Team Group Setup details on DFI NF4/CFX3200DR thread
**reference cpu is Opteron 154 aircooling
PSU: PC P&C 1000w
Bh5 First:
FSB Bus Frequency: 250
LDT/FSB Frequency Ratio: 4x
CPU/FSB Frequency Ratio: 12
RD580 HT PLL Speed: hight
HT Bus NMOS Drive Strength: 31
HT Bus PMOS Drive Strength: 31
HT Bus Receiver Impendence: 31 or 5~10
CPU HT Bus Drive Strength: Strong
K8 Cool & Quiet Support: none
CPU VID Control: 1.4
CPU VID Special Control: auto
DRAM Voltage Control: 3.26v(real vdimm is about 3.2v)
SB PCIE Voltage: 1.8v
NB Analogue Voltage:1.21v
LDT Bus Voltage:1.21v
NB Core Voltage:1.21v
DRAM Frequency Set: 200mhz, 1:1
CPC: enable or auto
CAS (tCL):2
tRCP:2
tRAS:5
tRP: 2
tRC: 7
tRFC:12
tRRD:2
tRW:2
tRTW:2
tWTR:1
tREF: 3120 or (4708 , 3684 for long time bench like super pi 32m)
Bank Interleaved: enable
Errata 94: Disabled
Errata 123: AUTO or disable
Odd Divisor Correct: disable
DQS Skew Control:0
DQS Skew Value: none
DRAM Drive Strength: 3 (4 works perfectly as well) or try 5 as well
DRAM Data Drive Strength: 2 or auto
DIMM 1/2 Clock Timing Skew: auto
DIMM 3/4 Clock Timing Skew: delay 300
Max Async Latency: 7ns
Read Preamble Time:5ns
IdleCycle Limit: 16clks
Dynamic Counter: Enable
R/W Queue Bypass: 16x
Bypass Max: 7x
Burst Length: 4
TCCD...weird, my TCCD used to go very well on all NF4 board with 2.5-3-3-6 setting over 300mhz 1:1
However, no matter what, just can't get it running @ this board, but here is a solution, thanks the ODD
I can run 335 fsb with ODD so I can have like 301mhz on ram though.
Team Group pc4800
FSB Bus Frequency: 335 (so it will be 300 on the ram)
CPU/FSB Frequency Ratio: 9
DRAM Voltage Control: 2.67v(real vdimm is about 2.72v)
CPC: enable or auto
CAS (tCL):2.5
tRCP:3
tRAS:5 or 6
tRP: 3
tRC: 7
tRFC:14
tRRD:2
tRW:2
tRTW:2
tWTR:1
Errata 94: Disabled
Odd Divisor Correct: Enable
DQS Skew Control:0
DIMM 3/4 Clock Timing Skew: delay 450 or 600
Max Async Latency: 8ns
Bypass Max: 7x
Burst Length: 4
Team Group UCCC:
FSB Bus Frequency: 280
CPU/FSB Frequency Ratio: 11
DRAM Voltage Control: 2.63v(real vdimm is about 2.67v)
CPC: enable or auto
CAS (tCL):3
tRCP:4
tRAS:6~8
tRP: 4 (some UCCC will do 3 especially 0552 dated)
tRC: 7
tRFC:14
tRRD:2
tRW:2
tRTW:3
tWTR:2
Errata 94: Disabled
Odd Divisor Correct: Disable
DQS Skew Control:0
DRAM Drive Strength: 5 (think about 7
Bypass Max: 7x
Burst Length: 4
Team Group Micron 5bf:
FSB Bus Frequency: 275
DRAM Voltage Control: 2.70v(real vdimm is about 2.74v)
CPC: enable or auto
CAS (tCL):3
tRCP:3
tRAS:6~8
tRP: 3
tRC: 7
tRFC:14
tRRD:2
tRW:2
tRTW:2 or 3
tWTR:2
tREF: 3120 or 4708 , 3684 for long time bench like super pi 32m
Errata 94: Disabled
DQS Skew Control:0
DRAM Drive Strength: 3 or 5
DIMM 3/4 Clock Timing Skew: delay 300 or 450
Bypass Max: 7x
Burst Length: 4
Team Group I/A series:
CPC: enable or auto
CAS (tCL):3
tRCP:3
tRAS:6~8
tRP: 2
tRC: 7
tRFC:14
tRRD:2
tRW:2
tRTW:2
tWTR:2
Errata 94: Disabled
DQS Skew Control:0
DRAM Drive Strength: 4 or 6
Bypass Max: 7x
Burst Length: 4
I will contune to update about all those settings.
OPB
- You may not post replies
- You may not edit your posts
Forum Rules
