3 ATI Radeon X1900XT
    NVIDIA Quadro NVS 280 PCIe
    INTERGRAPH Intense3D Wildcat 3400 PCI
    3COM 3C905CX-TX-M
    CREATIVE Sound Blaster Audigy 2 ZS
    MAXTOR 6L200S0
    BENQ DW1640
    LITEON LTD-166S
    TAGAN TG480-U1 480W PSU
    Jan 2006
    New Hampshire (USA)
    Hey Guys,
    I just recently got a BIOS from Mario who is an eVGA tech who I met in the eVGA forums. He made a modified BIOS to help with some of the issues we have had with the 7900GT's. I downloaded this BIOS version from him and just opened it with the new version of NiBiTor, version 2.9. Well unlike every other eVGA 7900GT BIOS that I've tried, this one reads to have a voltage of 1.35V. This wasn't some value that I changed with NiBiTor, it just reads that way on the VID tab.
    The card I currnelty have is my second replacment and it's unfortunelty suffering from the same exact issues my original card did! Not only that but just like my first card, this one worked perfectly fine for 2 days and only then did it start artifacting, freezing, blinking on/off, ect... Anyway I just got my second RMA approved and my Cross-Shipment replacment card is on it's way so I don't want to try this BIOS (I'll have to ship this card back right after I get my new replacment card so I don't want to mess with it).
    Anyway I'm just wondering if anyone has tried it and if so, did it actually change the voltage or not? From what I've just read above I'm quite sure it didn't or won't but it might be worth a shot? If anyone wants the BIOS just let me know and I'll e-mail it to you ASAP becasue I'd like to know if it will do anything?
    Asus Maximus III Formula (2001)
    Intel i7 860 (L924B516)
    Noctua D14
    Corsairs CMG4GX3M2A2000C2 (2 x 2GB) RAM
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    Creative X-Fi Titanium PCI-e
    LG GGC-H20L Blu-Ray
    Toughpower 850w Modular
    GSkill Phoenix Pro SSD 120GB
    HEAT
    The Blue Dolphin
    Nov 2004
    The Netherlands
    See: http://www.xtremesystems.org/forums/...ad.php?t=98911
    Quote Originally Posted by alexio
    Ok thank you. I have been looking at the bios-file and I'm fairly sure that this 1.35v card must have a different PCB from normal GT's, or the bios is just a big joke. I'm quite sure normal PCB's can only supply 1.1v and 1.2v. There are 2 VIDs and although you can name them to whatever you like it is impossible to change the voltage these VIDs give.
    I hope I'm wrong though,
    Someone please test this bios.
    Quote Originally Posted by Aleman
    I tried this BIOS (from Mario Gastelum Tech at eVGA) but the volts did not change since I
    1. could not OC any higher
    2. the temperature did not change at all vs 1.2V
    and the flash was successfull since I made a dump of the flashed bios and its the same as the one that supposes to be in the BIOS.
    And the asnwer to the question what card he has he answered:
    eVGA 7900GT CO N563
    Blue Dolphin Reviews & Guides
    Blue Reviews:
    Gigabyte G-Power PRO CPU cooler
    Vantec Nexstar 3.5" external HDD enclosure
    Gigabyte Poseidon 310 case
    Blue Guides:
    Fixing a GFX BIOS checksum yourself
    98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
    Feb 2006
    Hong Kong/USA
    Well then this rises a question.
    If the card is physically limited to 1.2V
    then why eVGA engineers put a 1.35V voltage call in BIOS?
    And I'm curious about Signature Series' difference, too. It's been heard that the GPU is running 1.45V?
