Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Interview: Daryl Ostrander - AMD R&D vice-president
    Xtreme X.I.P.
    Apr 2005
    Recently PCWatch interviewed Daryl Ostrander - AMD R&D vice-president. As he stated company will introduce new chips production tech using Germanium. This will increase transistors speed up to 15% comparing to current SOI technology.
    Also die shrinking shedule was on topic :
    45nm build CPUs will have implemented SiGe from the start.
    Source
    Jul 2005
    So, the reports are accurate. AMD 65nm launches in 2007. It'll be interesting to see if they use the K8 to tweak the process before hitting with K8L
    Intel i7-3770S l Thermalright Venomous X l Asus Sabertooth Z77 l 8GB G.SKILL Sniper Low Voltage l ??? l Samsung 830 256GB l Areca ARC-1200 l WD Caviar GreenPower 1TB (RAID1) l Pioneer BDR-207DBK l Creative X-Fi Titanium HD l Kingwin Stryker l Antec SOLO II l HP LP2475w
    Jan 2006
    Cambridge, MA
    I wasn't aware of how soon the 45nm builds were coming out. In fact, I didn't even know they were really on the schedule yet. That's quite impressive to hear.
    Athlon 64 3800+ Venice ~2.8, ASUS A8N-SLI Deluxe, 2048 Corsair XMS Pro (2 x 1024) PC3200, BFG Tech 7800GTX OC 480/1300, Audigy 2 ZS, 74GB 10k rpm Raptor Drive, 200GB Seagate 7200rpm, Rosewill RP550 PSU
    Jun 2004
    lake forest, CA
    Not really, you've just awash in nonsense from all the people who're saying AMD is gonna cave now and they keep falling farther and farther behind, etc.
    That chart sums it up nicely, while they've always been behind Intel on process development, the delays have been consistent and not getting farther and farther apart.
    Dec 2005
    im still amd to the core
    Xtreme X.I.P.
    Aug 2002
    Why are they building 65nm cores from mid 2006 and then only product launching 6 months later ?
    Regards
    Andy
    Xtreme X.I.P.
    Apr 2005
    Quote Originally Posted by zakelwe
    Regards
    Andy
    Apparently this 6 months is term from first prototypes till serial production
    Mar 2005
    Rotterdam
    I heard a lot of people touting the new SOI process will give a 42% increase in transistor performance over current generation but it seems its not true. What they mean is a 42% increase in performance over no SOI at all. The difference with the current generation will be at best half of that.
    Dec 2002
    From the benching here on xtremesystems, they'll need 3.7 GHz just to match 2.6 Conroe.
    Dec 2005
    Kansas
    Quote Originally Posted by keiths
    That's true with the current K8 arch. with the K8L the clockspeed shouldn't need to be as high the K8.
    Mar 2006
    Quote Originally Posted by mesyn191
    Sure AMD has something...
    Quote Originally Posted by INQ
    AMD is mad if it trusts in the tameness of a wolf, a horse's health, a boy's love or a whore's oath. The firm [Intel. Ed.] said in the Q&A that it had an answer to AMD's next generation too. This was the unkindest cut of all, but what's gone and what's past help should be past grief.
    Intel is a moving target.
    Xtreme X.I.P.
    Apr 2005
    Especcialy with Israel team onboard. Those guys put Itanium to it`s knees
    Jun 2004
    lake forest, CA
    Quote Originally Posted by lapdog
    Did I say it wasn't?
    Both of them are constantly working on something new and tend to leapfrog eachother in developments. The end result is that depending on how much you can spend and when you're looking to buy either one of them may be a better buy over the other.
    However as Intel has recently shown us (and AMD to in the not to distant past (ie. Thoroughbred/Barton vs Northwood P4 days...)) it takes a long time to come up with something new and in the mean time all you can do is sit and take the punishment.
    So the question isn't if Intel is working on something new to take on K8L, of _course_ they are!!! The question is when they'll have it available AFAIK they haven't released any info. on any K8L-killers that are coming anytime soon (though to be fair all we've had on K8L info.-wise is increased FP units (which does not necessarily equate to increased FP performance) and some vague data on process improvements...).
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    really? i must have forgotten about intels on die mem controller.
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
    Jun 2004
    lake forest, CA
    Quote Originally Posted by WeStSiDePLaYa
    I see absolutely no connection with your comment and what I said...
    Nov 2005
    Pamplona, SPAIN
    You said AMD was always behind Intel in process development, and WSP pointed to the Intel lack of on-die mem controller.
    But maybe you was referring only to process size?
    i7 2600k @4500 | Gigabyte GA-Z68X-UD4-B3 | Gskill 2x4096Mb 2133Mhz | 4x2TB WD Green RAID10 | OCZ Vertex3 120Gb | 2x AMD 6950 @ Stock
    Benq 24" TN | Samsung LE46C630 "2nd" Monitor | Enermax NAXN ENP850EWT | Corsair 800D Case | Corsair H60 | Logitech G9x + Wireless Solar K750
    Jun 2004
    lake forest, CA
    Quote Originally Posted by mursaat
    Process development has nothing to do with the on die memory controller, that would be an architectural design feature that you could build on any modern CMOS process...
  18. #18
    Nov 2005
    Pamplona, SPAIN
    OK, understood, I think WSP meant AMD was ahead in some technologies
  19. #19
    Jun 2004
    lake forest, CA
    Even then it still doesn't make any sense though, but whatever...
  20. #20
    Mar 2006
    The product launch for 45mn is not listed, And where does K10 fit in? I not sure that K8l is going to be a big change. AMD may have a good 2H08, maybe not.
    Intel 45nm launch is sooner than the chart said too.
  21. #21
    Mar 2005
    The first photo is interesing. If that reflects Frecuency and leakage scalability, expect that Processors leakage increase as Frecuency increases would be fairly lineal and that most of them will overclock around the same.
  22. #22
    Sep 2004
    Germanium Am I the only surprised that no Germans are used in its production?
    Sourcing parts for a mildly over clocked abacus.
  23. #23
    YouTube Addict
    Aug 2005
    Klaatu barada nikto
    Quote Originally Posted by gundamit
    It is just you.. what do you think the first Transisters were made out of man
    Yep you guessed it.. they did it right the first time...
    Fast computers breed slow, lazy programmers
    The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
    http://www.lighterra.com/papers/modernmicroprocessors/
    Modern Ram, makes an old overclocker miss BH-5 and the fun it was
  24. #24
    Apr 2004
    Personally I couldn't care less about 65nm K8 CPUs. I'm only concerned with finding out what K8L has in store.
    DFI LANParty DK 790FX-B
    Phenom II X4 955 BE (1003GPMW) @ 3.8GHz (19x200) w/1.36v
    -cooling: Scythe Mugen 2 + AC MX-2
    XFX ATI Radeon HD 5870 1024MB
    8GB PC2-6400 G.Skill @ 800MHz (1:2) 5-5-5-15 w/1.8v
    Seagate 1TB 7200.11 Barracuda
    Corsair HX620W
    Support PC gaming. Don't pirate games.
  25. #25
    Mar 2005
    Dallas, TX USA
    i'd love to see a 65nm K8, would give me a reason to by the DFI CFX3200
    Athlon XP-M 2500+ 0343MPMW The King is Dead!
    Phenom II X6 1090T 1025GPMW Long Live the King!
    I'm from the church of the operating room
