OK, new version is ready here:
http://avala.yubc.net/~lukija/A64Info.rar
Before changelog I would like to point out that this tool can freeze your CPU in some cases. In most cases it is harmless, usually one reset will fix it, but in some cases you can corrupt Windows installation or who knows what else. So, take care, backup your data.
Changelog:
- added version number (10x to bachus_anonym). Since it is half finished, it starts from 0.50
- added option to change DRAM Data Drive strength (10x to bachus_anonym)
- added option to enable/disable Memory clock for DIMM0,1,2,3 (10x to ReelMonza)
- changing some parameters should be more resistant to lockup (eg memclk change) but sometimes it can freeze (in my case if I change to memclk 100, starting from 200, memclk greater than 200 are still not tested, i need CPU with greater multiplier)
- updated FAQ section, please read it
Some observations:
- do not change memclk while ODC is enabled, there is a big chance of freezing. Disable ODC first and then change memclk. After that, re-enable ODC. Which gives me an idea to implement it in next version
Feedback is appreciated.