    3COM 3C905CX-TX-M
    MAXTOR 6L200S0
    BENQ DW1640
    LITEON LTD-166S
    May 2006
    i want to find out the low down on this
    we have the GT, GT CO and GT CO SC cards which can be flashed to that new EVGA bios that supplies 1.35v to the core, so either the core is not getting 1.35v or there is no 1.2Xv voltage limit on a hardware level because many people have flashed their cards with this new BIOS and have reached significantly higher overclocks with it, so it does seem to allow 1.35v
    then there's the Signature Series card that as Richteralan pointed out on the EVGA forums, at least according to Newegg pics, has several additional components on the back of the card, but i have the SS BIOS and it does indeed push 1.45v to the core
    it runs 450/1320 at 2D level and 600/1600 at 3D level, runs 1.2v at 2D and 1.45v at 3D
    memory timings are as follows
    trc 12
    trfc 14
    tras 8
    trp 4
    trcdrd 4
    trccdwr 4
    trrd 2
    if anyone can provide a high resolution pic of the back of a SS card, that would be great, will provide one of my Superclocked card this evening to compare
    http://www.evga.com/community/messag...TOPIC_ID=14988
    Opty 165 CCB1E 0550VPMW 2.7Ghz'ish
    Crucial Ballisitx 512x2 PC3200 @ DDR560 3-3-3-8 2T @ 2.89v
    EVGA 7900GT CO SC @ 700/1800
    ALL AIR COOLED
    Jan 2006
    Does the eVGA Signature Series' have the same layout as the other 7900GT cards?
    May 2006
    Ok, so what if you removed the two resistors that enable overcurrent protection and do the custom bios update??? Like as this pic shows, removing a coulple resistors disables overcurrent protection.
    Then again, if you take the time to remove the two resistors you may as well voltmod while you at it. Just my 2 cents
    Apr 2005
    Read the sticky in this section. Those aren't overcurrent protection.
    These resistors. measuring 1,8Kohm, are meant to balance the current between the two pair of switching Mosfets to carry an equal amount of load.
    Oct 2005
    Netherlands
    Quote Originally Posted by nobody_here
    trc 12
    trfc 14
    tras 8
    trp 4
    trcdrd 4
    trccdwr 4
    trrd 2
    To change the Vcore through Bios will only be possible with the semiconductor switches onboard in the area where the voltmodding is done.
    There are very few boards that are equiped with those switches.
    If they are not on your board, you can do whatever you like in your Bios, but it will have no effect on the Vcore.
    If the EVGA Bios is giving a better score, it can only mean that something else is causing this, but not the Vcore.
    I can hardly believe that you have selected the right timingset. It should be:31/39/22/9/10/6/8.
    This reflects exactly the timing that Samsung specifies for the BC14.
  18. #18
    May 2006
    Quote Originally Posted by t024484
    let me be clear....i did not flash the SS BIOS to my card
    i'm just telling you what was in the BIOS that was extracted from a Signature Series card
    trc 12
    trfc 14
    tras 8
    trp 4
    trcdrd 4
    trccdwr 4
    trrd 2
    i didnt change them
    of course the high vcore doesn't directly change performance, but the only way the Signatuire Series card can hit 700Mhz is because it runs 1.45v stock, whereas most 7900GT's run 1.2v stock
    and yeah, i figured out that the BIOS changes do nothing, hardmod was required
    ALL AIR COOLED
  19. #19
    Dec 2005
    New York
    trc 12
    trfc 14
    tras 8
    trp 4
    trcdrd 4
    trccdwr 4
    trrd 2
    i didnt change them
    It's pretty easy to do 1.45 with a hardmod. I'm running 1.4 and I'm hitting 680 on the core. Maby 1.45 will get me too 700mhz.
  20. #20
    Dec 2004
    Overland Park, KS
    But what about those who have no experience with soldering? I have a CO coming tomorrow and i want to raise the volts :P
    Intel Core i7 920 #3841A437 @ 3.8ghz 1.26v HT off
    Thermalright True-120 Extreme
    Gigabyte ex58-UD3R @ 190x20
    6gb (3x2gb) G.Skill Pi @ 1520mhz 7-7-7-21-1T
    PNY 8800gtx @ 640/1000
    abs (tagan) 700w
    Antec Nine Hundred
    Seagate 320gb
    LG 25.5" LCD
    Logitech G11 + mx518, Logitech x530 5.1 + plantronics DSP500
