Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Some Dothan/7900gtx am3 fun
    Threw together the 780m/7900gtx for it's last sendoff in am3 and 01' tonight.
    Session ended very prematurely however, as I think I killed this p4gd1 ...dammit. need to let it dry out overnight I think.
    Worked up the card clocks for a a pretty nice single gpu am3 score.
    Almost 21k cpu score under 4ghz still!
    Card is about maxed, but cpu def. had enough to take WR and do some damge in 01'...hope the board lives. Really bummed about it atm.
    780M / single 7900GTX
    Jan 2005
    Texas
    JESUS!!!!!! those GPU clocks are NUTS!!!!!!! so is that score! squeeze the rest outta that dothan and tear the ORB up
    "Roses are FF0000, Violets are 0000FF, All my base are belong to you."
    Asus P6X58D-E
    I7 930 @ 3.9
    Asus 660ti DirectCU OC
    Antec Twelve-Hundred
    Sep 2005
    Russia, Moscow
    nice score!
    i may get you a p4gd1, pm me if you need one
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    That is sick, nice work.
    Good to see you keeping the pressure on.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    May 2005
    Camping your spawn :)
    WoW crushing results, sry about your board, hairdryer it :P
    thats what I do with all my kids kb's when they spill sode or juice on it..
    Wish ya luck!!
    Join the XS WCG team and do your part to help save the world..
    ^^^Click here to start folding for the soon to be number one team in the world..^^^
    Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
    "A computer beat me in chess, but it was no match when it came to kickboxing"
    -Emo Philips
    Jun 2005
    Melbourne, Australia
    how many volts going through GPU core?
    Dam fine result.
    C-BuZz
    Jun 2004
    south of heaven
    Nice job. You kept your word...
    Asus P4C800ED P-M 730@2.8 7700Cu
    2X1GB OCZ - ATI X800XT AIW - OCZ PS 520W
    -100c Club Member
    Jul 2005
    England
    KP do you think all 79GTX can get those ram clocks or is it still luck of the draw
    the samsung gddr 3 is set tight compared to the spec sheet would relaxing them help the rest us get better clocks
    your clocks are nut dude
    Feb 2005
    Roma Italia!
    gpu clock is IMPRESSIVE
    I am Xtreme
    Jan 2005
    can't the dothan go even faster than 39xx MHz. ?
    anyway, insane
    Where courage, motivation and ignorance meet, a persistent idiot awakens.
    Oct 2005
    UK
    Over 1Ghz core on the card.
    Congrats and the great clocks.
    Mar 2006
    Cola, SC
    Wow, those are some ridiculous clocks. Way to go again Kingpin!
    Jan 2004
    Saskatoon, SK
    That's fricken nuts Kingpin...you might want to show "My boys" how it's done and come post up as many scores as you can in my "[H]ardForum Top10 Database" over in the Overclocking and Cooling section of [H]...here's the link...that score is freakin' nuts...and it'd be killer to have your numbers posted up on my charts.
    http://hardforum.com/showthread.php?t=1010273
    • Intel Core i7 875K @ 3.86GHz 1.35v /w Intel Extreme Tower Heatsink
    • Intel Extreme DP55KG
    • 2x2GB Kingston HyperX PC3-10666
    • ATI HD5970 2GB @ 850/1,200
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    Jan 2004
    Manchester (UK)
    Great stuff
    I hope the board is'nt dead. Would like to see some more wonderful things from you...
    Very impressive card and cpu clocks!
    Quote Originally Posted by \Karting_freak
    nice score!
    Thanx very much for the offer KF. Unfortunately it was my 780ES that died
    Mobo and adapter tested fine this morning with a diff chip. I think running high vcca(2.8v) earlier last night during some cpu testing may have lead to it's failure. I had that little lh/dh/ch stable over 4050mhz too.
    Dec 2003
    Sorry to hear that.
    For shure that was amazing chip.
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    ahh 20k CPU Score, that to me is the most impressive thing i see there.
    Great Job K|ngP|n .. i knew your Dothan had it within.
