Results 1 to 6 of 6
Thread: Oblivion Vsync problem = low FPS
    Xtreme Guru
    Apr 2005
    Finland
    When I use Vsync in this game the FPS lies constantly on 43. Normally it would be 85 fps max when the monitor is set to 85Hz.
    Would be nice if some1 especially with an Nvidia gfx card and a CRT monitor could try to first load a savegame with vsync on and use the fps meter (write "tdt" in the console) to check out the fps rate. Then load the same savegame but with vsync turned off and check if the fps rate differs.
    I've never ran into this problem before but when I googled I find that it might have to do with Vsync and certain games in D3D mode that would require triple buffering in order for the fps not to drop. For Nvidia cards it seems like you have to have DXTweaker and .NET frameworks installed. ATI users can activate/deactivate triple buffering through the ATI tray.
    However, would be nice if some1 could try this out. Without Vsync on I seem to suffer from the "tearing" effect in this game and I notice it best when I'm strafing. It's the 1st game I've played where I actually notice the "tearing".
    Added some pictures below with vsync both on and off. It seems like it doesn't only limit the fps at 43 but also run constantly slower out in the wild where fps goes below 43. In areas where I get 28 - 30 fps with vsync off I seem to get 21 - 23 fps with vsync activated for example.
    EDIT: Weird, I just noticed that indoors in cottages/houses in towns I get up to 85 fps while out in the wild and caves I get max 43 fps even if I'm looking at the ground with vsync activated.
    Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
    If all people would share opinions in an objective manner, the world would be a friendlier place
    XS News
    May 2005
    FL
    Hey, my friend has the same prob, i thought he was losing his mind. (he has a 7900GT)
    i7-3820
    SB Z
    16GB 2200
    GTX690
    1KW Lazer
    pepsi fiend
    Jun 2005
    La Verne, ca
    if you do not get at least the amount of fps that you have vsynch requires, it halfs the fps completley so it does not fluctuate. adjust your settings to get above 85fps constantly
    Lanparty Ultra-D DEAD|REVIVED
    X2 3800+ LDBHE 0606 EPMW 2950 @ 1.55v DEAD|STILL DEAD
    Powercolor X1900XT 725/873
    dell 2005fpw 20.1''
    Quote Originally Posted by afireinside
    "uh yeah is this DFI RMA dpt? yeah I was setting up your ultra-d motherboard last night and the pwm shot a flame at me... can you give me a new one?"
    Quote Originally Posted by Mr. Popo
    if you wont eat all of your vegetables einCe will come and get you!
    XS_THE_MACHINE
    Jul 2005
    Exton, PA
    Yeah, it cuts your fps to 1/1, 1/2, 1/3, 1/4 etc of your refresh rate. 1/2 of 85 is about 43
    Solve by turning off vsync, and playing with higher settings so you don't go over 85
    Rig #1 | Opteron 165 (2898 @ 1.35v) | DFI nF4 Ultra-D | GSkill ZX 2x1GB | HIS X1900XT 512MB | Seasonic S12 550w in Antec P160
    http://www.last.fm/user/repoman0/
    Xtreme Guru
    Apr 2005
    Finland
    yea I understood this now, never dealt with such a demanding game which had to cut the fps in half (42 - 43) or better yet even as low as 1/4 (21 - 22) in some grassy areas with vsync turned on before. I've only played very old games with vsync on before that, which mostly run 150fps+ with it turned off.
    I much rather play with it off and have a smooth performance and sometimes notice a slight tearing effect than having to run it at constant slower fps ~7 or so with it turned on.
    Banned
    Jun 2003
    Broomfield, CO
    A simple search for "Oblivion" and "FPS" would have yielded my recent post on this problem:
    http://www.xtremesystems.org/forums/...light=oblivion
    i have found that disabling vsync also causes tearing as so i keep it on. i have an artificial cap at 50 fps when outside with a vsync of 75Hz.
    -FCG
