Results 1 to 25 of 28
Thread: Program to monitor Yonah temperature! Need testers
Threaded View
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Exclamation Program to monitor Yonah temperature! Need testers
    Hey guys. I just wrote a program that's supposed to monitor Yonah based chips' Temps.
    Basically the program works as follows.
    All Yonah based chips out right now are rated for 100C TCaseMax.
    What the program does is reads a 6 bits wide field in an MSR (6bits == 0...63), it reports a temperature relative to the TCaseMax. So the way its calculated is Temp = TCaseMax - value.
    So the temperature range this program can report is 37 - 100C.
    Here's the link to the program:
    Download "Core Temp"!
    Edit: I just uploaded a version that has a system tray icon. These are the changes:
    • When you minimize the program it hides the main window.
    • If you left-double click the icon you Hide\Show the window
    • If you right click the icon, you get the File menu (Basically "Exit")
    • If you left click the icon, you get a Balloon tip with the current temperatures. With CPU/Core enumeration
    • If you simply hover the mouse over the icon, you get a list of all cores and their temps
    I really hope this works. I just moved to VS2005 and that was a major PITA. So let me know.
    You might need the new runtime DLL: MSVCR80D.DLL
    Member of Overclockers.com Folding @ Home team
    "<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
    Main rig:
    AMD Ryzen 7 2700X / Mobo: Asrock Fatal1ty X470 / EVO 970 500GB + WD Blue 250GB + HDD / GPU: Dell RX 570 4GB / Mem: 2x16GB DDR4-3200 G.Skill 32GTZKW TridentZ - 32GB total / PSU: Seasonic Prime Ultra Gold 650W
    Secondary rigs:
    Core i7 2600K 3.4GHz @ 4.3GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / 2x Inland Pro 120GB / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 8GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
    Core i3 540 3.06GHz @ 4.0GHz (Freezer 7 Pro) / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: Antec 380W.
    Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