    Sucks to hear about the chip.. Great way to send it off tho... no wait not really sending off HW is never good
  18. #18
    Oct 2004
    Wild West, USA
    Quote Originally Posted by k|ngp|n
    nooooooooo cpu died? Man that was one of few Dothan's i looked up too . Well Kingpin your PM system will always be in my personal hall of fame
    That is a crazy score anyway. 20K+ for cpu . And so close to WR.
    I bet if Dothan had a better platform to run on you would get it...
    Here is a litle info from Anad explaining wy Dothan does so well in AM3.
    Let us not forget that loads are probably the most important instructions of all. Not only are loads about one third of the micro-ops that are in flight in a x86 CPU, but they can also cause costly stalls when a load needs to go to the L2 cache (or worse, system memory). So how does this super flexible reordering of loads compare with other architectures?
    The P6 and P-M could already reorder Loads pretty good. They could move one Load before other Loads, as well as before Stores which have no unknown addresses or addresses which do not reference the same address as the load. In contrast, the Athlon 64 can only move loads before independent ALU operations (ADD etc.). Loads cannot be moved ahead much at all to minimize the effect of a cache miss, and other loads cannot be used to keep the CPU busy if a load has to wait for a store to finish. This means that the Athlon 64 processor is severely limited when it comes to reorder code.
    This is probably one of the most important reasons why the Athlon 64 does not outperform the P-M in gaming and integer workloads despite having a lower latency memory system and more integer execution sources. Integer workloads tend to jump around in memory, and have many unknown addresses which must be calculated first. It is less important for FP intensive loads, which is also one of the reasons why the Athlon 64 had no problem with Dothan in this kind of workload. FP workloads access the memory in a much more regular fashion.
    Abit IC7 P4 2.8a @4.21 | P4 3.4e @4.9 | Gainward 6800GT GS @486/1386
    Asus P4P800 SE Dothan 730-PM @ 2900 | EVGA 6800 Ultra GS @521/1376
    e8400@4.3G & 8800GTS G92 800/1932/1132 as gaming rig 24/7
    Custom self build chillbox with watercooling @-28c 24/7 | chilled wc " cpu -18c idle/-3c load
    3DMark 2005 Score Dothan & 6800U
    3DMark 2005 Score p4 & 6800GT
  19. #19
    Xtreme Cruncher
    Jul 2005
    London - UK
    dead dothan
    get Hipro's? he's selling it now...
    maybe 21k cpu score
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
  20. #20
    Apr 2006
    Singapore
    That's sure some mad stuff !
    A pity that Dothan died .... hopefully there is another that can do even more
    And i must say, that's some insane core clocks !
  21. #21
    Xtreme X.I.P.
    Aug 2004
    Chile
    maybe it was a signal, you have to move to conroe mate
    you'll be taking down several WR with conroe soon
  22. #22
    Banned
    Jun 2003
    Broomfield, CO
    the best CPUs always go down in a flame of glory...that's the way it's meant to be
    great score, go ahead, take my WR back from me, I'm just shy of 158K now
  23. #23
    Aug 2005
    Germany; Niedersachsen; Schaumburg; Bad Eilsen
    20k CPU Score
    Wow i thought it can only be done with an Conroe or Yonah .....
    I know my english isnīt the best ...
    my pc
    oVerkill.OC - Technic3D
  24. #24
    I am Xtreme
    Aug 2003
    Sorry to hear Vince Extremely impressive while it lasted, though.
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
  25. #25
    Dec 2005
    damn nice am3 score
    sux about the cpu dude...
    DFI LANPARTY UT nF4 Ultra-D [6/23 BIOS]
    AMD Opteron 148 [CAB2E 0546GPMW] [257x11.0 @ v1.500] & Zalman CNPS7000B-CU
    OCZ EL Platinum Rev. 2 2x512[207FSB @ 2-3-3-6 @ v2.80 1T]
    DFI Ultra-D [6/23 BIOS]
    eVGA 7800GT [470 / 1100]
    Western Digital Caviar SE 250GB Serial ATA
    Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply
