from here
http://forum.coolaler.com/showthread...39#post1451939
is ths allen-dale? fsb 333mhz! that's really like conroe xe.....,but xeon processor.
from here
low 17s..... drooollllllllll
pics of the setup?
is that 3ghz with 1333fsb AND 1.2v vcore AND 4mb cashe? that's insane
i just noticed... that's NOT an engineering sample!
i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
HD7970@1125/1575 stock voltage
1TB F1+2*128GB Crucial M4
Silverstone 450w, no case
2560*1440@120Hz overclocked catleap
Steelseries G6v2+5600dpi modded logitech trackball
:O is this stock ke?
*EDITed by IFMU*
Signature Removed by XS Staff for not following XS Policies
Forum Policies
Originally Posted by Waus-mod
YUP,stock...no oc,xeon support fsb1333.![]()
OMG... oc itthat is damn fast.... really fast
*EDITed by IFMU*
Forum Policies
Mayb the xeon will be the s939 opteron like amdwhat socket?
*EDITed by IFMU*
Forum Policies
@Hicookie
Can you ask that guy which board and bios he's using?
the board is es version,and he could't respon us , which socket 771 or 775?Originally Posted by the farmer
allen-dale? or woodcrest? dualcore ? or quad-core?![]()
i will ask him..if he could tell us some informations.![]()
this is most likely woodcrest.
allendale is conroe with 2M of L2 of cache.
(or was it single-core conroe?)
either way, it is a crippled conroe :-P
but woodcrest not..
17sec stock superpi is kinda mad lol![]()
ths just defual setup,ddr2-667 without any tweak. so fast
Allendale is the low cache version of memrom/Conroe and so not Xeon which tend to have large cache sizes. I think Woodcrest is the name of the large cache server based version of Conroe.
I think Allendale also is 1066fsb so whatever this chip is it is not Allendale ! Looks like a 1333Mhz 4Mb Conroe ....
Regards
Andy
This looks like a Woodcrest-based Xeon, which would make it dual-core and S771.Originally Posted by hicookie
And if the 3GHZ @ 1.2V are anything to go by, well, lets just hope Conroe cores will do as well ...![]()
Actually I think Woodcrest was supposed to come out at 2.93GHz and so this would be a close match ..so I change my mind and it is WoodcrestOriginally Posted by incurable
Regards
Andy
Thx.Originally Posted by hicookie
I think it's dualcore woodcrest and LGA771-Sockel
thank,the guy won't to tell more..
that's should be woodcrest,5160- 3.00GH
which board? he won't to tell,just said"es"
cpu&mobo all the es version, he told.
its woodcrest, this is the highest end Core macroarchitecture CPU which will be resleased in Q3, so thats pretty nice :p
EDIT: now someone go overclock one d@mnit. Just one more multiplier and you got the XE there...
Why publish and not tell which boardOriginally Posted by hicookie
Correct.
Thx for sharing these impressive info.
maybe because you aint supposed to have the board![]()
Nice chip, hopefully we get some more info soon.
It's a newer chip because it has de 6F4h steppings which is the newer B0 stepping according to The Coolest:
Originally Posted by The Coolest
intel Core 2 Duo E6600 @ 8x400MHz
Asus P5E X38 bios 1201
Corsair TWIN2X2048-6400 x2 4GB in total
eVGA Geforece 9800GTX+ || Creative Audigy 2 ZS
Adaptec AAR1430SA 4port Raid card
Seagate Barracuda 7200.10 160GB 8MB SATA2 x2 (RAID0, OS drive) on Adaptec
Seagate Barracuda 7200.10 250GB 8MB SATA2 x2
Seagate Barracuda 7200.11 500GB 32MB SATA2
Seagate Barracuda 7200.11 1000GB 32MB SATA2
Seagate Barracuda 7200.11 1500GB 32MB SATA2 x4
Coolermaster CM 690 || Corsair CMPSU-520HX
Windows 7 Ultimate RTM x64
Philips 200WB7ES 20" WS 1680x1050
MacBook Pro 15" June 2009
iPhone 3GS 16GB
omg
However, conroe xe is supposed to be 3.3Ghz![]()
Chip Number-Clock-Cache-Bus-Core
Cloverton Not yet Not yet 2X4MB 1066 4/4
Woodcrest 5160 3GHz 4MB 1333 2/2
Woodcrest 5150 2.66GHz 4MB 1333 2/2
Woodcrest 5140 2.33GHz 4MB 1333 2/2
Woodcrest 5130 2GHz 4MB 1333 2/2
Woodcrest 5120 1.86GHz 4MB 1333 2/2
Woodcrest 5110 1.60GHz 4MB 1333 2/2
Woodcrest LV 5148 2.33GHz 4MB 1333 2/2
That is simply insane.
Intel said in their earniong release call that they are already building inventories of Conroe , Merom , Woodcrest and availability should be no problem in Q3 ( July-August ) when they are launched.
well, Intel pretty much said they were going down theter for Q1 and Q2, so they gotta say something good to the investors to keep their stock from going south. HAving said that, I still expect their stock to fall pretty bad, and then guess whos gonna buy it right before Conroe comes out
Just like I said months ago. Conroe XE will pull sub-16 seconds stock at 3.33Ghz. Expect many systems OC'ed with good memory and tight(er) timings to go sub-12 seconds on SPI 1M. The champs will be in the low 9 second range.![]()
we'll have to wait and see, don't make sense that Presler only overclocks to ~4G on air, and yet you suggest Conroe can make nearly the same speed with less than half the pipe length.
